What most people don't realise is the NASA spec fuel systems required to track these things.... 7670 & above.
In the custom surge tank I'll be running a 700lph brushless pressure pump (possibly with speed control) so we can run higher base pressures for better fuel atomisation....and to reduce the current compared to dual 460's & so that the fuel is heated less. We are currently working out an intank pump to feed this serious bit of gear..... ..and designing a top plate to suit.
Build thread please
Get your car ready, I'll battle you at Wakefield or at a Roll Racing night.
NASA spec S15 vs Cabramatta spec R33.
  • Like 1
  • Haha 1
I love reading what you write, makes me wonder what planet you live on [emoji23]
A good quality adequately sized main and lift pumps are hardly 'NASA spec' smh
  • Haha 2
You'll be blinded by my shift light when I shift into 3nd slingshotting out of a tailkick from the power of the EFR equipped SR20!
I hope you like ethanol fumes & S15 tail lights pal!!!!!! I'm gonna need a parachute to pull up this wild hog!!!
Edit. P.s. pls sell me your SMB rear muffler lol.
  • Haha 1
Got my new SR22VET running with the T4 .92 IWG 7670.
Not noticing a whole lot of response loss compared to the old 2.2L setup with the T4 7163. Granted this new motor is built a lot nicer and has properly done +2mm exh valves which I guess helps.
Seeing it hit my 10psi boost cut at about 2.6k with no preload or wastegate duty and a 12psi spring, I'd expect it should do 20-25psi around 3.5k. it starts pulling hard at around 2.5k and is very linear. The 7163 did 23psi just before 3.5k.
Tune booked in for the end of the month so will have some proper results EOM.
  • Like 2
8374 with a 1.45 housing on a hamburger with the lot 2.8....is it epic? Hell f**king yes!!!!! The 1.05 is definitely hyperactive/frantic very early....but the 1.45 is like getting hit in the face by george foreman! In the lower mid to top end its just completely off its head, you're pinned to the seat holding on for dear life. Is it still responsive? Yes. Its just a little bit smoother early on.....you dont lose THAT much compared to the 1.05....and it still kills precisions, garretts and the like. The 8374 is definitely the perfect turbo, as it can do f ing everything VERY well....
But of course.....having a built motor with special head and portwork is 100% needed to bring out the goodness in these turbos....and when thats done...hold the f**k on!!! What would I choose? I honestly dont know if I could pick between the 1.05 and 1.45...they are both epic in their own rights...
13 hours ago, Kinkstaah said:
Except there's also that dude that made 466kw at the wheels on a 2.5 with one..
I think its more the fact its making nearly 200kw and peak torque at 4000rpm and seeing all the boost the match stick 4G rods can take by 4000rpm also. Big turbo behaves small even on a 2L 4 pot.
Edited by Mick_o
This no replacement for displacement shit really annoys me
Build a f**king don mega head and enjoy the fruit of an EFR.
Whats funny is 4 cyls can in some cases make more grunt & torque than 6's. Deal with it.
That makes sense, so bit better match to this capacity engine, lower rotating inertia than 9180 0.92AR IWG combo, similar turbine power potential, sounds like the ideal combination for high boost combined with transient response.
that is correct, 9174 works best with the big 1.45 a/r housing when pushing the turbos limit.  The 74mm turbine is relatively small to swing the 91mm compressor so anything that can be done to reduce preturbine drive pressure at high rpm / high boost is a win for this one.
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
    • yeah I get ~0.6L per session into the catch can. very ethanoly. It ends up overflowing out the breather of the catch can on circuit days too even with a 2.3L capacity catch can and I only drain out ~0.6L max. So every session I have to come in and drain the catch can, which is a hassle. So this is me cracking the shits and doing everything I can without removing the motor (back of head sump drain/breather and oil restrictors off the table). plans short term are: full length splash plates remove oem cam cover baffle add foam and reinstall at -10 or -12 AN fittings to the side of the cam covers down to the sump (luckily I already have fittings in the sump) Yes the ~340,000km unopened motor is probably not helping things
    • I'd use any fuel safe foam....mine went in 15 years and 15 rebuilds ago, still getting reused I'd have to say I don't understand swapping to studs to fit a particular baffle unless you are having a massive blowby issue, and even if you are addressing crankcase not head breathing is probably the next step.
    • BTW, the reason I came in here to "update" this list was that the Garrett G Series II range have been released and I've updated the list with their flow details if you're curious to check how they fit with previous Garretts and other brands The G-Series II G35 990 looks like a banger...
