9 hours ago, Roy said:
They binned the EFRs for Precision! At least they are man enough to run twins. Give them another few years and they will finally see the light and rock Trust turbos
Lol!  That would be pretty grand, and to be fair - they are using pretty advanced lag reduction techniques so they can probably run a relatively potato turbo and it shouldn't be too much of an issue.   Pretty funny seeing the now old/iconic Precision "bullet" antisurge ports on something this fancy.
I have to say, if that transmission works the way he is expecting it to. It will be a game changer. The speed and driveability if a DCT with closer to manual weights. Not to mention packaging advantages.
Edit: aww hell, I screwed up the quoting somehow. I was referring to the Koenigsegg video
Edited by Silverhks
it looks like they may be evaluating options or doing mockup/fitment. but surely dual 7670s aren't going to make the quoted 1600hp so maybe not. and its footage of two different engines, as the Agera RS and one:1 engines definately had precision snails on them.
here are a couple of screen grabs for the Jesko video...
EFR is on one side of the motor, precision is on the other? (ps that finish on the investment cast efr turbine housing is NICE.. like the early ones before they changed to a cheaper sand casting method)
Edited by burn4005
Those turbos look smaller than EFR7670 as well, probably 6758s or 7163s in that frame - definitely not 1600hp worthy haha.    Guess they figured they can use the bigger Precision turbos and use other tech to try and spool them faster was a nicer setup than making less power with naturally more responsive turbos.  Simplicity is not the theme of this car haha
multi million dollar car and using shonky turbo's with china sourced turbine wheels, compressor covers, and other misc parts....  gold. Obviously does not give a f**k about compressor maps or engineering of those items ?
  • Haha 1
Does anyone have any idea how a 8474 would compare to a 9180?  The 8474's compressor flows the same 95lb/min as the 9180, but the catch is, will it ever flow reach the potential that you see on paper in reality with a smaller turbine than the 9180?
I've been keeping an eye out and know of about 3 cars (two RBs, one 13B) which are going to be running them at some point but no idea on ETA.   The only EFR black series result I know of other than Eric's EVO is an EFR9274 on a 2JZ drift car which made around 1000whp.
^ way too small for a 13B engine IF used for maximum output.
Forget the dyno sheets, lets see if anyone else puts up actual performance (in a 3rd gen RX7), that is if they don't detonate and spray oil on the rear tires like the majority seem to specialize in ?
Yeah, the owner would be the first to say that it's not going to do the turbo justice - he won't be winding it up, engine is relatively stock spec.
On 3/12/2019 at 7:31 PM, minesskyline said:
@Full-Race Geoff or anybody really: Are there any EFR based (single) turbos that can achieve 1100+ hp (to the wheels)? Running a 26/30 (3.2l) (the thread for this is incredibly dry) for reference.
Hard to say what a 9280 1.45 will be capable of at full tilt?  I dont know yet.  I agree with burn4005 that twin 7163 would be the best way to acheive the 4-digit power levels.  Garrett G25-660 is also a consideration.
If you really wanted to stay single turbo, the G42-1450 may prove to be a good way to do that.  still a bit early to know on that turbo as well
:4_joy:
edit - another evo on 8474 is ken thwaits from showtime motorsports in the usa.  he switched to 8474 recently, and after the first event he said its insane, 4 wheel spin has required some changes to their setup and tune
Edited by Full-Race Geoff
He said 674whp which is decent power but not anything which makes it seem like it is running an upgrade from an EFR8374 :/
Edited by Nismo 3.2ish
Wrong info
Puts on EFR and makes excuses? FYI 100% Stock motor we ran on EFR9180 at 2850mB easily, when took engine out on tear down it was perfect inside, even on full knock limit running ;) then again it runs a proper ECU ;)
As the most respected/qualified Internet knowledge & on line learning vehicle modifiers in the world said and I quote:
"If I was too like buy a hot water balloon and I don't fly it, like whats the point"
Edited by RICE RACING
Who made any excuses about anything?   You are the only one acting like there is an issue :P
Let's see when the kunts show the performance  ;)
Everyone prefaces 50 different excuses as to why it wont do XYZ, typical of the times we live in now in Generation GAY.
    • Nope, but they are definitely one of the default choices. Well established.
    • Has anyone used > https://performancecoating.com.au/
    • Haha actually I did join back then under a different email address,  I couldn't re-activate my account so made a new one! I didn't post much anyway so not missing out on much. Amazing to see how the value of the cars and parts has changed over the years, also ACT section appears to be dead now.
    • Thanks... It's in pretty good condition overall, probably due to not being drifted/tuned however being a daily driver has taken its toll. Had 100k on the clock when I got it, up to 180k now. Unfortunately it's not 100% dent free, it's got a small dent on FLH side and broken indicator from where I hit a small kangaroo at high speed. If you look at closely at pic #5 you might spot the dodgy trailer light repair my old man and I rigged up as temporary repair! - It's still there due to a combo of needing the car as daily driver and then too lazy/busy to fix properly. I've a couple of other minor accidents accidents as well but nothing major. One required a new front bar and unfortunately the smash repairer ordered the normal gtst one and not the aero bar. Needed the car back asap so just went with it, regretted ever since.
    • I can't believe that anyone is foolish enough to believe that the base maps are for any other purpose than to drive the car up onto the trailer/truck or gently creep it to the dyno. No matter how good they are, they can never be any better than the factory maps**, and only the foolish trust those on a significantly modified setup. **Yeah, yeah. I know there's also the difference between factory maps being fixed to certain injector sizes and MAP/AFM/VE relationships, and the likely aftermarket ECU base maps being better able to handle the sorts of changes that would render a stock ECU dangerous, like different sized injectors. But let's just ignore that for the moment, because the principle is still the same.
