G42 definitely has the exhaust flow to back it up - but a significant amount more lag too.  Probably the way to go if you are looking for big power, but if you are looking for big power and response doing something a bit different a Xona Rotor 105-69S have the potential to be pretty epic when they get more available.
Its such a fine line. At the end of the day, everyones idea of laggy is different.
9280 would bolt straight up to my current setup as I've got a 9180..... that's why I'm looking down that route for this new engine.
I haven't been on the forum much in a long time - but look what turned up in the post today...  courtesy Geoff Raicer (thanks again mate).   Just came by to see what the latest results were..
I'll be doing a direct one to one comparison of this vs my current 8374 when the time comes.
  • Like 6
18 hours ago, burn4005 said:
People really like round numbers don't they.. My car did 495kw at absolute max turbo speed and everyone always asks why I didn't go one psi more to break the half ton.  If you need a round number in your life set the Dyno to metric and aim for 700kw instead of 1000hp.  People forget that tuners pull a degree or two of global out when they unstrap the car anyway.
#penismeasuringcontest
18 hours ago, Lithium said:
 If you get an EFR9280 on a strong RB28, and tune it until you hit around 117,000rpm shaft speed then who gives a crap what the dyno says - that is going to be a FAST car.   Pick a bunch of parts which work well together and build, tune until it's sent and go forth and enjoy... that is the way to get a happiest result.
totally agree.  A illustration of this is seen working with world class top-level professional drivers.  Guys who drive real racecars for a living, sit them in a turbo 4 or 6 cyl vehicle with a big EFR at full song, and everytime its the same shock-and-awe reaction of "that thing is so fast, i have to change my driving style to adapt".  These are the best in the game, and its not easy for them to drive to the limit.  especially considering how laggy these little RB engines really are - even with all the tricks.
12 hours ago, Dose Pipe Sutututu said:
HP, kW, Shaft speed are great numbers, but those numbers are completely useless if you can't back it up with solid time slips OR eye popping lap times.
But my dyno chart number is bigger than yours !! ... said every forum jockey ever. (especially on the BMW forums)
i love the guys at Tial,.  however xona rotor = undivided singlescroll only.  For some applications this may work well but Im pretty stuck on divided housings for I4's and I6's that turn (dragstrips singlescroll is fine).  What further irks my inner engineer is there are no turbine or compressor maps nor speed sensor option to confidently know where you are operating... but thats never affected precision so it must be me.  the market doesnt seem to care
Very true.  my idea of laggy has changed considerably over the last few years as i get more experience with better spool.  Regardless if you can do a supercore swap on your setup, that would be convenient.  all the hoses/fittings remain the same and you might be able to get away without removing the turbine housing from the vehicle
Edited by Full-Race Geoff
  • Like 1
Ahh yep, gotcha.  Sounds like the 9280 is a couple hundred rpm or so laggier but the compressor map definitely paints a picture of a lot more flow.  I think the 9180 compressor left a bit to be desired, so in that sense it may be a good upgrade depending on how much more power you want, and how much more lag you can live with.
A shame results seem to take so long to filter through - most people who have run them so far have not shared anything, and the things shared so far fall well short of what the flow claims would suggest aside from the EFR8474 dyno result from a couple of years ago.  Hopefully this changes eventually!
Yusss!
On 7/2/2019 at 4:15 AM, Full-Race Geoff said:
8474 0.92 a/r just won pike's peak with a Honda K20
62101444_2552144351482953_20056412691259
https://newatlas.com/2019-pikes-peak-results-robin-shute/60378/
With a Life Racing based ECU and correct set up that engine would have run properly LOL........
Regardless goes to show what a superior power train config can manage, we run a 2zz 1.8lt engine on EFR at same level of peak power but with far broader power range, similar vehicular constraints, and I can confirm it makes lesser packages look 'compromised' when you look at the performance potential.
Edited by RICE RACING
I just want milk that tastes like real milk.
In other news, i'm getting boost spikes with the new tune unfortunately, seems to be more on rapid changes in revs, eg in second or if i lift off and the get back on it in 3rd/4th. This is using the 4 port with 14psi springs in an IWG 75. Will have to head back to the tuner I suppose.
that being said I do have the 1.05 rear housing chilling out in the shed still that i got with the replacement core...
Sneaky Pete, can I ask why you would run a 14psi spring with a 4port? my understanding the ability of the 4port allows you to run minimal spring (say 7psi) which in turn lowers your lowest boost pressure but the 4port gives ability to run boost to the top of the gate if u have a twin port iwg 75 that has that ability. This could help with the gate catching the spike. Maybe that your just too small on the rear but dropping the spring pressure imo would be my first thing to try.
  • Like 1
Personal attacks, negative posts about businesses (including childish name calling) and off topic posts (this is a turbo, not ECU thread) removed. It's not that hard to keep a discussion civil.
Further such posts will lead to warnings and bannings
  • Like 2
Is your ecu doing the boost control? You could try backing off the proportional gain a bit as the proportional error seems to be too high. Alternatively you may need a bit more derivative to back it off if you think the prop gain is correct (output gain matches process gain)
  • Like 1
Hard to say without having had a look or go at it all and not knowing which ECU you are running etc, but it seems like there are a couple of things there which definitely are setting up to make it a bit of a challenge to make boost stable.... I'm not a huge fan of the internal wastegate EFRs personally, the 1.05a/r housing with external wastegate seems to be the way to go in most cases but as Welshy says, the 4-port actuator with a 1bar spring in it is definitely likely to make things trickier.
You basically end up with much smaller duty cycle differences needed to have a solid impact on wastegate behaviour, and annoyingly a lot of ECUs with closed loop boost control don't factor in the dead time for the wastegate solenoid which means that closed loop corrections are counting the dead time as part of the effective pulse width... not usually an issue when you have a fairly wide duty cycle range for not a huge boost target range, but a bit more of an issue when the amount of the pulse needed to open the solenoid in itself could have a reasonable impact on boost if applied as part of the effective pulse width, if that makes sense?  It's likely to make closed loop control have fits unless the ECU is able to provide the closed loop logic with just the effective pulse width to work with.
We haven't actually tried it out yet, but one of the cars I work with that need a wide boost range we've plumbed up two 3-port solenoids and will use a PWM output on the Link ECU to regulate pressure to one side of the wastegate just using a table to effectively bump up the spring pressure based off boost target a bit, so we can use a .4 or .6 bar spring and be able to run sufficient boost to justify the setup with acceptable control.
  • Like 1
I would run a much softer spring. you are clamping the lower effective control range of the boost control output as its just more preload for the boost control pressure to overcome for no reason.
I am using a 5psi spring in a progate 50 and it holds 28psi no problems, in saying that it has an excellent diaphram to valve area ratio (~2:1) so even a 1psi spring would work.
I also recommend the 12watt mac solenoid instead of the 5.4. its deadtime is significantly shorter giving you a broader effective control range.
  • Thanks 1
@burn4005 noticed you don't have a build thread, however I recall you run a 76mm Pro Series cooler?
If so, are you able to give me some data on your IATs with a bit of load? I'm in the middle of tossing up between a 76mm or a 100mm cooler as I want the IAT as low as possible as I plan to mainly run 98RON with the occasional dilution of 98RON with ethanol.
I did a bit of logging and with my dim sum bok choy 76mm Hybrid cooler it's peaking at 59 degrees on a 15 degree day in 3rd with only a baby amount of boost (1.4bar).
nah I've got a 100mm greddy unit.
dont really have much useful data as I havent got any track data for full boost as I'm getting the chassis happy first. and at 10psi from the last test day there is very little heat being added to the air, making around 300awkw.
but a 7 second dyno pull at 28psi went from 26 to 34 degrees C. but thats more heat sinking than cooler efficiency, Dyno fan not an accurate test.
You've kept this quiet...
Game on mole :D
  • Like 1
Game on mole :D
I wanted to 'surprise you'..   and now because I couldn't keep my mouth shut..  I've gone and ruined everything.
.......................You know about the Samsonas though yeah?
PS..   I can't believe you called me a mole...
    • Yeah one of the first things I out in when I started having catch can filling up issues. Still prefer to empty 1-2 times a track day rather than every session
    • You'll find this link is probably more useful  Performance Turbochargers - Garrett - G GT GTX GTW Series Turbo TBG G35 1150 map may not even get added to my list depending on how it looks, the G35 1050 already is a mixed bag for making the numbers you would expect from the compressor map due to mismatch - I don't know how another 10lb/min of compressor flow is going to make that any better.   I've left out others for similar reasons as it's already getting quite big.   In terms of Precision, provide me with legit compressor maps for them and I'll do my thing   I'll add some more of the newer Xona Rotor options are they're pretty boss, I'd take a 68mm Xona over a G35 "1150" any day of the week - or Precision for that matter.
    • Ahh got it. Well maybe install a drain for the catch can somewhere down low and accessible like a wheel well too....
    • Before you blow your car up, have you checked you've made all the correct modifications to the wiring if you're still using the RB20DE loom?   Some things to look at: The pin used for the map sensor on the RB25DET, is the same pin used on the RB20DE for the Ring Gear Crankshaft Position Sensor, no idea what you've got it plugged into now. The turbo pressure control valve solenoid you're talking about on the RB25DET, the same pin is used for the Variable Air Intake Control Valve on the RB20DE.   The factory manual has the wiring pinouts in it for you to check everything. It also has the diagnostics process to read codes out. In addition, there's a great table that shows what sensors and what actuators not functioning will relate to which signals. And Nissan confirm the as everyone else has from experience, the Solenoid being disconnected won't cause a fuel cut. However, the turbo pressure sensor being missing / wrong, WILL cause a fuel cut. https://www.nicoclub.com/service-manual?fsm=Skyline%2FR34-Workshop-Manual-English.pdf
    • I've been hunting info on the G Series II - this is best I have found so far(Link below). Still waiting on the G35-1150 comp map, kind of very keen   So how do we go about getting precision on that little table of yours ?   https://turbosbytm.com/sites/default/files/product/technical-info/Garrett-G-Series-II-Product_Flyer 25 30 35_1.pdf
