Full-Race Geoff Posted January 13, 2020 Share Posted January 13, 2020 trust me you arent alone... in early november I had the conversation that the one site is getting updates and they did not realize it, in fact they were using turbos.bwauto.com unfortunately this type of confusion can happen when there are 12,000+ employees spread across the planet with IT in germany, engineering in north Carolina, Corporate in michigan and billing somwhere else. all part of the fun & games in our automotive aftermarket industry. too big to ignore, too small to dedicate real resources to. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922780 Share on other sites More sharing options...
RB335 Posted January 14, 2020 Share Posted January 14, 2020 (edited) On 1/9/2020 at 6:59 AM, Full-Race Geoff said: +1 done this a number of times on different applications. The results are typically what you would expect, bigger AR makes more power, appears to spool identically (on the dyno). on the street it loses response Some tuners who claim this do not have enough data to work from, or a lack of understanding (or both). Backpressure and shaft speed + EGT are critical links in understanding the system. If they are disappointed in the max power result then its probably an issue with the setup or the turbo is too small. The larger inducer EFR 9280 certainly does move more air. and Peter may be pleasantly surprised with the 9280. I felt the same in many instances, but so far it appears to be delivering What data do you have and what tests have you done with a 9280? Edited January 14, 2020 by RB335 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922814 Share on other sites More sharing options...
Full-Race Geoff Posted January 14, 2020 Share Posted January 14, 2020 the best 9280 back to backs against 9180 were WTAC builds from scott kuhner at Emtron / Insight. 3 cars, all the same turbo, shaft speed went down, airflow went up, backpressure did not get worse Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922815 Share on other sites More sharing options...
usmair Posted January 14, 2020 Share Posted January 14, 2020 RB30 + 9180 + Sequential 955bhp ... must be engine hp as he has 1000cc injectors and one pump so that implies 98 fuel... surely not atw right? Goes hard but doesn't seem to be that much faster than mine These guys do some silly stuff on public roads 2 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922824 Share on other sites More sharing options...
r32-25t Posted January 14, 2020 Share Posted January 14, 2020 It’s an American dyno, they make 500 with stock turbos and injectors 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922825 Share on other sites More sharing options...
usmair Posted January 14, 2020 Share Posted January 14, 2020 8 minutes ago, r32-25t said: It’s an American dyno, they make 500 with stock turbos and injectors In UK, they using American setting too? Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922826 Share on other sites More sharing options...
r32-25t Posted January 14, 2020 Share Posted January 14, 2020 I didn’t watch the video I just assumed, uk dyno their cars at the wheels then make up some number that it makes at the fly wheel usually in lots of 50s and use that number to state what power it makes 3 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922827 Share on other sites More sharing options...
Butters Posted January 16, 2020 Share Posted January 16, 2020 Seems very quite for a hollinger ? Bored out to 3L ... ammmm Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922951 Share on other sites More sharing options...
Lithium Posted January 16, 2020 Share Posted January 16, 2020 On 15/01/2020 at 12:45 PM, r32-25t said: I didn’t watch the video I just assumed, uk dyno their cars at the wheels then make up some number that it makes at the fly wheel usually in lots of 50s and use that number to state what power it makes ... they also rip on US dynos for "reading high" yet come out with stuff like this, claiming 800+hp from setups which just can't make that kind of power - then post times which don't match the power and make a bunch of excuses. I remember when they had a couple of serious drag Skyline builds where they were making big power claims but not running as quick as lads down under they even went so far as to claim the drag strips were downhill here and if they ran here they'd be faster lol Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922959 Share on other sites More sharing options...
fatz Posted January 16, 2020 Share Posted January 16, 2020 955hp f**k yea my r33 has that much power the n Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922960 Share on other sites More sharing options...
Full-Race Geoff Posted January 17, 2020 Share Posted January 17, 2020 people also think dyno #s = drag times. but fail to realize that gearing, chassis, tire setup, track prep and launch specifics matter quite a lot... Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7922998 Share on other sites More sharing options...
Nismo 3.2ish Posted January 17, 2020 Share Posted January 17, 2020 22 hours ago, fatz said: 955hp f**k yea my r33 has that much power the n What fuel do you run at 955hp Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923001 Share on other sites More sharing options...
GTSBoy Posted January 17, 2020 Share Posted January 17, 2020 1 hour ago, Nismo 3.2ish said: What fuel do you run at 955hp Is that a trick question? Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923003 Share on other sites More sharing options...
Nismo 3.2ish Posted January 17, 2020 Share Posted January 17, 2020 45 minutes ago, GTSBoy said: Is that a trick question? No , you have a bloke saying he has 955hp car in the UK on 98 Fatz said he has the same , I asked, on what fuel ? I think 955hp on 98 with the UK setup is BS?♂️ But I am asking FATZ , a bloke with much more knowledge than I have a question The only way to learn anything is ask questions, I work on the assumption that “ there are no stupid questions, just stupid answers” Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923004 Share on other sites More sharing options...
Ben C34 Posted January 17, 2020 Share Posted January 17, 2020 33 minutes ago, Nismo 3.2ish said: No , you have a bloke saying he has 955hp car in the UK on 98 Fatz said he has the same , I asked, on what fuel ? I think 955hp on 98 with the UK setup is BS?♂️ But I am asking FATZ , a bloke with much more knowledge than I have a question The only way to learn anything is ask questions, I work on the assumption that “ there are no stupid questions, just stupid answers” You have been lured in by the man's satirical comment. He does not have that many horsepowers Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923006 Share on other sites More sharing options...
fatz Posted January 17, 2020 Share Posted January 17, 2020 Yea I don’t have 950Hp more like 400rwkw but my shit heap needs two external pumps 2000cc injectors and e85 to do that shit at 21psI lol im sure if I was dumb enough to run 28psi I might have 460rwkw at which point I’ll have 950hp like mr uk... lol except my imaginary 460kw would be faster than his 950 either way internet videos make me laugh and that was a cracker... mainly cause the f**ker in the passenger seat 2 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923007 Share on other sites More sharing options...
fatz Posted January 17, 2020 Share Posted January 17, 2020 9 hours ago, Full-Race Geoff said: people also think dyno #s = drag times. but fail to realize that gearing, chassis, tire setup, track prep and launch specifics matter quite a lot... think more important would be lap times cause that typically sorts the “good” turbos from the junk but measuring that is difficult 2 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923008 Share on other sites More sharing options...
Nismo 3.2ish Posted January 18, 2020 Share Posted January 18, 2020 34 minutes ago, Ben C34 said: You have been lured in by the man's satirical comment. He does not have that many horsepowers Yeah ? ,Paul already laughed at me for believing Fatz’s Pisstake comment ?? i am old but stil gullible ?♂️? 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923011 Share on other sites More sharing options...
warin Posted January 19, 2020 Share Posted January 19, 2020 I’m pretty fresh to SAU, I used to follow Supra forum pretty hard. I’ve read through this post from 70ish onwards. Very interesting results. I have a 3L Supra with GSC S2 cams (272ish), GSC Beehive springs, stainless valves, 9.5:1, all the good gear inside. Bottom end is for 1500hp. ive has big turbos and want this next iteration to be a great street car. I’m thinking the 8474 with a progressive 400shot at the drags. Looking at Matchbot, the turbo is too small for the engine, then using logic my goals are a responsive turbo, so I guess that fits. My question is, will the 9280 be a responsive turbo On the 2JZ or is it a turbo more spec’d for racing where you can swap a cog or drag racing. I can’t find any 2JZ’s with the 8474... mostly they go Precision. I saw the 8374, which had a nice boost curve. comments welcome... Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923067 Share on other sites More sharing options...
Lithium Posted January 20, 2020 Share Posted January 20, 2020 (edited) On 20/01/2020 at 10:14 AM, warin said: I have a 3L Supra with GSC S2 cams (272ish), GSC Beehive springs, stainless valves, 9.5:1, all the good gear inside. Bottom end is for 1500hp. ive has big turbos and want this next iteration to be a great street car. I’m thinking the 8474 with a progressive 400shot at the drags. Looking at Matchbot, the turbo is too small for the engine, then using logic my goals are a responsive turbo, so I guess that fits. Hey mate, sounds like a fun build Some pretty ambiguous or open to opinion comments in there so some background on what you've had and where you're coming from would help. Your previous "big turbos" you've had, what are they are what kind of power have you made with them? Is this the same engine spec as you used with them? It'd be good to quantify what an acceptably responsive turbo would be for you, and what "too small" means - as an EFR8474 should be fine on a 3litre depending on how much work you're expecting it to do. What is the pre-nitrous power target? Also, a 400 shot of nitrous - I see you like to party. You may need to be very sure you have enough hotside to support the inevitable exhaust gas flow which is going to result from this combo Edited January 20, 2020 by Lithium Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/120/#findComment-7923132 Share on other sites More sharing options...
