8 minutes ago, Dose Pipe Sutututu said:
At least I drive mine, unlike your hoist queen.
How do you know how much I drive my car?
In fact I bet its been driven more than yours between engine breaks and builds.
and 0 times on the track.
At least I gave it a go, thrash the shit out of it at a few events and killed it. Now it's going to a proper shop to be built.
Anyhow, ignore list you go.
Dose, a proper shop? Before you claimed your engine was NASA spec and led everyone to believe you reinvented the wheel, when in reality you blew the motor due to your bicentric throttle control and the lead weight you have for a foot. Limiter bashing is for Honda drivers m8... it’d make more sense if you put a B18C in given the 100kw might just cope with your driving style
18 minutes ago, GTSBoy said:
Nah, just unlock the original and merge threads.
This!  I was gutted when the trolling started in my original thread which ended up with it being locked, now there is near 12 years of quantity over quality to browse on the topic - I'd take an obscene bit of pride in starting the longest running technical handbag fight on the interwebs!
Edited by Lithium
  • Like 1
  • Haha 1
Lithium, the only people that seem to bicker & moan are the people that "DON'T" run EFR turbos.
The blockheads that have never used an EFR are the ones that have busted a sewer main in this thread. They just can't seem to stick within their oil spewing Precisions & big bubba Garretts threads
I don't fully agree, sadly.  And given I'm the one that started going on about these turbos ~12 years ago its hardly that I'm biased haha.  There has been some pretty good conversation for, against and about from one side or another and it is still fairly frustrating that the conversation has been going for 12 years and there is still pretty f**k all data on them.   I don't blame people for having doubts.
  • Like 2
anyone know what angle the turbo can sit at? the max angle im trying to aim the ass end down as much as possible on my wrx build.
But its pretty steep and I don't want it smoking. I know the garrets are only good for 15 deg, does anyone know what the EFR is?
I think the only available guidance is from gut feel.
If the bearings were hydrodynamic bushes, I would suggest that there would be only a very small angle that could be tolerated. Hydrodynamic bearings offer no axial location at all and would allow the weight of the rotating assembly to float downhill and the thrust bearings would be carrying that load all the time. That would likely be counter to the design intent of the thrusts.
If the bearings were ball bearings (and EFRs are, right?), then things are probably a bit different. A ball bearing will offer some axial load carrying capability when placed on an axial angle. The rolling elements will work up against the side of the race. The manufacturers of all such bearings do provide some information on what's acceptable in that regard. So whilst BW might not have said anything, it might be possible to infer what the limits are from inspection of typical similar rolling element bearing datasheets.
Even without finding real values, the gut feel engineer in me says that you probably wouldn't want to be running higher angles than around 15°. That seems to be enough to me to make the rolling elements displace away from the centreline of the race. That gut feel may be just too damned conservative. For all I know they could be fine working at 30+°.
This SKF chart shows that single row roller balls can work at light axial loads up to angles a bit higher than 30°. After that you need to use more special bearings or arrangements. I don't think that paired (ie, two separate single race ball bearings) would change that except that obviously every extra bearing you add reduces the axial load carried by each bearing.
So, my non-scienticious gut feel is to stay below 30°, and well below if possible.
    • A 180SX has a much better look than a FD. The roofline is far superior being a fastback. It's popups look better. In a world where we all subconsciously add a little bit of low, and wheels of our preference, it's just more handsome than the FD is. The FD just looks 'bubbly' in comparison. It can come down to preference, sure. But "The FD is the BEST looking (on appearances alone) 90's JDM car without question?" Nah. Plenty of questions lol. I could think of 8 cars I think look fundamentally better, and probably a handful of ones that look about on par with a FD. (like say a SW20 MR2) I feel people like/overrate the FD because of it's mythicality/rarity, its rotary and it's unpredictable nature. It probably drives great, you can stuff a ton of tyre under there, has a unique sound, light as hell. I feel that people reading this thinking "YOU CANT RATE A 180 ABOVE A FD BECAUSE A 180 IS A CHEAP DRIFT BUCKET" prove the point about bias as to what the car represents, moreso than how it actually looks.. And this thread is purely about looks :p
    • A red or yellow S15 wins my vote, Ack that it just scraps in with the 90's cars theme, but they are great looking little sports car Next would be a A80 Supra (pre face lift), whilst the A80 has its own issues, I feel is the best looking larger GT car As for the FD, "I" feel that the reason it triggers me in a non-positve way when looking at one, is like looking at a high maintenance pretty girl who you know is mentally unstable and likely to explode for no apparent reason
    • Yes, it's because it has hips and bulges on the top/front surface, a tiny cockpit and roof, and the skin looks like it is stretched over muscle. The proportions are....perfect. Long nose, short rear, short roof. What's not to like? It continues the theme started with the S1, that peaked with the FC, being "looking like a front engined Porsche", while gaining a little more of the 60's Mustang coupe profile and stretching the skin more tightly over the understructure. The FD is definitely colour sensitive though. Like all Mazdas. There are plenty of details on it that changed over the years that were either better or worse, could have been done better the first time and/or never changed for the worse. But...the same can be said for the NSX. In fact, that's probably even more true for the NSX. I've also just worked out that part of the reason I don't like the rear of the NSX is that the integrated wing is too similar to that shitful R33 rear wing.
    • I wonder if people like the FD because it reminds them of old 60's roadsters and such. It just gives me such a 'roadster/soft cruising' vibe as opposed to anything more hard-edged and purposeful. That, mixed with 90's melted soap bar styling. It's hardly ugly, but it's kinda oddly proportioned to me, relative to about 10 other cars I had a think about based on this thread.
    • Well, unless you are prepared to do it yourself, or to pay someone for a lot of labour, you don't want to move the rear camber around much at all. Close to stock length on the rear upper arms (both the RUCAs and the tension arms) will minimise the addition of bump steer. That means you should probably be satisifed with whatever neg camber you end up with as a result of it being lowered, and not try to dial too much of it out. Dialling it out by making big changes to the RUCA length will require effort put into tuning the length of the tension arms. And, apart from front caster and toe at both ends.....that's all there is to talk about. So, yes, toe settings, pretty much.
