56 minutes ago, fatz said:
That’s American horses remember so achievable
your sneaky edit makes this post sound dumb
Whats sneaky about saying,  wrong info , I can admit it better than some :223_speak_no_evil:
7 minutes ago, RICE RACING said:
Let's see when the kunts show the performance  ;)
Everyone prefaces 50 different excuses as to why it wont do XYZ, typical of the times we live in now in Generation GAY.
Odds are it'll do what they expected from it, there will potentially be some interesting data to come from it for those who appreciate that kind of thing, and there will always be keyboard warriors who find something to hate on - typical of the times.
I'll post in here if or when there is any more news.
Don't expect much from vendor paid advertising ;)
My 8474 turned up on friday from Turbosource but of course I'm away for work for the next few weeks and have a huge list of crap to finish off on the Car before ill have any data but rice you should be happy as i will have a pretty reasonable amount. (egts, map, emap, etc all from the KV8) Anyway...big list 1.Finish fab of hotside piping to cooler 2.Drill housing for emap and run tubing etc 3.Plumb everything (coolant, oil/OPR, gates) 4.Send housing, dump, gate bodies and screamer pipes for coating 5.Purchase and fit thermocouples 6.Wire in ETC 4 x2off for egts( 3rd party coz f wiring) 7.Lick a stamp and send it
Good stuff  ^ :)
On the other end of the scale did an EFR7064 the other day on a 1.8lt (460rwhp on homodynamics roller) but running car weight is 700kg region and small frontal area means it runs rings around anything else :). And doing twin EFR on R35 next, all of them fully instrumented ;)
  • Like 1
Hey Rice, (apologies Ive not caught your name) Considering my manifold is a true split pulse and the housing is also split pulse which side of the housing should i be drilling and tapping to take the emap reading from? Surely thered be a small difference between the smaller scroll and the larger scroll pressure wise when spooling the turbo?
Awesome! What is the rest of the mechanical setup you are running? What hotside did you go for?  Looking forward to hearing result :)
  • Like 1
True Split pulse 6boost manifold with twin 40mm TS gates external and indvidual egt's. I fabbed my own 4" SS exhaust with a "Hi-flow" cat and 2 off Magnaflow mufflers along with all the 3" intercooler piping. Changed from a old 68mm PWR cooler to a CPC 90mm 600x300mm core. (was hard to bring myself to weld to the billet end tanks). Its a basic 2.6 build. eagle rods, CP pistons, actually i need to check when i get home if it has main studs and Head studs... lol fingers crossed. Im thinking the head is gonna be the big restriction. (tomei 260 9.15 cams) Edited as i forgot the gate info
Edited by welshy_32ZILA
  • Like 1
Awesome, has potential!  Sounds like a very nice setup...  If you are going to run E85 and aren't shy of boost then it should be capable of some solid numbers still I'm guessing.   So what hotside on the turbo, 1.05?
Edited by Lithium
Yea e85 and 1.05 split on the rear. Im guessing the boost may start with a 3. but Between the head, and the inj being at 65/70ish% duty with the -5s id say they may temporarily hold us back aswell.
Are you on 1300s or something?  That won't quite cut it :D     Should still be able to make plenty of power to be a very fun ride
Nah they're bosch motorsport 1650s. I checked logs from the emtron and are seeing 76% @ 280kpa. We were leaning on the -5s pretty hard.
Interesting burn. This was only showing 380hp but dynos ya know. Seat of pants dyno said it was making more... Will talk to Sean in regards to inj, might just change em early to prevent the mess around later.
Yo, it's Peter ;)
I mount them anywhere (in the exhaust manifold) as the averaged TIP is basically equal, Don't know if ECU specific but some I see run what must be accumulators to filter the signals? Don't need this on Life Racing based ECU you can see we just run a pipe to a conventional pressure transducer (nothing special) have many in service no issues.
29 minutes ago, RICE RACING said:
Yo, it's Peter ;)
Cheers Peter.
Ok so u run them in the manifold itlself. Even my manifold is split so the pressure reading wpuld be only from 3 cyl.
Yea I see most run an accumulator/filter setup to smooth the small pressure rises from the cycling/firing of each cylinder. And obviously filter to prevent exhaust soot clogging the sensor.
12 hours ago, burn4005 said:
Interesting. I was at 76.5% duty on same injectors on e85 at 285kpa on an 8374 1.05. That was a 491awkw run on a 2.62l
lambda of 0.8 though.
Quite interesting looking at it all there, his target lambda is arguably on the rich side - and he's ~5% rich of that target (ie, it's running 10.7:1 "gas scale" AFR).  It could be that rich of target due to the fact he is running at part throttle at that long point, but at face value if he was running your lambda at the same MAP he'd be <70% duty at this point which isn't so bad.
Also, those Bosch injectors are "1650cc @ 4bar" while the target differential pressure appears to be 3.2bar, and it's around 3.1bar at that time spot.   One way or another, there should be room for AT LEAST 10% more power with that fuel system which isn't all bad :)
Edited by Lithium
heres a run of mine during the tuning process for comparisons sake:
we didn't have the pump PWM speed control map set up correctly for a flat fuel pressure, and base pressure was a bit low. closed loop fuel was bang on the lambda target regardless (+4.5% fuel enrichment and -3.5% closed loop lambda enrichment. this run was at E75, but in my tune anything over E70 is full boost, full timing.
I've been trying to get emtron to fix the fuel rate calculation speed as it's quite a useful runtime for fuel demand, but for some reason its refreshing very slowly in the log.
Edited by burn4005
    • A lot of what you said there are fair observations and part of why I made that list, to make some of these things (like no advantage between the GSeries and GSeries II at PR2.4 in a lot of cases) however I'm not fully convinced by other comments.  One thing to bare in mind is that compressor flow maps are talking about MASS flow, in terms of the compressor side you shouldn't end up running more or less airflow vs another compressor map for the same advertised flow if all external environmental conditions are equivalent if the compressor efficiency is lower as that advertised mass flow takes that into consideration.   Once the intercooler becomes involved the in-plenum air temperature shouldn't be that different, either... the main thing that is likely to affect the end power is the final exhaust manifold pressure - which *WILL* go up when you run out of compressor efficiency when you run off the map earlier on the original G-Series versus G-Series II as you need to keep the gate shut to achieve similar airflow.    Also, how do you figure response based off surge line?  I've seen people claim that as an absolute fact before but am pretty sure I've seen compressors with worse surge lines actually "stand up" faster (and ironically be more likely to surge), I'm not super convinced - it's really a thing we won't easily be able to determine until people start using them.     There are some things on the maps that actually make me wonder if there is a chance that they may respond no worse... if not BETTER?!  which brings me to your next point... Why G2 have lower max rpm?  Really good question and I've been wondering about this too.  The maximum speed *AND* the compressor maps both look like what I'd normally expect if Garrett had extended the exducers out, but they claim the same inducer and exducer size for the whole range.   If you compare the speed lines between any G and G2 version the G2 speed lines support higher flow for the same compressor speed, kinda giving a pretty clear "better at pumping more air for the same speed" impression. Presumably the exducer includes any extended tip design instead of just the backplate, but nonetheless I'd love to see good pics/measurements of the G2 compressors as everything kinda points to something different about the exducer - specifically that it must be further out from the centerline, which means a lower rpm for the same max tip speed and often also results in higher pressure ratio efficiency, narrower maps, and often actually can result in better spool vs a smaller exducer for the same inducer size... no doubt partly due to the above phenomenon of needing less turbine speed to achieve the same airflow when using a smaller trim. Not sure if this is just camera angle or what, but this kinda looks interesting on the G35 990 compressor tips: Very interested to see what happens when people start testing these, and if we start getting more details about what's different.
