12 hours ago, Lithium said:
Quite interesting looking at it all there, his target lambda is arguably on the rich side - and he's ~5% rich of that target (ie, it's running 10.7:1 "gas scale" AFR).  It could be that rich of target due to the fact he is running at part throttle at that long point, but at face value if he was running your lambda at the same MAP he'd be <70% duty at this point which isn't so bad.
Also, those Bosch injectors are "1650cc @ 4bar" while the target differential pressure appears to be 3.2bar, and it's around 3.1bar at that time spot.   One way or another, there should be room for AT LEAST 10% more power with that fuel system which isn't all bad :)
10% more power isn't going to be enough imo lith.
I spoke to my tuner about it being a touch richer then most.  He said that's where he runs them. I trust him and try not to question, more just understand. 1000 ways to skin a cat.
I'll order some Bosch 2200/ID2000s and fit them before it goes back. Id prefer to not be maxed at injectors and keep everything happy.
Burn, 125k rpm shaft speed. I like it. I'm still new to reading data so I may have a question once I get a chance to have a good look at your ss.
It's a little known art form (internet age) to run more excess fuel and correct spark advance. Some tuna's get too carried away with BS abstract on line learning crap advice to target set fuel amounts, there is no such thing honestly.
Knock limits and thermal capacity or tolerance (pistons rings, valve seats, seals etc) is what is key, your blokes advice is sound, stick with it. All the best cars are set that way ;)
Lost count how many tests I have done in real world showing arbitrary 'Lambda targets' then doing the same with what the engine wants and always the performance is better, EGT is lower, knock is always less... fuel economy is down but no one I know gives a f7ck about that :) Some are spark limited and in those applications the motor tunes you, and that is never a good thing lol.... Get proper spark (Inductive is NOT proper !) and see the light.
  • Like 2
Agreed, and I don't want my post to be taken out of context.
I was simply pointing out it the target was on the fatter side (which as you say, may be perfectly right - it's literally why I said arguably as everyone have their own approaches and views even if they tuned the same engine), and the fact that it was a bit rich of target - even if ~3% is SFA.   When you factor that in along with the fact that while he is running ~3.2psid the Bosch 1650cc injectors are actually rated to their advertised 1650cc/min at 4bar psid  (compared to ID1700+ which flow ~2000cc/min at 4bar) and the fact he has a good few % of duty cycle to play with still means even with the same target mixture there is possibly a bit of moving room depending on how they want to approach it.
Make sense?
Fwiw I wasn't questioning his choice here, I definitely didn't mean to make it seem that way - I was just listing variables which added up to the fact that the thing may have a bit of headroom and I am sure he would be good to talk to about that to work out what a good way forward would be.   Some people have doubts about the Bosch 2000+cc injectors and ethanol use, so do your homework/talk to your tuner if you haven't already to make sure you're happy with where you go :) Surprises with fuel systems aren't fun.
Edited by Lithium
Agreed with you Lith, you need the extra capacity. Say for example you have a fuel pressure problem (been hit with a litany of these last fortnight!) what then can happen is a back ground calc will take over (dep on ECU type? code?) and manually and much more quickly than relying on a feedback loop from a Lambda sensor OR covers situations where those are/cant be relied upon say on action of limiters be that tr or traction or some other ...... you then NEED to have this margin, if you injectors are maxed out or even not enough extra capacity built in you wont be able to control what happens inside your engine, despite your paper/internet page 'engine protections' lol :)
Pressure (fluid) sensors act very fast much faster than a feedback through any exhaust gas measurement, just a tip for young players.
Like running 4bar then seeing 1.7bar in the fuel rail, will your motor still be running? :) It can and does happen what is good/great these days is with the right systems + design + execution you no longer need to "take the engine out" when it finally catches up with you ;)
The only engines I've tuned which have been hurt have been hurt by things which anything the ECU sees or controls would not have been able to do anything to warn for or protect against, and plenty have had fuel pressure issues - among other things.  It is amusing how often people get frustrated at what your protection strategies have done... until the topic of what would have happened if their hard lap wasn't disrupted by a big reduction in power/rev range.  IE, the same kind of disruption to their session but more things to fix.
Edit: Just remembered you seem to assume the worst when other people are involved... I'm not quite up to making a tune which will protect against valvetrain failures.
Edited by Lithium
  • Like 1
I think the issue is these companies who make those offerings in the majority DO NOT race at professional levels....... thus the strategies are lacking, let alone the kunts who set them up ;) its comical listening/reading to some of the total crap on GagTube/Arsebook honestly.
Make sense?
No probs lith, nothing taken to heart here, you were on the money,  the other reason why it was a touch fatter which I had forgotten until digging into inj was that the injectors had 8/9% variance.
Just a couple of pretty switch on ppl and and  a gumby (me) discussing things.
That's interesting about the BM 1650 compared to the ID 1700. Will definitely be doing a bit more research about the injectors but after reading a bit more I'm leaning towards the Ids2000s but I may need to rob a bank to pay for them ? If you guys hear of any banks being robbed ot wasnt me ok ?
  • 3 weeks later...
DO NOT USE ID2000's!!!!!!
  • Like 1
They are an older style gas injector and eventually fail when on an ethanol car
Oh boy. That's not brilliant. Next your going to tell me they fail catastrophically and the car pretends it's a Ferarri?
Time to start learning all about injectors I think. [emoji848]
I don't have these problems with the wife's car. [emoji23]
    • They do. The pale yellow translucent ones from Japan were .... I dunno. Useless? Whiteline and SuperPro are probably fairly similar. There's bound to be a range of different hardnesses amongst the dozens of options on the market. The simple fact is that the pineapples don't get up inside the bush at all. They just sort of exist in the space between the washer/bracket and the subframe's bush outer tube, and...exert a bit of force between them? Or something like that. I'm sure that with enough provocation, they will simply allow one to more wrt the other.
    • I'm not sure they came in different hardnesses? Going from memory only - I had set them up in the balanced setup. I also have poly bushes, so I have both poly bushes and pineapples. This is what my memory tells me at least. I'll have to take a look under there to be sure. The tramp was so bad that I managed to eject/kill a diff bushing, so those I know are stock. The tramp is bad enough that you are 200% sure you are doing severe damage to the car. It's not just chirping or vibration, it feels like you're hitting a speed hump/kerb 10 times a second. The issue has persisted between subframes! (I went from Hicas to non hicas subframe and replaced every bush a few years ago now) so I'm entirely lost. Every arm is factory.
    • Can recommend the Frenchys kit, been using it 2 years now with no issue, very happy with it.  Only thing for me was upgrading the thermo fan but I am super fussy on cooling.   Also interested in electric AC, partly for boot mount to have a clean bay and partly would love the idea of cooling off the car before i get in. The battery setup to do that might be tricky / expensive though.  Found this an interesting watch.
    • I put Whiteline pineapples in my old 33, they came in a 6 pack of them, got rid of the axle tramp altogether, cheap, quick and easy install,  they were pretty solid units though...???high durometer???? and NVH was increased a fair bit How hard are the ones you installed?
    • I'd suggest the answer to the first question is at least a qualified "yes". I'll come back to that. Pineapples just don't do a lot to solidify the mounting of the subframe. They do a little bit, and that little bit was clearly helpful to me in the past, but the main thing they are intended to be used for is to tip the orientation of the subframe to try to either dial in more or less anti-squat. You can install them one way to try to increase launch traction, or the other way to try to increase lateral grip (at the notional expense of longitudinal traction). Or, as I did, you install them neutral, which only really offers a little bit of "snugging" up of the subframe. When I did pineapples, that was the only option. No-one had a machined alloy collar like the GKTech ones. There were some other options, but nothing like the slip in collars. And it is clear from looking at them that they occupy almost all the free space inside the rubber bush, so they will do a lot to stop them moving internally. So I thought, "that's the game for me!". Obviously the next/adjacent step is poly bushes, but what's the point in doing that with all the work and hassle required to change them over, when jamming (and I mean literally jamming) some alloy into the rubber bushes probably gives an equivalent, or possibly even superior result? So, to go back to your 1st question, I would suggest, for the investment of <<$100 and a morning spent lying under the car swearing and getting some sore fingers, it is certainly something you should try. Who knows? Maybe your situation is so severe that it doesn't solve it. But it might help a lot. If your problem is as severe as you say it is, the next thing to look at is what the rest of the bushes in the rear end are made from. Things like the Hardrace arms with hardened rubber bushes might be a good thing (for the purposes of having adjustability AND stiffer bushes). Otherwise, just poly bushes throughout could be a help. Or following in my fever dream footsteps and putting a lot of sphericals into the rear? Eliminate undersired movement to avoid the build up of resonances that cause the tramp. Also, if you have adjustable uppers in the rear, and you haven't put effort into adjusting the traction arms to minimise bump steer, there might be some advantage in that. If you don't want to go to the effort of doing it yourself (like I am pretty much forced to in Adelaide, owing to a lack of race alignment specialists) then surely there's a place in Melbs that is able to do it. It will cost $$, But that's life.
