50 minutes ago, Nosure said:
Hi. Will fit on a fully build rb28 with cnc head 280 cams etc.
turbo is here today. New exhaust setup should be done in 3 weeks time.
:worship:
I like it.  Very cool, look forward to seeing how this comes together - sending it on E85?  Please post results when it's done :)
1 hour ago, Lithium said:
:worship:
Yes mate. E85 full time.  The 1.45 housing look huge.  Hope I choose the right housing:)
That that size cams, engine and compressor you obviously want to party - so that turbine housing will be well justified I suspect :) What kind of power and power delivery were you looking for?
Fwiw I've been in a GTR running an RB28 with a 1.45 EFR8374 and it was surprisingly punchy, the 280deg cams will probably soften it up a bit down low but I suspect it'll still have a hearty power delivery - so long as the black series 68mm compressor doesn't come at too much cost in spool.  I suspect it should prove to be a pretty rewarding power delivery
What I see is the compressor flow increase 20% might need bigger rear housing to max out the turbo.  1.05 is small even for 8374 in my eye.
Agreed, the 1.05 can work ok on EFR8374s depending on the setup but I wouldn't use it on an EFR8474 on a 2.8 with a good head.  It sounds like a good combo from all I can tell.  Looking forward to seeing how it comes out :)
Edited by Lithium
On 26/06/2019 at 5:59 PM, Deano 1 said:
Closed/ Secret FB group, I assume it's a GTR for sale. And I didn't think cross posting to for sale ads was allowed?
That isnt a terribly hard question to answer if you know what is max engine RPM?  a 2.8L engine revving to 8500rpm @40psi boost, will produce 1000+hp at the limit of the compressor map.  Speed sensor mandatory.
The 80mm turbine in 1.45 a/r will see 11-13psi backpressure so its really a question of why do you need 1000hp and is this really the right way to get there?
10 hours ago, Deano 1 said:
will the 9280 make 1000hp atw on a 2.8 with everything needed to make 1000hp...... that is the question.
Depends on how harsh the dyno is etc, the compressor flow is there for well >1000hp @ crank on E85 but the question with the EFR range has often been if the exhaust side is up to it given people already run into EMAP issues with the EFR9180.. granted it's hard to know how much that's just due to people running out of compressor on them
  • Haha 1
People really like round numbers don't they.. My car did 495kw at absolute max turbo speed and everyone always asks why I didn't go one psi more to break the half ton.
If you need a round number in your life set the Dyno to metric and aim for 700kw instead of 1000hp.
People forget that tuners pull a degree or two of global out when they unstrap the car anyway.
Edited by burn4005
  • Like 1
  • Thanks 1
I might be in the right mood for this, but I love so much about this comment.
1000hp is such a random made up number, like I understand the bragging rights but seriously.  If you get an EFR9280 on a strong RB28, and tune it until you hit around 117,000rpm shaft speed then who gives a crap what the dyno says - that is going to be a FAST car.   Pick a bunch of parts which work well together and build, tune until it's sent and go forth and enjoy... that is the way to get a happiest result.  The reality is those other numbers become academic in the end and sometimes result in people making compromises trying to hit a target which is academic and realistically you will make different power on different days or different situations depending on what various aspects of the tune kick in and compensate for whatever may be going on at the time, as you get ESPECIALLY on big high strain setups.
A specific power number which can mean different things on different dynos and even days, or setups is not worth making compromises on imho.
  • Like 1
    • Doing a refresh of my 33 and can see a few websites stating they sell the entire main carpet for our cars, but they all have generic photos which is fine, i understand they are custom made to order.  Just seeing if anyone has got it done or had any experience with this, as i would only want to do it if the fit and finish was as good as oem https://carmatsdirect.com.au/products/moulded-carpet-or-vinyl-for-nissan-skyline-r33-1993-1998-coupe https://knoxautocarpets.com.au/moulded-carpets/nissan/skyline/skyline-r-33-1993-1998/
    • Any plans for E85? If so, add flex fuel sensor.   I'd probably add in the sensors I mentioned above if the Link will support using them for engine protection. With water pressure, you need to be able to effectively set it that "If temp > X, and pressure = atmospheric, shutdown" as at running temp, you should be able to read pressure in the cooling system. If pressure suddenly disappears, it means the water went some where, and this is a quicker reaction than waiting on water temp to go up (Which, can take a little longer than you'd like, considering it now has to wait for hot air to heat it up) Oil pressure, Oil temp, both would be on my list too if you're looking to add sensors. Wideband O2. And at least one EGT sensor. If you're feeling deluxe, put in individual runner EGTs. Single EGT sensor is more so forget about a specific number, get used to "What is normal EGTs", and then keep an eye on it, if it starts going away from "normal" it's a sign something is wrong (Also, things like the tune can still start going out of spec, but EGTs may not show it, for example one injector starts running leaning, so ECU richens everything up, now 5 out of 6 cylinders are rich, and running cool, with one cylinder lean and running hotter, so it's not perfect) Then there is your other things to look at non sensor related, but you may have already done, or have underway, and that would be things like building a sump for more oil, and better oil control under high G-Forces (Cornering, brakes, acceleration). Basically, the above is worth looking/thinking about, if the ECU can do protective stuff with it, and you continue to use it how you are (Drive it to the track, thrash it, drive home, repeat once every 3 to 4 months)
    • Can also confirm these work a treat for most balljoints and bushes. If you have access to a big rattle gun, they make the job so much easier and quicker, compared to using a socket wrench or shifter on the c-clamp 👍
    • Its sort of street but got used for circuit sprints on account of I never drive it on the road because I dont have the time to spare. So it usage was sits around for months at a time then gets driven either 50 or 250 kms to the track followed by 20 laps followed by 50 or 250kms home followed by stuck in the shed until next time. So yeah neither fish nor fowl. Just dont want to break it on the track as a preference. Hence the fairly short sensor/mod list. Probably more worried about it pinging itself to destruction more so than anything oil related.
    • My thing I'd be doing, is pulling it out, and just getting the tune cleaned up for now. Before that even happens, checking over everything, like vac hoses, fuel hoses, etc. No point dropping thousands on sensors if the moment you start it back up all the oil leaks out, or it has massive vacuum leaks etc.   But really, to know what to do, depends on what your use case is. Hard core track car? Throw most sensors available at it. Street car, I'd probably just run oil pressure, oil temps, water pressure, water temp, probably fuel pressure too. I don't know exactly what the Link can handle and do with those though. And if it's mainly just to cruise the streets, rather than mountain runs, you can probably skip most of the above if you've already got them in as gauges and warning lights.   PS, inb4 "sell it and buy a modern sportscar"
