burn4005 Posted May 23, 2020 Share Posted May 23, 2020 8374,8474,9180,9280 are all identical turbos as far as external dimensions go. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7931543 Share on other sites More sharing options...
Lithium Posted May 25, 2020 Share Posted May 25, 2020 On 24/05/2020 at 3:45 AM, RB335 said: Making 50% of max power by 4500, that's amazing. Tempting me to switch from my 8474 to twin 6258s Is anybody able to take measurements of the EFR9280 compressor, I'm seeing if I have enough clearance on my engine to run and test it compared to the 9180 which I have on me which fit fine on a 6boost T4 in a R33 GTR engine bay I don't think it's that shocking on an RB30, it's good but it's not unheard of at all. I think if you get the EFR8474 running on a good (/similar) RB30 setup you'd not be left feeling disappointed. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7931693 Share on other sites More sharing options...
Mick_o Posted May 26, 2020 Share Posted May 26, 2020 THAT! ^^^^ Not trying to take anything away from that result as it's no doubt a f**king fast car! BUT an 8474 or above will go toe to toe with that all day. Particularly down low /midrange power. 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7931730 Share on other sites More sharing options...
meX Posted May 30, 2020 Share Posted May 30, 2020 (edited) I'm gonna change my setup now. The PT6466 System is going for sale because I'm looking for a different driving style. Will try the EFR 7670 with a 1.05 EWG and a 6 boost manifold with 2x40mm wastegates and im curious to see what it's gonna be. Aim is to come close to 550 engine horses on 100 octan. Hope it brings some fresh wind Edited May 30, 2020 by meX Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932026 Share on other sites More sharing options...
R32 TT Posted June 1, 2020 Share Posted June 1, 2020 Question! Who has used a TurboSmart replacement BOV that fits in the OEM position? And if so has anyone actually noted a difference? There appears to be a suggestion the factory one may leak - but I don't know if that's true or not. I don't see how I can measure either - so the only way to find out is replace and see (which is an expensive experiment if it does nothing) And Turbosmart appear to offer two variants: https://turbosource.com/products/turbosmart-kompact-shortie-plumb-back-efr-bov-upgrade https://turbosource.com/products/turbosmart-kompact-shortie-dual-port-efr-bov-upgrade Any feedback ? Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932082 Share on other sites More sharing options...
GTSBoy Posted June 1, 2020 Share Posted June 1, 2020 1 hour ago, R32 TT said: There appears to be a suggestion the factory one may leak - but I don't know if that's true or not. I don't see how I can measure either You can test if the factory one is opening under boost by simply blocking it off with a coke can gasket. You're not looking for the differences anywhere except when making boost. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932095 Share on other sites More sharing options...
taijohnsen Posted June 1, 2020 Share Posted June 1, 2020 2 hours ago, R32 TT said: Question! Who has used a TurboSmart replacement BOV that fits in the OEM position? And if so has anyone actually noted a difference? There appears to be a suggestion the factory one may leak - but I don't know if that's true or not. I don't see how I can measure either - so the only way to find out is replace and see (which is an expensive experiment if it does nothing) And Turbosmart appear to offer two variants: https://turbosource.com/products/turbosmart-kompact-shortie-plumb-back-efr-bov-upgrade https://turbosource.com/products/turbosmart-kompact-shortie-dual-port-efr-bov-upgrade Any feedback ? I had the dual port turbosmart bov on my 7163 to help with compressor surge on throttle lift off. No longer an issue with the 8374, so if you'd like a cheaper 2nd hand one let me know. The other main difference is adjustable spring tension for the given vacuum of the engine. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932100 Share on other sites More sharing options...
sneakey pete Posted June 1, 2020 Share Posted June 1, 2020 11 hours ago, GTSBoy said: You can test if the factory one is opening under boost by simply blocking it off with a coke can gasket. You're not looking for the differences anywhere except when making boost. In this case by factory/OEM I think that's referring to the standard EFR integrated BOV, not the Nissan one. I don't think you can block off the EFR one with a coke can. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932114 Share on other sites More sharing options...
GTSBoy Posted June 1, 2020 Share Posted June 1, 2020 Aaaah. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932118 Share on other sites More sharing options...
GTSBoy Posted June 1, 2020 Share Posted June 1, 2020 1 hour ago, sneakey pete said: I don't think you can block off the EFR one with a coke can. But, you may be able to do something equivalent. ie, make a plug that can replace it. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932123 Share on other sites More sharing options...
sneakey pete Posted June 2, 2020 Share Posted June 2, 2020 23 hours ago, GTSBoy said: But, you may be able to do something equivalent. ie, make a plug that can replace it. indeed... https://www.turbosmart.com/product/bov-blanking-plate-for-borg-warner-efr-kkk-and-ecoboost-turbochargers/ Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932199 Share on other sites More sharing options...
GTRNUR Posted June 7, 2020 Share Posted June 7, 2020 I'm just about to get on the EFR train and get a 9280/1.45 for my RB34. Any recommendations as to where the best place is to source one? Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932548 Share on other sites More sharing options...
Mick_o Posted June 8, 2020 Share Posted June 8, 2020 22 hours ago, GTRNUR said: I'm just about to get on the EFR train and get a 9280/1.45 for my RB34. Any recommendations as to where the best place is to source one? Probably me ? Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932610 Share on other sites More sharing options...
Stixbnr32 Posted June 9, 2020 Share Posted June 9, 2020 Yo guys - will a 50mm wastegate be suited with a EFR 8374/1.05 T4? The manifold runs with 1 waste gate port split in two. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932655 Share on other sites More sharing options...
burn4005 Posted June 9, 2020 Share Posted June 9, 2020 (edited) yep i have a 6 boost with single divided outlet, 8374 1.05 on a 2.6l rb26 50mm progate, 7psi spring a 4 port mac valve. no creep above 10psi of boost. below this you are asking too much flow through the gate. the lowest boost run was with the boost solenoid unplugged from ecu. Edited June 9, 2020 by burn4005 3 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932658 Share on other sites More sharing options...
R.3.2.G.T.R Posted June 9, 2020 Share Posted June 9, 2020 56 minutes ago, burn4005 said: yep i have a 6 boost with single divided outlet, 8374 1.05 on a 2.6l rb26 50mm progate, 7psi spring a 4 port mac valve. no creep above 10psi of boost. below this you are asking too much flow through the gate. the lowest boost run was with the boost solenoid unplugged from ecu. great result, is max boost around 28psi? i have same turbo setup, except will be on 2.8 with vcam, looks like i need to step it up to 8474 at the very least Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932661 Share on other sites More sharing options...
burn4005 Posted June 9, 2020 Share Posted June 9, 2020 I would definately go a 8474. this turbo is at absolute full speed. on the 490kw trace you can see the boost drop at 7500rpm. that is the boost target dropping to stop it going over 128krpm. this is the VE calculated airflow ive overlayed over the compressor map. nothing left. this is the VE 1 Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932662 Share on other sites More sharing options...
R.3.2.G.T.R Posted June 9, 2020 Share Posted June 9, 2020 On 24/05/2020 at 1:45 AM, RB335 said: Making 50% of max power by 4500, that's amazing. Tempting me to switch from my 8474 to twin 6258s Is anybody able to take measurements of the EFR9280 compressor, I'm seeing if I have enough clearance on my engine to run and test it compared to the 9180 which I have on me which fit fine on a 6boost T4 in a R33 GTR engine bay got dyno chart, i recall you also running 2.8 with vcam Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7932663 Share on other sites More sharing options...
iruvyouskyrine Posted June 29, 2020 Share Posted June 29, 2020 EFR6758, anyone know what the thread size/pitch is on the front housing cover for the boost reference signal? I looked through the EFR turbo tech guide but couldn't find it. Need to convert it to a -3AN fitting. Thanks Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7934937 Share on other sites More sharing options...
BK Posted July 1, 2020 Share Posted July 1, 2020 Nearly all compressor cover boost ports are 1/8npt, 27tpi across BW, Garrett and Precision. Link to comment https://www.sau.com.au/forums/topic/466636-borg-warner-efr-series-turbos-v-20/page/125/#findComment-7935073 Share on other sites More sharing options...
