The new genV turbosmart twin port is probably the way to go. It has a better lower seal and a universal joint to the wastegate actuator arm. I wasn't very impressed with the first two versions (non twin port and the first twin port) but the latest one should be good. Use a low pressure spring or it'll be too sensitive.
The e-iwg cost wasn't too bad (less than the turbosmart actually), but yes, you will have to adapt it to fit and have an ecu that can drive it.
Position data is nice.
Edited by taijohnsen
I thought the supra parts were already a few hundred bucks alone?
Do you have a list of items that are needed for the e-iwg?
Can't seem to find anything useful with google.
The genV twin port is $500ish AUD and the std one is $300ish AUD. I managed to get the e-iwg landed from USA for $350 AUD.
A bit of 3D printing and a carton of beer sorted the rest.
More pics in my thread http://soarercentral.com/sc-forum/messages/263854/354587.html
Hey Tai!
Just finished reading your thread on soarercentral from start to finish.
Very nice build and a lot of cool selfmade stuff in there.
The electronic wastegate actuator is awesome, but setting it up + 3d printing parts for it is way out of my league.
Another question though:
With your latest dyno session, whats the turbo shaft speed that your speed sensor is reading at max?
Thanks and have a nice weekend!
Now that my build is finished after 2 long years being off the road I can finally contribute to this thread with my EFR results.
EFR 8374 1.05 A/R
Racepace built RB28
9:5:1 compression ratio spool pistons
Nitto I beam rods
Spool billit 2.8 stroker crankshaft
PRP engine brace
HKS step 2 valve springs
6 boost manifold
Turbosmart 60mm wastegate
Nitto oil pump
Racepace custom 3.5” dump pipe & cat
Tomei extreme titanium cat back
Plazmaman 100mm intercooler
PRP trigger kit
PRP R35 coil kit
Tomei cam gears
Haltech elite 2500
Bosch 1650cc injectors with flex fuel
Nismo front LSD
Racepace transfer case upgrade
Plus many more mods
Made 504.9kw 25psi on E85
Couldn’t be anymore happier with the result and build. Turbo feels awesome and love the responsiveness.
  • Like 3
1 hour ago, burn4005 said:
Roller speed axis should be made illegal.
What gearbox, diff ratios, rims and tyres?
I agree..    based on my own car that would be boost in at around 4100rpm I think.
But why they don't use RPM is beyond me.
Gearbox stock, diff ratio stock, rims volk GT-C 19x10.5 pirelli p zero 275 and cams are stock atm because mine are on back order. Have a set of mines super shore pro camshafts just waiting till they arrive and will get them installed. Tune has been wound back to 460kw @ 23psi while the engine is being ran in and till the cams arrive.
On 1/9/2021 at 8:44 AM, MotHot said:
Hey Tai!
Thanks MotHot,
It has been a long build, but I have enjoyed the journey for the most part :)
Sorry for the delayed response, but the tuner took a while to get back to me with the logs.
The internal power calcs of the EMtron say 350kw engine, this run was 350rwkw @ the wheels (roller)
  • Like 1
  • 3 weeks later...
Because who gives a shit about rpm.. road speed is where it counts!!! :)
Lol, all you stroker big block RB boys would realise your better served by laggy RB20s that rev to 10,000rpm with 4.6 diff :)
  • Haha 3
  • Confused 1
  • 4 weeks later...
Hello, could you guys help me choose between 8374 and 8474, both with 1.05 housings, for 2jz ge non vvti engine. Quick specs are 9.5CR, BC264 cams, sligthly ported head. The target is 650 to around 700whp with best spool and response and 7500 to maximum 7800rpm limit. Is the 8374 be enough or 8474 will be needed for those goals? Fuel will be E100. Thank you in advance!
Matchbot will tell you there is no way an 8374 should be on a 3.0L RB.
That said, I ran mine happily for some years at sub 120krpm making 650-700hp at hubs and spinning to 7000-7500rpm on both 3.0 and now Nitto 3.2.  Intake temps were ok - but it didn't want to make any more power.  It has finally let go just two weekends ago.    We had recently added launch control which may or may not have contributed (or at least shortened its life).     Everything on Matchbot says its should be overspeeding, but I've got logs to show it wasn't (unless there is an issue with what/how we are reading) - so I am not sure how this correlates to Matchbot..  perhaps the default VE figures are different enough to affect it?
I've also run an 8474 on same engine (3.2L, both 1.05 rear) and it definitely feels laggier than the 8374.  On a dyno plot its only about 200rpm later coming on, but in practice, on a rally sprint coming off 2nd gear corners, you notice the difference.  Also between gear transient response is dulled a bit.
8474 makes about 50hp at the hubs more on same boost (750hp at 23-26psi) , temps post turbo (pre intercooler) are only 10 degree cooler. And post cooler can't see a difference.  Definitely when in the mid-range revs and up you feel the extra legs it has.
So!  for me, on a 3.0-3.2L  I'd be going 8474 and altering gearing to suit what you're doing,  and keep it a bit further up the rev range.
  • Like 1
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
