Its seem silly to buy from Australia in any case.  They are made in US.  Why pay for freght to Australia, and then freight back to you.    I would get straight from US.
Try Geoff at Fullrace.com  he has been very helpful to me and should be able to get you one.  It may even get through customs a little more easily if he has sent to Bulgaria before and they've already gone through the steps.
On 09/03/2021 at 3:38 AM, R32 TT said:
That said, I ran mine happily for some years at sub 120krpm making 650-700hp at hubs and spinning to 7000-7500rpm on both 3.0 and now Nitto 3.2.  Intake temps were ok - but it didn't want to make any more power.  It has finally let go just two weekends ago.    We had recently added launch control which may or may not have contributed (or at least shortened its life).
Turbine wheel broke I suppose?
On 3/8/2021 at 9:38 PM, R32 TT said:
Matchbot will tell you there is no way an 8374 should be on a 3.0L RB... 8474 makes about 50hp at the hubs more on same boost (750hp at 23-26psi) , temps post turbo (pre intercooler) are only 10 degree cooler. And post cooler can't see a difference.  Definitely when in the mid-range revs and up you feel the extra legs it has... for me, on a 3.0-3.2L  I'd be going 8474 and altering gearing to suit what you're doing,  and keep it a bit further up the rev range.
all good advice.  the other benefit of the 8474 is it won't overspeed as willingly on a large displacement RB
On 3/12/2021 at 10:17 AM, gixer said:
What about 9174 1.05? I cant get my hands on 8474 and now i am wondering about this one.
we have 9174 in stock.  it behaves similarly to 8474.  (note: 8474 is on backorder until april)
thanks for the vote, we ship to south eastern europe without issue.  most of our customers are not in the US
19 hours ago, gixer said:
How much laggier the 9174 is from 8474?
There's a smaller difference than expected.  one reference point - Fred Aasbo (papadakis racing drift team) ran 8474 vs 9174 back to back on the same track and could not tell any difference.  Their data shows 50-150rpm later spool but the tune did not change and he still uses 8374 for the smaller track Formula Drift competition
I went from a 7163 to 8374 to 8474 to 9174 and I am glad I did, it's an incredible turbo with amazing spool.
My car is not a Skyline sorry, it's an EVO X with sleeved and built 2.16cc engine (plazmaman IC, direct port meth injection, S2 cams, sequential 6 speed etc)
8474 was twinscroll  IWG and only 0.8 A/R rear
9174 was twinscroll EWG with 1.45 A/R rear
The 8474 came onto boost way too hard and made it undrivable (like between 3.5k to 4.5k was vertical on the dyno).
The 9174 we all thought being so much bigger rear housing would be lag city but surprisingly it was about the same as the 8474 (we only changed the turbo and nothing else). I see 1.5bar (22psi) by 4,300rpm. I am not done yet, I'm increasing the downpipe and going to S3 cams (Time attack car).
Rob
  • Like 2
thats a super interesting comparison.. 0.8 to 1.45 is a pretty dramatic turbine difference to not see any transient difference.
Im guessing you had the boost response tuned to be quite soft for the 8474 that wasn't nessasary with the 9174?
interesting. which turbo do they reach for these days? the 84 or the 91 or are there tracks that they'd go one over the other?
I just looked up the dyno graph comparison, it was about 100rpm of lag difference (9174 had more lag). Both setups are always tuned the same way as in boost is as aggressive as possible. Power curve was almost identical until 5,000rpm where the 9174 started making more power all the way to redline (70whp more on a mainline). I am still running a 3" downpipe though (with exhaust cut out) and will be upgrading to 4" downpipe with cut out plus S3 cams soon.
I found a fellow in the US with same car who also went from 8474 to 9174 (small Ar to large Ar) and he told me he barely lost spool and made more power up top (this isthe reason I made the change - it's true), I guess the 1.45 A/R is a very well engineered housing.
I'm glad to hear you like the decade old 9174.  it remains a relevant turbo and due to a price discrepancy (that was never resolved) 9174 is the lowest cost EFR in the lineup.  a bargain compared to almost anything else in the same price range
1.45 a/r is a monster.  It was originally designed for Honda's Indycar 2.2L V6 engine (12k rpm rev limit).  As long as the housing is divided and there is a lot of boost at high engine speed >8500rpm then the 1.45 will work great.
*edit: Transient response will suffer, so it doesnt make sense for drift cars
Edited by Full-Race Geoff
Rob
Recall difference going from 8374 to 8474, same turbine size?
Yes, same rear housing and both were IWG at the time. To be honest, I may have had too much back pressure which was apparent when moving to the 8474. But I will never know (I don't log back pressure).
I will say I expected more from the 9174 with such a large rear housing and twin EWG. We shall see what happens after the next round.
8474 didn't deliver anything special in my application, 2.8L high comp RB26 2.8l.  WIth a 1.05 rear, compared to the 9180 it behaved very similar.  It was quite more eager to come onto power faster on full throttle in 1st and 2nd gear, but it felt so restricted as soon as you got it moving.  The 9180 didn't feel like it was choking the engine as much, overall felt much more healthy and a better match
The 9274 was the next turbo I was going to try, but it looked like it would just be an extension of the drawbacks I had with the 8474.  74mm wheel simply too restrictive to swallow all the flow the larger compressor can give.  Wasn't impressed with the 9280 from very limited testing I done
Edited by RB335
Have you fixed your exhaust that’s way too small yet?
  • Haha 1
12 minutes ago, burn4005 said:
or run a screamer. venting ~25% mass flow out a short screamer reduces your full exhaust requirements in a big way.
this is where the significantly more efficient 84 or 91mm compressors would be better over the 83mm at high mass flows. the 91mm is about 10% more efficient above 70lb/min, which corresponds to about 7% extra mass flow that can be bled out the gate due to the reduced shaft power requirement.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
    • Hello friends, i have a good friend in Canada that looking for a good condition 1993 GTR around him please if one or know someone around you that is willing to let it go please let me know so that i can inform him.....Thanks
