8 minutes ago, Butters said:
Don't think the g35-1050 will get there ?
I am pretty close(720rear) on 26psi with scope for more boost and rpm.
Very happy with the repsonse on a 2.6 with vcam, on a 3.2 it would be amazing.
800-850 is a pretty big step up from where you are, imho you'd need to go up an exhaust housing size (or two) to support the extra power - especially on a 600cc larger donk.   That's going to take a lot of steam out of the response, and while it's not going to be rubbish still... it imho will shift it outside of EFR league (well, further outside of).    So I wasn't saying it's rubbish or not a valid option, just when we're talking about an EFR8474 then imho it's definitely a step backwards.   That's because EVERYTHING is a step backwards, nothing against the G35.
Edited by Lithium
Agree on a bigger motor a bigger rear would be the go.     I do wish I had a built bottom end to throw the extra 10psi at it to see what it would do.
It's very tempting to test this out. You can get them in a vband flange turbine side which would make it near direct swap.
It wouldn't really be a valid test, my statements assume someone is running a native twin scroll housing.   Any observations I (and pretty much anyone else here) offer relating to EFRs assume twin scroll housings.  Any data for them and suggestions relating to them apply to the housings they come with.
For it to be realistic it'd have to be a typical G35 setup and typical EFR setup, matched appropriately for the car they're going to be running on.
this is what I'll be doing - G35 - 1050 with 1.01 v band rear with rb27 and 35 psi would think be around mid/high 800 hubs still think
  • Like 1
  • 1 month later...
Something else to consider with all the 9180 vs 8474 talk is that the 80mm turbine is the biggest culprit for flying out the back of the exhaust. The 74mm wheel is certainly the more "proven reliable" option. Even whilst over speeding.... But obviously if kept happy they are proven to be of OEM reliability.
Just an update. I have the 8474 on the engine now (8374 previously)
It's about 100-200rpm laggier and makes an absolute sh$t tonne more power up top. The 8374 topped out at 650rwhp at 30psi.
This 8474 is just f$c%ing dumb. At 26psi, it's making well and truly over 750rwhp and just keeps going. It doesn't fall over.
RB28 with Vcam (264/272), 6boost manifold, 3.5inch exhaust, E85, Emtron KV8 etc etc
  • Like 2
Well that's exciting news!  Can't wait to finally test mine out at some point!
Do you have a dyno chart?  Love to see her curves. 😍
16 hours ago, burn4005 said:
goddamit. now I've got to upgrade.
only question is Iron or Aluminium CHRA
I also pondered the same when ordering, but couldnt be bothered, so went iron. Mines a 9180, and its not really heavy either.
GCG said there is about 5kgs difference, and no difference in strength. I went the iron core and haven't had any issues. Wasn't heavy either. Iron would handle heat better though I would say?
I don't unfortunately, I'm just looking at the calculated HP / torque in the Emtron which is about 5-10hp within the dyno readings.
Plus, I have ID1300cc injectors running at 4bar so about ~1600cc and they were hitting 95% duty on E85. That is a dead giveaway to output.
The 8374 at 30psi was only at 82% duty.
  • Like 2
A screen shot of boost / rpm log showing where target boost is hit would probably be pretty meaningful, I've already posted dyno plots of these things pushing 800+hp to the hubs on a 3litre - the flow potential of them shouldn't really be in question at this stage, but how it comes on with an RB28 would be pretty good data to see.   There is always talk about how good these come up between gears etc, but not that much data for people and I can fully see why people develop an attitude that the enthusiasm for these turbos are just fanboism, as opposed to earned respect for being that good.
  • Like 1
Aluminium. It weighs 5kg without a turbine housing. Also Aluminium dissipates heat quicker so probably better on bearings etc. Also it won't rust and look old and Daggy like an iron core will eventually
On 01/11/2022 at 7:21 PM, Shyboy said:
That sounds exciting👍Any graph ? I should get mine back in few weeks
About time lol! How long ago was your car at my shop? 😆
Look forward to seeing it!
I also wanna hear my exhaust! 😎
I would never have bought or recommended an EFR9280 for this kind of power level (helped by the fact I've seen less impressive results from them), there is not much info on exactly how hard this one is being pushed, but I still feel like this result is worth knowing about if you hadn't already given GameOn aren't unheard of or anything.
EFR9280 on a VVTi 2JZGTE making 1130hp @ hubs with respectable spool is a solid result no matter how you cut it
https://fb.watch/gA5azNc8fg/
    • Convert to dual filament bulb   FWIW, it will look odd - I dare say a bit dumb as it looks like your flasher relay has shit the bed.
    • If the RB20 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
