On 7/12/2017 at 6:00 PM, minesskyline said:
It might be too late to ask this, but do you guys think the EFR 6758 is too big for the RB26? I'm like neck-deep in the build now, so it's probably too late to turn around, but curious what you guys think. I got them super cheap so couldn't pass them up, so this is my life now.
I'd like to check out this build. There's gonna be some sick parts to support these little guys. Do you have a build thread somewhere?
I do not have a build thread. But I could certainly make one. I'm not doing the work myself, so some details/pictures might be lacking. Let me throw a thread together some time this week and I'll let you know.
34 minutes ago, Full-Race Geoff said:
looks good!  only question is regarding the intake tubes/filters - are they 3" ?  or 2.5"
I'm not sure. I can ask. Would it make a difference and if so, what should it be?
Ok - I prefer to see 3" as the smallest diameter for the inlet.
edit:  the 2.5" will work fine, but 3" can better avoid any surge with 7163s
Edited by Full-Race Geoff
These are 6758's, if it makes a difference.
On 26/02/2017 at 8:32 PM, Meathead said:
I'm using the turbosmart twin port actuator (14psi springs 3 turns preload) with 5.4w 4 port Mac valve @20Hz  max d.c 60% for 1.6 bar boost @3800rpm. High and Low 3d boost maps on Link G4+
Had the EFR high boost canister but it is hopeless for good control and used to severely over-boost after 20 mins driving when WOT. It was about 20mm away from #1 runner so I extended the turbosmart actuator 50mm forward. Boost control is damn near perfect.
@Meathead did you have to cut some more thread on the arm of the turbosmart actuator? My IWG actuator hits on the body of the car and was thinking extending it in this fashion would work almost perfectly i think.
Is that the 'inconel' brand beanie? Did i already ask this or was it a diferent one? [emoji14]
Yeah I'm curious too. I have a genuine efr one to go on my 7163 and it's freakin huuuuuuge. Same beanie they fit on the 9180. One size fits.... Most
4 hours ago, MaximuSmurf said:
4 hours ago, sneakey pete said:
Is that the 'inconel' brand beanie? Did i already ask this or was it a diferent one? emoji14.png
https://www.ptpturboblankets.com/collections/borg-warner/products/ptp-efr-turbo-blanket
Hope so, mine just left Austin...
The 'Inconel' brand stuff kinda lost me at them trying to make it out like the inconel was what makes it insulate, and not that the inconcel is just the high temp protecting casing for whatever they use inside for insulation.
And also the prices
:8_laughing:
Buraz' car.
Went from a Precision 6262/0.84 to a 9180/1.05 on his Racepace built 2.8L.
"target boost" was the same RPM - 4700 RPM, however the 9180 feels much stronger sub 3500 RPM. (Yes, the bigger turbo with the bigger ass end felt stronger down low). That falls in line with a couple other 2.8/9180 results that have come through lately.
6262 made 430 rwkw at 24 psi
9180 made 483 rwkw at 24 psi and 498 rwkw at 27 psi so possibly needs a larger exhaust. It's only a 3.5 inch RP item.
* Adnan loves to rape this thing so the tune is softer than most.
Once again, the transient response is the stand out. The stuff that can't be shown on the dyno.
IMG_4753.MP4
  • Like 1
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
