Guys for the 680hp forged OEM capacity rb26 8374 ar.91 is the best way to go with fastest spool and lowest lagg with that power level? Or better option is 6266 DBB with smaller ar.84 divided?
Which fuel?  I tend to have a strong preference for the externally gated housings btw, the 1.05 would be fine on a 2.6 I reckon -especially if you are aiming for that kind of power area.
98 octane, well it will be external wastegate i have Tial already on my twin scroll manifold. Just wanna ar.91 for the lower lagg than 1.05
Im a little scared of 1.05 ar with ~2.6l for the street car.
I don't know anyone who have gone with the 1.05 and regretted not going smaller, I know plenty who have gone the other way though.
  • Like 5
8374/1.05 over a 6266/0.84 ALL day.
Nismo 3.2ish went between those two turbos and the 8374 was on significantly earlier.
Buraz went from a 6262/0.84 to a 9180/1.05 and down low it drove MUCH better.
8374.. do it.
  • Like 2
8374 1.05.. do it.
Ftfy :)
Also, bare in mind the 6266 turbine is the same one used on the 6466 and 6766 - so for all intents and purposes from the Precision range it is probably not really apples and apples with the 8374 turbine, and more comparable with the one on the 9180.
I have in my head you already have a GTX3582R... I'm not 100% sure that it'd be worth changing unless you have a really good reason?  What is the motivation for the turbo change?
  • Like 1
Yes i have chinese GTX35 with bigger intake wheel [in 63/ex 87 mm] with open t3 0.82.
On 27 psi it make 635hp :P
It feel laggy, even after change gear it build the boost from 1.5 to 1.9.
4th gear spool video
100-240kmh video
Thanks Piggaz, Lithium i going for 8374/1.05 :11_blush:
Edited by Snara
Well i can w8 a few months :P Yes but i think G25-660 is too small to hold 660hp in 2.6l for the 8200 rpms. And it have max flow rate 61 lb/min while efr 8374 have 79 lb/min. But we will see in january potential of G25 orrr maybe G30 later.
They did say on one of their sites that there were other models coming soon, but so was the 8474  :)
Yeah I was more thinking about the potential for a G30-range :)
  • 3 weeks later...
is anyone using an Emap sensor with these turbos?
I'm going an emtron KV8 and the fuel model has EMAP compensation calculated from compression ratio, so I'm adding an EMAP sensor.
I have a single turbo 2.6l rb26, running an EFR8374 with a 1.05 rear and boost up to maybe 32-33psi depending where top speed is.
what kind of peak emap am I likely to see at sea level on a cool day? i want to use a sensor that has the span but don't want to lose too much resolution if possible. being conservitive im guessing 2.5x is a possibility?
5 bar abs sensor?
7 bar abs sensor?
thanks.
matchbot is telling me for 32psi of boost at redline its only 40psi EMAP. that seems very low considering its way off its efficiency there (compressor is at stonewall)
Edited by burn4005
Compressor efficiency doesn't really have an impact on what the ex manifold pressure needs to be.  That's a function of how much power is needed to drive the compressor to do that work times the various factors involved. Granted, comp efficiency is one of those factors.  But the big one is what the match between the exhaust side and the comp side is like.  OEM street turbos are very likely to end up with 2+ times boost pressure in the ex manifold.  Outright race setups where the engine is supposed to be run flat out up on the power curve all the time might be as low as 1x boost pressure.  So it's not surprising that a well matched EFR only wants to do a reasonably small factor on top of boost pressure.  You'd very much expect a turbo chosen for a performance application to be <2x.
5 bar abs sensor?
7 bar abs sensor?
thanks.
Who is your tuner?  Sounds like questions you should be talking to them about as that's who you work with an need to be on the same page with.  I'd be content with a 5bar sensor, myself - I'd not want to be going over 500kpa one way or another.
Just for sanity here, 32psi boost and 40psi are equal to 318kpa IMAP, 372kpa EMAP at 100kpa baro.   I'm pretty sure @Piggaz said his EMAP peaked at 360kpa and he was getting ~122000rpm so loosely speaking the Matchbot numbers sound fairly on point.
The EFR8374 with 1.05a/r seems a really really good match between compressor flow, turbine flow and response for a "nice" sub 3litre responsive RB setup - turbine inlet pressure is essentially starting to climb relative to inlet manifold pressure when you hit stonewall, so still "breathing" well while also not wasting turbine energy in the "transient" turbine rpm range.
Edited by Lithium
I'm the tuner. have never seen results of EMAP from an EFR so was a sanity check. will start with a 5 bar sensor and see how we go with that.
using one of these with a honeywell PX2 sensor and stainless tubing to the T04 collector of cyl1-3:
http://fullfunctioneng.com/product/ffe-emap-canister/
20151022_113226-e1446044231578-349x300.j
I'm running 8374 EFR .92 on a 2.75L stroker and it's ALL IN at 3600 rpms. Actually on the new EMU Black (just switched from Haltech Platinum) I accidentally setup the boost wrong and it made 36 psi at 4700 rpms!! Anyway I do like the .92 IWG for simplicity and I think 2.6L guys pass them up for some reason, but I think it is a good fit on a 2.6L. That being said...I'd still go with an external gated solution because of exhaust housing options. That .92 housing looks like a "catch-all" housing and my ONLY upgrade from here is a 9180 .92...which seems counter productive at my level.
About matchbot - Fuel is a HUGE driver on it. Look hard between pumpgas and E85...I have recently considered the jump to E85 (actually redoing all of my fuel now in preparation for it), but ALL of these turbos really take off and stretch further on it. They are better in the compressor maps as well if you pay close attention to what they are changing. I am at 636 whp on 21 psig with 93 octane and a *little* water meth just to fight knock on the street (since I haven't installed my giant intercooler yet) and I get an extremely responsive fullboost at 3600 rpms. If you really plan on running 30 psi you will likely need to taper off boost as fast as it onsets to keep speeds down. On pumpgas at 21 psi I'm already at the limit on the 8374 .92 on top end. E85 will stretch this a good margin, but 30 is just going to blow tires or break things for sure as hard as the car already pulls.
very interested to see what i'll be getting with boost control setup on mine. Just using the WG (turbosmart) only getting 14psi at 4000ish RPM, i wonder if there's something else in my setup bringing it back a little compared to yours, or something that i'll pick up in the tune...
Need to get the engine back in and get cracking I think
    • Update: Tunehouse looked into the problem and identified a wiring issue between the camera unit and the connector. They managed to get it working , but did warn me at some point it will stop working again. From their perspective it is unserviceable and will need replacement. They did some research and found that the new replacement camera would be Approx $1400 supply only (their fitting cost would be $190) . They did provide the part number (28442-JL05B) and a quick google of the part number shows that these are rather expensive brand new (seemingly no longer in manufacture) for the places that still have them in stock, with the used option potentially presenting  the same issue down the track at some unknown point. They are happy for me to supply the part so that they can fit it. Decisions, decisions... I can definitely recommend Tunehouse (thankyou Vee37!). Cost for the diagnosis was as quoted  ($190) , car was ready on time and communication was top notch. Their workshop is super clean and modern, and there was plenty of car candy parked out the front on the day I went.   Would definitely go back.
    • to fix the voltage drop issue I swapped out the old 150amp alternator which turns out is a brand known for having issues and replaced it with the black 180amp alternator beside it
    • For anyone interested, the Way Back Machine has that Japanese website archived with pictures, etc: https://web.archive.org/web/20051023225805fw_/http://www.a31cefiro.com/air_con.htm "Simply swapping the wiring of the harness will not allow it to function properly. For the outdoor air sensor and sunlight sensor, disconnect the wiring connected to CN1-11 of the air conditioning harness from the harness and connect the sensor side wiring to earth. For the indoor air sensor, disconnect the wiring connected to CN2-3 of the air conditioning harness from the harness and connect the sensor side wiring to earth. The connector PIN numbers listed here are the genuine A31 PIN numbers. To avoid incorrect wiring, check with a tester before wiring. Also, disconnect the wiring in a location close to the sensor. The disconnected harness side wiring will not be used, so be sure to insulate it." Wish someone sold a conversion harness to just plug-and-play a Kouki 180sx digital climate control into C33/A31. I'm decent with wiring but feeling kinda lazy about taking this on. Edit: Did some more digging and found a helpful Minkara blog post about the conversion as well: https://minkara.carview.co.jp/userid/1831116/car/1360568/2284209/note.aspx "After installation is complete or the battery is replaced, you need to go into self-diagnosis mode and set the internal air recirculation. The way to do it is to "hold OFF with the key on for more than 5 seconds, set the number to 5, then press 卍→C." ↑↑↑It probably won't make sense unless you actually try it (・∀・)." Lol wtf
    • Maybe SAUNSW could see howany members would do a motorkhana day if Schofield's is still available for a reasonable price...
    • Skip the concrete, we just need to smooth a field. Mark knows how to drive a grader Duncan   I reckon 100x100 flat area for skid pan style, and then some sort tracks for rally... Duncan's already got a rally car on the premises to...
