3 minutes ago, GTSBoy said:
It needs to, otherwise there is zero point in making the manifold split pulse.
I was going the single gate route but got talked out of it.... No regrets!
  • Like 1
Won't quote names but I've seen a few from big brands appear to be split until both pulses are just going into 1x big 50 mm hole to the gate.
Best I've seen from one brand was an open scroll manifold with a divided T3 flange welded on top lol
  • Haha 1
yeah 6 boost did the spilt for the gate.
I did all the fab work, trust me you dont want anymore pipe work under there. In saying that my gate is plumbed back in which makes it a bit harder. Screamer pipes are easier to route.
But at the end of the day, what for - why make it harder and most $$$ for the same result.
Edited by Deano 1
  • Like 2
Also the plate thats welded up the inside of the pipe from the mani to gate flange - Hangs out past the end of the pipe, once you weld the V band onto the end of the pipe - you than shape the "spilt plate" to suit the back of the waste gate, so its sealed up.
  • Like 1
This would be practically no different to the IWG housings, and i'd be pretty confident that it would be as good as twin gates.
What stumps me is when people do have a split pulse manifold and the single gate isn't divided..
  • Like 1
Given r32-25t has posted a dyno of his -5's with vcam on the same dyno presumably as this i thought i'd put them together for interests stake.
Of course if ramp rate was different etc might cause comparison issues but i figure this is better than most considering its same dyno and a short period of time apart.
  • Like 4
For what its worth, going on boost curves etc, i'd expect my 2.8/9.5:1 8374 to be to the left of the -5 curve. But its hard to say if street feel would line up on a dyno etc.
But yes if i had another spare 5000 i'd get vcam.
Your car would belt the 5s just like every other back to back 5s vs 8374.
Plus a run in tune would be low on timing I'd like to think which should fatten up the middle a bit more.
V cam on your car would probably just induce surge. With the hi comp and .92 it wouldn't need any help getting it spooling!
Piggies car would start surging on the dyno as low as 2800rpm.
So even if it had v cam on it, you couldn’t move the intake cam anyways.
Edited by Mick_o
New EFR crew member checking in....
Manifold will be a 6boost w/ twin gates.
Wastegates will be tial mv-s.
Exhaust will be plumbed back via 3.5" downpipe
The EFR will be used on a SR20DET with a fully ported NAPREC head, big valve chamber with deleted squish pads.
ETA for completion is probably 6 months away.
Having been in a 2.8L EFR machine, the thing is completely mental and beats stock response with quadruple the power.  THEY ARE MAGIC fellas.
  • Like 1
21 minutes ago, sneakey pete said:
might plot that tomorrow arvo if i get a chance.
Note the one i already plotted was -5's with vcam.
As the pig said thats also the same v cam and rolling road not hub dyno like the -5 result. So theres a possibility that its a "higher reading" vs the rollers.
Tell em the turbo son!
Because I was worried about the exact same thing I spoke to Jez about that and his dynos are within 3% of each other
Sweet thanks for clearing that up ?
So lets call it "on par" you're at about 160kw at 4000.. The 8374 is at about 240kw at 4000??
80kw through the middle with 60kw up top.
Thats quite alot more power EVERYWHERE!
Plus all those nice things EFR delivers that the dynosheet doesn't show...
Edited by Mick_o
I'm happy with mine also but coming from Tomei ARMS that wouldn't be a glowing endorsement :P
did take it for a bit of a moutain squirt last week and its great, no 'to large to be fun' issues... and (once i get e85/boost) will have a shitload of power for whenever else i want it
    • The 1000ccs are side feeds but they're not currently installed, had my old factory ones in for leak testing purposes, only decided on them because front facing plenums and good top feed rail kits are out of my budget at the moment, are they really that problematic? Had a set of yellow jackets that lasted me 5 years, no real issues, only replaced them chasing this misfire issue that ended up not being ignition related 😄
    • Are those 1000cc side feeds? If so, that's part of your problem. I have 1480cc and they idle at stoich on 98RON, and all the way to E85. Also your coil packs.....
    • Update for the sake of closure   Ended up getting the intercooler piping all sorted, new plugs and yellow jacket coils, and she was idling mint until it warmed up while I was bleeding the cooling system. Found the misfire to be localised to cyl 3 by unplugging coilpacks, ran a compression test, that checked out, then decided to get a mate to check if that spark plug was firing out of the motor. Upon cranking it over, with the injectors disconnected, the car actually fired and ran on a couple cylinders and heaps of fuel came out the top of cyl 3 I'd say that injector's either spraying incorrectly or spraying far too much, which is fine as I'm planning on replacing them anyway I'm planning on making about 250kW on flex fuel, and have a set of 1000cc injectors from ozautosport, obviously overkill but I'm planning on building the motor and running more boost further down the line, do you reckon they'd be too big for a smooth idle on 98? Thanks for the replies gents, much appreciated
    • I'm confused. You said you want to "remove the clear coat from most panels" but it sounds like you are actually doing a full respray? Few random things to add -  If you chase the blistered paint with 120 grit, I can almost guarantee you'll chase it down to bare metal (that's fine). But if you paint the car from here, you'll have nice little indents where ever the blistered paint was. The new paint won't magically level out the low areas, you need to fill them. Which leads me to the main point I wanted to add, make sure the whole car is flat before you paint it. All those areas with blistered paint you sanded out, make sure to fill them and triple check they are flat with a block guide coat. I'd also check the whole car is flat with a large block and guide coat but yeah up to you if you want to go that far.
