9 hours ago, MaximuSmurf said:
 Otherwise I'll just say f**k it and grab 2 x 38mm gates and go external setup which SHOULD get around the boost holding issue.
I posted something similar in this thread and Geoff from Full race said that it wouldn't make any difference.
Said it was more to do with the rear housing design than the internal gate.
Nice numbers by the way.
  • 3 weeks later...
4 minutes ago, sneakey pete said:
Is there an ETA or any more info on the 8474?
I haven't heard anything beyond what is already in here, I'd definitely update the thread if I have information which I'd be able to share.
The information already in here is basically; shown off at SEMA 2016, someone had one on an evo earlier this year that made ~10% more power and that's about all we know?
Hadn't really paid much attention to it but a mate may be interested if they're going to be a thing before mid year.
How are you finding it on the 2.8?   Must be pretty perky at that power level [emoji3]
Comes on much much earlier than I thought, very sketchy at this power. I usually have it on 29psi setting still a handful to drive tho.
  • Like 1
comparing the dyno charts from both Umair's youtube videos, the 9180 looks to be pretty much 900rpm later than the 8374 everywhere. same engine, both 1.05A/R housings.
8374 is at: 200kw at 4450rpm | 300kw at 4650rpm | 400kw at 5050rpm | 500kw at 6800rpm
9180 is at: 200kw at 5460rpm | 300kw at 5470rpm | 400kw at 5910rpm | 500kw at 5910rpm
it appears the 9180 is being brought on a bit more gradually, then peak torque being liimited by timing (unless wheelspin?) as well
great to see some proper back to back figures!
Edited by burn4005
added picture
  • Like 1
I did change from a 5 speed to a 6 speed (with factory 33 diff) between those tunes, which would have a material impact on the dyno graphs. I.e. it's not as bad/laggier as the dyno shows it to be.
If the ramp rate is the same and the rpm is set up correctly that should have no effect
How are you finding the 6 speed mate?? Was it a headache to convert?
Also just out of curiosity why is it dynoed in 3rd. I know it doesn’t matter much but just curious as every tuner wants to dyno at 1:1 ratio or close to it
the 1:1 thing is a bit of a wives tale.
Final drive ratio has an inversely proportional relationship to velocity, and a proportional relationship to Torque.. so the gear ratio completely drops out of the power equation.
Actual torque is really high in lower gears, any torque plot is just a 'normalized' plot at 1:1 mechanical advantage... really just brake torque neglecting drivetrain losses
dyno in a high gear so the dyno doesn't have to work as hard to retard the engine (especially if you want a slow ramp on a powerful car), but also at a speed that is considered safe.
300km/h is a lot of rotating momentum.
Edited by burn4005
  • Like 2
pretty straight forward to convert although apparently when converting into a 33, you have to remove a part or not connect a part (or something...... my mechanic mentioned it to me once) so on idle/at traffic lights the box just rattles lol. bit annoying but you get used to it.
other than that its awesome for street use. Not so awesome for the strip or roll racing as I'm changing into 5th just before the line.
Also a bit worried if i break something then it would be a very expensive exercise to repair.
Also an FYI - if all goes to plan I'll be heading out to WSID on 11th April to see what this extra power does for ET and MPH. Stay tuned.
  • Like 1
Wouldn’t you be starting in second for roll racing anyway?
cause I was using 1st to 4th in the 5spd and now with the 6spd I’m guessing I’ll be using 2nd to 5th, so itll be the same number of gear changes
Might try starting in 1st to get the 9180 to come quicker.  See how 50km reacts in 1st lol
With the 5spd I was at 6500-7,000 at 50kmh in first so was starting at 40 to make it useful, so with the 6spd I imagine it being even higher lol
    • If the RB29 box in the car is a push clutch, then yes, you will need to deal with the pull clutch on the turbo box. You either buy a pull clutch and don't use the old one, or you do the things needed to convert the turbo box's clutch arrangement over to push. Which is a bit of a f**karound. "Making" a custom tailshaft is the easy part. But you will need to source the front clip yoke - the bit that goes into the output of the gearbox. These are not as easy to find. They are out there, but they don't grow on trees the way that they used to.
    • Indicator bulbs are way too bright to use as a "corner marker" (we call them parking lights too). Sure. Go ahead and do it. But realise that you wil need to come up with all your own wiring to do it, as no-one will have a standard howto worked out for Skylines. It's just a matter of abandoning everything that Nissan have done and starting from scratch. You'd probably be better off retrofitting tailght/brakelight globe bases into the front indicator housings and using the taillight circuit for your corner marker and the brake light as the indicator. You'd need to work out how to kill the marker circuit while the indicator is flashing, otherwise it won't flash on-off, just bright-less bright.
    • Hi. A little bit of an update. It maybe(hope not) looks like i would need a new tranny(it would be "maybe" a cheaper or better option anyway) So i need some info. I know i need a different propshaft(i can make custom one) LSD is not a problem cuz the engine will be still(for now) N/A RB20. So if i buy RB25DET NEO tranny...is there something else i need? I read something about push/pull type but i do not know if i need to "change" something or i can just plug n play onto my engine a go? Thanks for the advice
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
