I'd imagine for flow rates towards the upper end of the 8374 the 9174 will have a lower exhaust manifold pressure as the compressor will be more efficient, all other things equal.
at 75lb/min @ 2 bar you're at 65% on the 83mm but still up over 72% on the 91mm that effeciency change correlates to shaft power requirement dropping, so the required turbine pressure ratio also drops.
the changeover in efficiency occurs at about 58lb/min. less than that the 8374 will be lower pressure, and more than that the 9174 will be lower. during acceleration transients however the 9174 will be slightly higher due to the increase in inertia of the larger comp wheel.
17 hours ago, Full-Race Geoff said:
that is correct, 9174 works best with the big 1.45 a/r housing when pushing the turbos limit.  The 74mm turbine is relatively small to swing the 91mm compressor so anything that can be done to reduce preturbine drive pressure at high rpm / high boost is a win for this one.
if only Borg warner made an EFR 67/84mm compressor wheel!
maybe even anodize it black?
Edited by burn4005
56 minutes ago, RICE RACING said:
9174 on a well built 2.7lt 4 cyl
That's just bollux.  What a ridiculous power delivery haha.
For those who didn't watch the video - check out this power delivery, 300kw at 4000rpm on something holding power to 8500rpm... Like 875hp power.  There isn't much to question there.
Cheers for sharing!
Cheers for sharing!
That's with a 1.00TCF too, so basically ~1000bhp @ engine with the FR combination in that car with the rear end and 1:1 4th (minimal gear train *gearbox* losses no driver/driven x driven/driver power flow since direct drive *no lay shaft* so input shaft>output shaft).
Now to pick what to use on the EVO????
Edited by RICE RACING
we built the turbo kit on steph's drift car.  its a 2.6L engine from a toyota sienna minivan, typically he revs to 7800-8000rpm depending on the track and gearing.  Turbo setup is divided t4 manifold, very similar to evo but flipped so its a top mount obviously.  the turbo started as 8374 0.92 a/r, then tested 1.05 a/r 8374 and went back to 0.92 once they had the nitrous on the car.  He is battling V8s and 2jz's so he needs as much bottom end torque as is possible.  once they switched to the 9174 he kept the 0.92 a/r for a while due to the setup already being built and in place.  as of right now i believe he is back on the 1.05 a/r.
keep in mind there is a lot of nitrous on this engine
Edited by Full-Race Geoff
21 hours ago, Piggaz said:
What kind of exhaust pressure increase are you seeing on the 9174 over the 8374 for a given turbine housing size/engine combo?
it depends entirely on the application - altitude, engine size, max rpm, boost level, VE, etc.  typically the 9174 exhibits increased emap at most points
Yeah, definitely noticed that - ANNNNND in the most "harsh" correction mode Dynapack dynos offer.   No two ways about it, this is making some big power with a very wide delivery.
Yep good to know a 9174 with 1.45 will actually do 1000bhp on a 2.7lt engine. It's not often you find nuggets of info like that around, saves having to test everything yourself for sure!
Somebody help me out, being offered a seemingly near new 7670 with a 1.05 TS rear on it. this would be to go on my forged SR with a sexy head and good TS manifold.
Too big/small max power? I have a hard time wraping my head around EFRs other than they seem to be a "good" thing.
Sprint/time attack style car so the transient is what interests me, I'm expected the motor to be capable of "decent" revs.
The 7670 is the turbo I used to have,
Up to 450kw, maybe even 465kw.
It's a big turbo. It's not as big a turbo if you're realistically considering using it as a track car, i.e always up in that rev range. You'd have to define "sexy head" as this is a turbo you'd be need to be living at 5-8k at constantly.
It is GTX3576 sized.
I guess I don't know what turbos you are familiar with, but I feel like the most sensible way of describing one is if you were looking at something using "back in the day" turbo terms - its in the area of a Trust/Kinugawa T67 - Garrett GT3582R power wise but wanted better response (just to clarify, I'm not saying it will be like a supercharger - just something that is in that power range with less lag) then you should be happy with it.
Edited by Lithium
8 minutes ago, ActionDan said:
Maybe too big for me then I was looking at Gen2 GTX3076 or so.
Maybe it was the 7163 I was looking at.
Haven't seen much of the Gen2 GTX3076Rs, but I'd take an EFR7670 over a Gen1 GTX3076R from what I've seen.
An EFR7163 would be a beast on an SR, though if you are going for high rpm there is a chance of choking it - I'd use the biggest housing you can get on that turbo.
I would highly recommend AGAINST the 7163 for your track use. IMHO the rear exits are too small for TS use. I would think a 7670 and 1.05 (MAYBE even the smaller 0.92) would be perfect. The 7163 only come in 0.80 rear in TS form which I believe (no expert) chokes too much, especially under higher RPM.
FYI I'm running an EFR7163 on T4 TS SR20DET. I will be pushing it HARD to get maximum response and power for street / light track duties. But the small lag hit I think you'd be wanting the extra ~80-100rwkw and freer flowing turbo setup.
I don't wanna blow the bottom end apart trying to "use" a turbo properly.
Will have CP pistons, Manly rods, and some other tricks, but I was under the impression most "basic" forged h beams were only good for 600-650 crank hp in an SR, but how long is a piece of string?
    • I would paint match the whole thing to avoid unwanted attention  I had a similar bonnet, paint matched, on my old R33 GTST, but mine was a fibreglass jobbie made by Blitz in QLD, they work extremely well for radiator efficiency and under bonnet temps
    • Does anyone run this kit with factory plenum? Does the adapter and bosch tb fit under factory strut brace? I wanted to get this setup before going forward facing manifold. Thanks
    • small update time, after always wanting a "cool" looking bonnet for my car and always struggling to find one for the series 2 that i liked and wasn't an insane amount of money. Saw one i liked on RHDjapan from D-speed in Japan the price was very good for a carbon bonnet so good infact i was a little unsure how much i trusted it, decided to bite the bullet and with the help of jesse streeter in not long at all it was at my door. Once it was delivered i ran in from work and quickly unboxed it and to my surprise the quality was actually pretty good i quickly removed the old bonnet and placed on the new one to test it out and even the fitment wasnt too bad at all. Then decided to paint the little grille in the bonnet black to stop it sticking out so much.   I decided to not mess around with the hood latch and just install some aero catch hood pins, having never installed them before did some YouTube university classes and i was good to go. fair to say it is not a fun job at all from making brackets so the pins sit nicely and actually cutting through the bonnet but also being very scared of cutting the holes too big it took wayyyy longer than i would like to admit but finally got it there. Then it was time for a quick test drive to ensure the latches actually worked and thankfully the bonnet looked very stable. I still think paint matching the bonnet and leaving just the part that sticks up as carbon would help make it all look alot neater as im not sure how i feel about all that carbon on a very fridge white car but will leave it as is and see how i feel with time.
    • I think it's bound to happen, you finally get it all perfect, and bam, something will happen. I took a while to get a Commodore rear quarter repaired where a P Plater clipped it. Two days after getting it back, Sarah wiped it out on a concrete pillar in an underground car park... This is why I take forever to repair them, it stretches how long until it gets bent again... 😛
    • Nah, not really responsible for that little fiasco, but I'm still pissed at myself for writing off my 86, or when I reversed my VX into a pole just before selling it, but, meh, 5hit happens to stuff, all it takes is a slight distraction, and life is full of distractions, and "dooh" moments
