3 hours ago, Full-Race Geoff said:
The 9180 1.05 can easily supply 500rwkw worth of airflow.  the rest of the setup will need to support this, fuel is the biggest factor (knock)
Full-Race has a few in stock, there will be a sale for the big holiday in the states this weekend
BTW, I meant awkw, not rwkw.
21 minutes ago, Piggaz said:
Piss it in. 8374/1.45 on my setup went 517 AWKW at 122,000 turbine RPM. 490 AWKW with the 1.05 bum.
Thanks mate. Is that on a 2.8 and on 98 or flex? Looks like you were just under the line there - for the 8374, is it 125k max shaft. speed?
Paul , you have had the 1.45 on for a while now and at first you were sort of thinking about switching back to the 1.05.
You have had a few runs now and one today with Dan , have you made your mind up yet ?
2 hours ago, Nismo 3.2ish said:
you have had a few runs now and one today with Dan , have you made your mind up yet ?
Nugget. Spending money on the wrong things, needs a shift boot and a front lip ffs.
I am too upset to talk about it in depth right now but will update with more when I am back in NZ ?;)
Edited by Lithium
56 minutes ago, fatz said:
1.45 no good?
Dont they make like 4 million kw in seppo land?
1.45 has its place. Did the Huntley hill climb today and just doodling through it at a corner that I had huge issues with the twins, it was ready to turn tyres.
I won’t be going back to the 1.05. Sub 3000 RPM there is Definately a penalty to pay, it feels a bit “soft”, from 4000 RPM it’s fine. If you’re “driving it” it’s all there. The 0.92 IMO should be made redundant IMO. No need for it.
Still well infront is the -5’s that we’re on it either way.
Without the head work you have done and slightly higher CR 9.1 ish , would the 1.45 still give you what you want or just lag it to much for what you like in a Street car
Guess without some sort of comparison it would be hard to know how much difference it would make .
Stock head no.
Depends on what you want, what you’re happy with. Having driven both, I would want my cake and eat it too. If the engine ever comes out I’ll throw a V cam at it and possibly bump the compression up a tad higher. Cake and eat it too?
As you know I am thinking of doing some headwork ( never ends lol) wondering if anyone has a 3.0 or 3.2 Lt that has has the compression increased  up to 10.5 ish   , mine is down to 8.1 for whatever reason during work on the stroker build ?
Maybe also done  some port & polish work?
Back to back Dyno runs would be great
I will stick with the 8374/1.05
Of course you should do that.  8:1 is 1980s CR for boost.  But you won't get that increase by changing the head. You'll need pistons.
20% increase in capacity means a 20% increase in head flow wouldn't be a bad idea.  Easily achieved with sensible porting.  1mm bigger valves gives the perfect opportunity to properly do the seat angles and shape the bowl into the back of the seats.  And there goes 5 grand.
A decent full effort head costs as much as the bottom end. That’s where the last 15% of performance is found. Depends on how much that last bit is worth to you.
Sort it out Pete!
There will have to be new pistons to go with the new work, it will have to be done properly especially with the Vcam in the car, I already have 1mm OS valves
i decided that if I am going to pull the donk down, get it all done at the same time
Wouldn’t do it if I did not have E85 close by now ?
Sort it out Pete!
Yeah mate , as you know I have been tossing it around for a long time and can’t help myself, must do it , have to feel the difference when I press the peddle, like an Fn drug ?
Just now, fatz said:
Pulling down a running motor is just dumb
just saying
break then fix
Know what you mean but I am not going to break it anytime soon and at 76 , F it I want to finish It , just wish I knew what I wanted at the getgo, but I think there are many blokes doing work on their cars and the goal posts just seem to keep moving
But I had no idea I would go this far , it just gets in your blood like herpies and just keeps coming back when you think it over ?
    • I suppose that's true. Barring almost any situation, I'll never sell so what the market does is kind of irrelevant to me. It's possible I'd make most of my money back. That spreadsheet I mentioned? Maybe I could make back more than what the car's total costs thus far are, but the parts and all that is possibly a different story... Thanks for reading. It was certainly a good moment and just makes the ties to the car that much stronger. It's exciting that the option will be there to bring it over, however I have some plans with a shop that may end up keeping the car there longer, not sure. Coupled with the fact I want to move there and haven't solidified any path yet. So in a way, it feels like I'm in a limbo state that is uncertain; time will tell.
    • No worries, everything worked out in the end. I just wanted to make the point that it doesn't matter where it comes from (I.E Australia), it can be broken or improperly built. I would still purchase from these companies in the future. B2R - Not certain how that finished, this was on a car I wired a few things and street tuned. I know the owner ended up shipping the motor back to Australia for investigation. Hopefully some of it is covered under warranty.  Turbosmart - I always pressure test everything that goes on my car. It's a habit from my career in oil and gas. I run two 40mm's and both had major leaks from the actuator to exhaust portion through the shaft. I returned both, they shipped me back two and one was leaking and the other had a 38mm top (40mm gate with 38mm actuator cap, no idea how that happens). Eventually after a lot of back and forth I found myself with two non-leaking gates. I believe this happens a lot more then people would like to believe but you would never know if you don't pressure test them prior to installation. Crank Motorsport - Issued a full refund and let me keep the seat rails. I turned them into scrap metal for other projects. GKTech - Shipped me out a replacement and asked that I modify it as per my idea and that they would do the same for a future revision. ATP - Can just needed a large shim to bolt up properly.  Haltech - They started an actual proper Beta channel for firmware's a few months back and stopped using the general public for testing. I'm now much happier.  Speedtek - f**k Speedtek. I would love to watch them burn.
    • I've got a Turbosmart wastegate, ATP catch can, many GK Tech parts and Haltech everything. Everything's been perfect, sorry to hear your experience wasn't the same
    • The only high-power RB I've personally seen go pop after running for all of an hour on a dyno was built by B2R, while being remotely tuned by B2R. The only wastegates I've ever had leak like a sieve, return, still leak, return and get shipped back the wrong ones were from Turbosmart. The only final drive that I've ever purchased that were unusable, twice... were from Speedtek. The only seat mounts that I've ever purchased that placed the seats in the door frame were from Crank Motorsport. The only poorly designed parts that I had the manufacturer confirm should have been designed as per what I mentioned were from GKTech. The only ECU I've had firmware updates consistently break things are Haltech. The only catch can I've purchased that didn't fit in its advertised spot was from ATP. So forth and so on... Moral of the story, doesn't matter where it's from. Do your research beforehand and stick with products and companies you've trusted in the past.    @joshuaho96 If you want it done right, do it yourself.
    • Something coarse-ish. 180 is good.
