R34 GT-R/S13 Shed Clean Out
Removed due to upgrade/replacement. Haven't fully separated/cleaned things up yet. Can take more pics as needed.
R34/RB26
- RB26 Stock manifolds - $20
- Stock manifold shields - $10
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $250
- R34 Standard fuel pump. $40
- R34 AFMs $80
- Standard Cam Gears. $10
- R34 Non Vspec air guides for brakes. $200
- R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $80
- R34 GTR Intercooler, with IAT bung - $150
S13 - Free/6pack/whatever
- S13 CA18 Viscous Centre and 6 bolt shafts.
- Carpet
- Roof lining,
- Lots of interior plastics
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- CA18 AFM and plug.
- a TPS
- Washer fluid bottle and neck
- Standard space saver.
- CA18 carbon canister
- Rear toe arms
- Rear camber arms
- Leaking power steering rack that includes the rack ends (the rack ends might be S15 ones as I used an S15 rack and some bits from the S13 rack ends/tie rods.
I can assist with fairly cheap postage or pickup is fine.
Make an offer, take a bulk lot for cheap, just want it all gone.
Located in Wodonga.
https://www.sau.com.au/forums/topic/466640-r34-gt-rs13-shed-clean-out/
Don't have the mirror triangles.
See pics of carpet, has been cut up on the tunnel under the dash and has some small blemishes under the drivers mat.
  • 3 weeks later...
Exhaust isn't actually 3" mid as thought.
List updated with new parts/things removed that have sold.
R34/RB26
- Greddy air diversion panel - $100
- 2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $200
- R34 GTR Intercooler, with IAT bung - $120
- S13 CA18 Viscous Centre and 6 bolt shafts and diff cover.
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
- Traction rods
Or take a bulk lot for cheap.
Located in Wodonga.
  • 1 month later...
List update, pic update.
R34/RB26
- Greddy air diversion panel - $80
- 2x Stock manifold shield sets - $10
- 2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $150
- R34 Non Vspec air guides for brakes. $100
- R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $50
- Properly baffled catch can with sump drain, was $200 new, never used only test fitted. $150
- S15 crown wheel.
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
- Traction rods
- S13 and S14/15 RLCAs.
- S13 Castor arms.
- S13 and S15 Tie rod ends.
Located in Wodonga.
  • 4 weeks later...
  • 5 weeks later...
Forgot to add
2x full sets. 17x8 and 17x9 multi stud. One set has 235 RS-Rs on them with a bit of tread left.
I need some 4stud/multi stud 17x9 all round that will clear 4 pot brakes on a Silvia.
    • Pete knows these cars well, he does my car too, if he was concerned about the traction arm length for your use he would have said so. Do you have adjustable bushes in that arm, maybe he got enough adjustment there (or maybe the bump steer was not material for your use of the car)
    • Hmm. Yes. I should have been clearer. 1000s for Haltech, for extra headroom. 725s for Nistune. You might even be OK with 640s, but if the possible power ends up much more than 300 rwkW you will run out of headroom on the 640s. That would probably be OK and a signal to not push it to that sort of power with Nistune anyway. At that level you probably do want to be thinking about engine protection functions. Oh, and all of that presumes 98 only, not E85. Well....the 1000s would allow you to run E85 at ~300rwkW territory, again, maybe sort of running out of headroom. Hard to tell with E85 - depends on the tuner as to how rich they like to set it up.
    • Yes.  The only scenario I can imagine when the answer isn't yes, is if you drive like there is highway patrol behind you at all times.  If your car currently runs, enjoy it and keep saving. Better costs more, keep saving until you can budget the better ECU. It's worth it.  Nope. Plenty of us making >300kw on unopened motors. Mine is unopened and makes about 350kw if I turn everything up, its fine (lots of caveats here, how the car will be used/abused, how long you expect the engine to last between rebuilds, how has the engine been maintained prior to coming into your ownership, etc etc).
    • Sorry just wanting to clarify, at this power goal, which should I be going? Also, More info regarding suspension, the rear upper camber arms were used to get the camber back to i believe around -0.5 ~ -1 degree (@ Road and Race in Rydalmere), I forgot the exact figure, but ALOT less camber than what it came originally which was like -2.5degrees. Are the traction arms still recommended? The bilsteins from SydneyKid, they've got 400lb/in fronts & 275/in in the rear, revalved to his specs. Intercooler, I'm just having a look at some on Rakuten.jp and some other japanese sites. Might get something from back there, GReddy, Blitz or HPI, all crossflow. Looking at roughly $450-$500 AUD + shipping... Theres not many choices except that chinese branded Justjap unless you go for blitz return flow. Yeah, only downside with Haltech is the price ahhaha, so expensive, and with all the sensors if I go that route... $$$$$ yeesh. Are headstuds/gaskets needed for <300akw?
    • Haltech fanboi reporting in. Buy the Haltech!
