R34 GT-R/S13 Shed Clean Out
Removed due to upgrade/replacement. Haven't fully separated/cleaned things up yet. Can take more pics as needed.
R34/RB26
- RB26 Stock manifolds - $20
- Stock manifold shields - $10
- 3" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $250
- R34 Standard fuel pump. $40
- R34 AFMs $80
- Standard Cam Gears. $10
- R34 Non Vspec air guides for brakes. $200
- R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $80
- R34 GTR Intercooler, with IAT bung - $150
S13 - Free/6pack/whatever
- S13 CA18 Viscous Centre and 6 bolt shafts.
- Carpet
- Roof lining,
- Lots of interior plastics
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- CA18 AFM and plug.
- a TPS
- Washer fluid bottle and neck
- Standard space saver.
- CA18 carbon canister
- Rear toe arms
- Rear camber arms
- Leaking power steering rack that includes the rack ends (the rack ends might be S15 ones as I used an S15 rack and some bits from the S13 rack ends/tie rods.
I can assist with fairly cheap postage or pickup is fine.
Make an offer, take a bulk lot for cheap, just want it all gone.
Located in Wodonga.
https://www.sau.com.au/forums/topic/466640-r34-gt-rs13-shed-clean-out/
Don't have the mirror triangles.
See pics of carpet, has been cut up on the tunnel under the dash and has some small blemishes under the drivers mat.
  • 3 weeks later...
Exhaust isn't actually 3" mid as thought.
List updated with new parts/things removed that have sold.
R34/RB26
- Greddy air diversion panel - $100
- 2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $200
- R34 GTR Intercooler, with IAT bung - $120
- S13 CA18 Viscous Centre and 6 bolt shafts and diff cover.
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
- Traction rods
Or take a bulk lot for cheap.
Located in Wodonga.
  • 1 month later...
List update, pic update.
R34/RB26
- Greddy air diversion panel - $80
- 2x Stock manifold shield sets - $10
- 2.75" mid pipe with flanged stock Nissan cat and basic mid muffler into 3.5" rear pipe/muffler section with cannon. Can only see a Jasma label on it - SR. Came of 34, but will fit 33 with minimal mods - $150
- R34 Non Vspec air guides for brakes. $100
- R34 GTT Console ilid skin, mint condition. Hinge and leg no good though. $50
- Properly baffled catch can with sump drain, was $200 new, never used only test fitted. $150
- S15 crown wheel.
- Carpet
- Roof lining,
- Interior light
- CA18 Cam Gears
- CA18 Intake Cam
- a TPS
- Rear toe arms
- Rear camber arms
- Traction rods
- S13 and S14/15 RLCAs.
- S13 Castor arms.
- S13 and S15 Tie rod ends.
Located in Wodonga.
  • 4 weeks later...
  • 5 weeks later...
Forgot to add
2x full sets. 17x8 and 17x9 multi stud. One set has 235 RS-Rs on them with a bit of tread left.
I need some 4stud/multi stud 17x9 all round that will clear 4 pot brakes on a Silvia.
    • Thanks for that.... If only I could do something once and be happy with that, like some people do....
    • I had no transmission at all so I managed to find a big box manual gearbox from an R34 GTT for an insanely good price in EU. I converted it to push type which cost more than the transmission almost, with parts from Amayama! These engines are very strong and can put out decent power with a properly sized turbo. You can save on money from parts like pistons and rods, and invest those in the transmission and other parts. I suggest you join the RB20 Enthusiasts facebook group, plenty of info and almost daily posts there about 20DE/DET/Neo+T builds. (I hope I'm not breaking any forum rules by mentioning third party platforms, just trying to help the buddy out)
    • Yeah, having tried all of those methods including BBQ+recipro/hacksaw, I ended up buying a bush press kit under $150 that works well, like this: https://www.ebay.com.au/itm/355967727167?mkcid=16&mkevt=1&mkrid=705-154756-20017-0&ssspo=sfmmuhxgqhm&sssrc=2047675&ssuid=dJvnaZ11TB-&widget_ver=artemis&media=COPY It basically has a range of pushers and cups with threaded rods between to press out a range of large bushes. The problem with any sawing solution is minimising damage to the subframe side, although it probably needs a quick sand afterwards no matter what solution you try due to damage
    • Hi. Thanks for the answer. I do not have instagram 😄 I too considering turbo the RB20DE NEO 🙂 But i think i upgrade the gearbox first or at least buy new.
    • Just pulled the passenger apart so got a good idea, also the side bracket that pivots the top half is completely cooked.. how I don’t know.. haha and paid $400 also included a photo of the passenger seat! She is mint
