R33 intermittent loss of power.
Hi guys.
I have an R33 gtst series 1.5
List of mods
Full high Flow xforce exhaust
K&N pod filter whith heat shield
Blitz front mount intercooler
Spit fire coils
New spark plugs ( unsure of brand)
Power fc tuned by legend matt spry
Z32 airflow meter
Stock turbo running 13 pounds
Car is making over 200kW at wheels
I have several issues. There are days when my car feels nice and responsive and goes like a bat out of hell. And there are days when I feel like I've lost about 30 hp through my mid range top end power. At times my accelerator feels less responsive / sluggish and boost doesn't feel like it comes on hard.
At times it feels like boost is flowing through a McDonald's straw.
Now the other strange issue is sometimes when I stab the throttle to rev match the car will bog down but not always.  It's very inconsistent. And my fuel economy is terrible.
I have also noticed some oil leaking from intake manifold. I was advised it could be a sqaushed gasket causing boost leak?
Only strange thing matt spry saw on the dyno was the 02 sensor was crapping out when the car is cold and dumping crap load of fuel but fixes itself when it warms up.
Could it be piston or valve issue guys?
Problem is extremely frustrating and has been happening since I've owned the car. I just want my pride and joy to be running 100%
Any help would be appreciated guys.
Edited by Redknight
https://www.sau.com.au/forums/topic/466641-r33-intermittent-loss-of-power/
Where is this oil leaking from? Check your intercooler and pipes, could be full of oil which could be blown turbo seals.
It could also be broken ring lands, resulting in epic blowby which will dump heaps of oil in your intake. This is never good... This will put some oil on your AFM too.
    • Interesting....can't say I've ever checked it, have always just changed it in the off season as practice
    • Just checking, when we are talking about high temp fluid, are we all referring to DOT 5.1? I haven't had any issues with changing it every 2-3 years.
    • Yeah that is still true AFAIK.....good brake fluid should be changed annually because it absorbs water faster which is more often than most mechanics would do it. There are cheap tools that check water% in brake fluid if you all scientific about it. I for sure would (do) run good brake fluid in anything that even casually saw the track like Murray said; avoiding the risk of "exciting" fade is worth it
    • Well, back in the day..... "race" fluids, which were essentially only really "high temp" fluids, used to absorb water more readily. So they really needed to be changed more often anyway. The coincidence of that being directly necessary along with it being what racers would do as a matter of course was just fine.
    • Does the high temp fluid degrade any different over time compared to normal one? That's one thing I've always been wondering. Because a track car is going to get the fluid flushed probably way more often than every two years and will see less kilometers driven. I would think the requirements are different. I'm running Motul RBF 600 in mine. Was recommended by my mechanic before a trackday and I've stuck with it since. Hasn't seen the track since but I've kept buying and using it for servicing anyway.
