Skyline GT-R aftermarket parts for sale. BRAND NEW.
Hi All,
I have few aftermarket parts that I was planning on using on my R32 GT-R. As this is now a designated race car a lot of these parts were not used.
SAARD 700CC Single nozzle injectors for GT-R/ RB26 USED
For sale is 6 SAARD 700cc injectors that I was using on my R33 GT-R. I am selling them as I had to bring my car to stock form to clear an EPA and never put them back on. Since my GT-R is now sold I have no need for them.
  • Injectors suit R32, R33 and R34 GT-R or RB26 engines
  • Top feed
  • Low impedance
  • Single nozzle
  • 63500 part number
  • Dead time 0.65msec
  • Used less than 1000km
Price $500
Tomei Pon Cams 256 degrees IN/EX 9.25 lift R32 & R33 GT-R RB26 BRAND NEW
Brand new set of Tomei Pon Cams for sale which suits R32 & R33 GT-R RB26 engines. These cams are still in box and in the oiled vacuum sealed plastic. I purchased them to use on my race R32 GT-R however I didn’t install it due to using a bigger HKS cam.
These according to literature on the web are drop in cams. Which means no valve springs will need to be changed. Tomei products are some of the best quality parts money can buy.
Cam specs
  • Part number IN 1421 256092 EX 1422 256092
  • 256 degree 9.25mm lift both IN and EX
  • Suit R32 & R33 GT-R RB26 engines
Price $600
Alexi Power FC + Hand Controller to suit R32 & R33 GT-R BRAND NEW
For sale is a brand new Apexi Power FC suits R32 & R33 GT-R still in box. I bought this brand new in 2006 and recently put it in my R33 GT-R (prior to selling it) to see if it works. The car was just turned on in the garage and that’s the extent of it’s use.
I purchased the PFC initially to run it on my race R32 GT-R, but instead opted for an ECU running map sensors.
  • Part number 414AN029
  • Power FC + Hand controller still in box
  • Suit R32 and R33 GT-R
  • Booklet of instructions
Price: $1000
IMG_0307.thumb.JPG.d87effbfd767775d8585ae062f2db85a.JPGIMG_0308.thumb.JPG.20dcf5d3c948732381328afa1e33308f.JPGIMG_0309.thumb.JPG.a0ceb5487f80afc2ed3d0b3ea92377e2.JPG
Garrett GT2860-9 x2 turbochargers for Nissan Skyline R32 R33 R34 GT-R BRAND NEW
For sales is a pair of Garrett 2860-9 turbos to suit R32 R33 R34 GT-R RB26 engines. These turbos are the HKS GT-SS equivalents. I purchased these 5 years ago from Boostn Imports for my race R32 GT-R. Instead I decided to stay with a single turbo set up. I was holding on to these to eventually put on a street driven GT-R.
I have read on some forums that people are getting close to the 400rwkw mark with these turbos on E85. Some of the more conservative estimates have been around the 330rwkw mark on PULP.
  • Garrett GT2860-9 x2 turbochargers rated at 650HP
  • Comes with 2 15.6 PSI actuators
  • BRAND NEW never used
Price: $2200
IMG_0071-1.thumb.JPG.ea44c71ac63cdb0ccdca0931cab4399e.JPGIMG_0068-1.thumb.JPG.3ac23ab8005c4942577538cd6b01b5df.JPG
Contact & Delivery Details
For more details please feel free to contact me via PM or email me on [email protected].
Delivery: Please use the Australia post calculator. I will not respond to requests for delivery prices. A rough estimate can be viewed using the URL below. AUSTRALIA POST DELIVERY QUOTE.
Please no time wasters or low ballers. I will ignore all ridiculous offers!
  • 1 month later...
  • 1 month later...
    • ...just a note of warning, you shouldn't drive it about with the TCU in limp mode with only 3rd gear available ~ apart from the fact you end up sheering the ATF at the torque converter interface, the high clutch in these isn't especially the strongest, particularly bolted to the RB25DE mill...which is likely a 4AX01 box with lighter duty high clutch (the RB25DET got the bigger high clutch)...be careful out there...
    • Hoping to do similar mods to my RB20 once I get it running and reliable again
    • As you're looking at using a Link ECU, then large injectors are not a problem. But there's not really any need to go 1000s on an RB20 unless you're planning >>600HP on E85, which would seem unlikely. There are other options for injectors. The Xspurt ones are available from a number of places and you can get them in the mid 600s and 725cc, which is probably a sensible place to be. These are all EV14 based. If you are not using the stock AFM (at all, which would be the case with a Link) then a large turbo intake pipe to suit the ATR turbos is not an obstacle, so you should use one instead of a highflow. Results will be better.
    • Hey guys,  I'm after some advice and this here is the best place to get it imo. I was a member a looong time ago under another account, with a lost email address. Its nice to jump back on and see some of the same names still giving good advice.  I mothballed my car when i moved to perth in 2013, and after getting towed across the nullabor a few times it has officially done more km's on a trailer than under its own power. Now that i have started the process of tidying up and modifying it, i see the fruit available (and the fruiterers selling the produce) is different than back in the day. hence my questions, as i used to 'know' what to get and now, i'm not so sure. Engine wise the car (92 gtst) has a walbro 255, k+n, fmic, cam gears and and turbo back 3"exhaust. Wish list is a Hypergear high flow or ATR43G1, Link G4x and some newer injectors before a tune up. My goals are modest, only low 200's power wise. i know i could achieve this with less, but i've been swapping out old for new where i can. Every cooling hose has been replaced, along with mani gaskets, WP, thermostat and radiator, fuel pump and timing belt, tensioner and idler, and i rebuilt the steering rack. Regarding the injectors, the fruiterers all seem to sell what used to be considered quite large injectors. There are a lot of options for bosch 1000cc EV14's, and i would like to know if that is a suitable choice for my build. Is modern injector design good enough to run these at the low duty cycles that i likely would be? is there a downside to running a too large injector these days? or, would there be an upside to running a smaller injector at higher duty cycle? I can see that there are smaller injectors still available, but the ones i have seen specifically marketed for RB's are pretty large (see: https://golebysparts.au/collections/fuel-rail-injector-kits/products/nissan-rb20-fuel-rail-bosch-980cc-1150cc-injectors-turbosmart-fpr800-regulator-kit), and i dont know enough about them to say one not marketed for RB's would fit or not. I have searched the forums, and amongst all the posts on older tech, I did see gtsboy recommend EV14's, but no size was mentioned... again, i'm not clear on if the smaller size bosch injectors are also EV14's as they do look similar.  also, if someone can recommend a tuner familiar with RB's in the Geelong or West Melbourne area i'd appreciate it. Thanks in advance guys. Cheers, Rowdy
    • FWIW the depth of the groove in the rubber pad is not super essential, the blocks are rubber and squish a bit. If you are worried an angle grinder will make a deeper groove quick smart
