Hey guys :)
I have these stains on my seats that I can't get out on my R34. what do you guys use for cleaning on seats?
And also, how can I get these scratches off the radio surround plastic panels? I looks kinda deep like it was scratched with a screw driver from previous owners.
Edited by StaceyR34GTT
Heat gun should work on the scratches. But may cause more damage if not done with care...
The seat needs a wet extraction vac, those carpet cleaners that you can hire from supermarkets work fine
  • Like 1
Someone looks like they had a blast on that seat and couldn't hold on to anything so he scratched your panel and left a big happy ending stain. USE SCOTCH GAURD AND RUB IT OFF WITH A CLOTH, or any carpet cleaner from a AUTOSHOP !! The scratches looks bad :( just pull the panel out and like wrap it with carbon fibre or some sort
  • Like 1
I had  the same problem with the seats on the 34 when I had stock seats. You do so much as rest a cold can of coke there for half a second and suddenly you have that ugly mark.
I was able to remove it with just your common autobarn-esque type of interior seat cleaner, it actually responded pretty well. As for the scratches I have similar problem and the surround and gearbox is like $80 but I am interested in the heat gun method too if it can be better explained.
One of those things that makes the car look awful during the day but looks fine at night :P
A commercial automotive trimmer or upholsterer will know what solutions to use because they have them.
For seats, I've just used Polyglaze Upholstery Cleaner or a brand of Carpet cleaning agent.
  • 8 months later...
2 hours ago, MissGTR34 said:
I have a bad stain on the rear seat in my gtr, ive literally tried every cleaner, carpet machine etc.. anyone have a miricle?
Cheers,
Is it jizz?
  • Like 3
41 minutes ago, Ben C34 said:
Is it jizz?
Haha... i freakin hope not.
Has anyone had any luck with gross carpet too btw? Best cleaners/deodorizer  (feels like such a chick thread)
  • 4 weeks later...
    • Of course you can. That was a waste. Straight down one oil drain gallery and out the sump hole. Could at least have run the engine a little (obviously with at least minimum oil level on the stick).
    • Oh really? Maybe I'm being silly. I'll get some more shots. I had it higher but found that it went too high after a drive, I never knew this but exhausts can move around a bit when hot (makes sense, just never knew) and when it was higher it would make nice cooking plastic smells. That said, I could put some heat tape on a'la 90's R33 exhausts     Ha, I've spent a lot of my life in castle hill waiting for cars to be done. I think I'd prefer something closer but thanks D.
    • @Duncan Yes, changed filter every time. I don't have the service manual for the car yet (Car was imported and they removed everything when importing). I've been using the oil change threads in the forum as reference.   @Milkmun The second oil change was after ~4 months after the first months and I wasn't sure about reusing engine oil that was opened. The third oil change happened within 3 weeks of the second oil change and I used the previous leftover oil to just "clean up" the system. (Poured it through while the sump plug was open")
    • I left the ceramic coating off this bit, hopefully it just comes off after a few drives.   The gap between the spokes is too tight for anything on a stick, its only marginally bigger than my finger. I have to use a brush to get in there and its a big reason why I thought I'd try the coating.   Absolutely will do. I have EBC Blue Stuff pads to put on the front which will make them a bit dirtier. I'm hoping a pressure wash will just get most off. The shine is different to most, its very thin but seems very well 'attached' so hopefully it lasts.
