Nismo 2-way mech diff
Hey,
wrote off my r33 gtst skyline in a drink driving accident a few years ago, was planning to put the diff in and go drifting :)
its a Nismo 2-way locker, 5 stud axles, no need for it anymore. On the flipside if you give me an r33 ill happily put it in and use it :P :1310_thumbsup_tone1::banana:
Price $650 or nearest reasonable offer.
postage at buyers expense.
Joe Liersch
0439615986
[email protected]
2371 borung hwy warracknabeal vic.
Edited by joe2548
  • Like 1
https://www.sau.com.au/forums/topic/466710-nismo-2-way-mech-diff/
    • Unlikely, as per Greg's post. This is not helical diff behaviour unless one wheel is up off the ground. Shimming what? You don't "shim" a mechanical LSD. Probably not in the sense that you have heard of people "shimming" a diff. And the process that Nissan f**kwits call "shimming" a diff involves super-preloading a VLSD cartridge against the side of the diff to create a friction/wear point (in a place that it wasn't supposed to have one) to make the sloppy, useless, viscous diff into a hybrid viscous/mech abortion. In case it isn't clear, I consider the process to be stupid. Nike.
    • How much does the shifter move when the car is in gear with the engine off? If it is more than about 1cm you need to replace your shifter bush. Your shifts will just get crunchier, not faster, with a short shifter unless you also rebuild the whole box
    • I should video mine, will prob do it tomorrow    Between 1st and 3rd, you could fit another two gears. That is how loose and wobbly it is   horrible:(
    • Throws on the FS5R30A in most Nissans of this era are actually quite short and direct compared to any remotely modern BMW with the S6-53 transmission. Those things have throws a mile long with rubbery vague everything. Synchro issues combined with a short shifter is just going to break everything even faster.
    • Only thing I'd add...is on recommendation from a good diff shop, I've used mineral oil in my diff including the race car for years. The synthetics can be too slippery and glaze the gears
