Skyline V36 coupe - Wheels offset fitment
Just like the sedan thread, rather than store all the pics and info on my computer I might aswell put it all out on the net for others to use....
Skyline v36 coupes actually have wider arches than sedans, hence a new thread
285/30/20 on a 10" wheel +32 offset
Edited by R377
WORK Gnosis GS5 Wheels
Front:
20 X 9.5 +20
Hankook V12 245/30/20
No camber kit or modifications
Rear:
20 X 10.5 +30
Hankook V12 275/30/20
No camber kit
Trimmed fender liner
Cut rear bracket (Not completely off)
Rays TE37 TT Tokyo Time Attacks
19 x 9.5 + 22 on 245/40/19 ----> camber specs are -1.25
19 x 10 + 35 on 285/35/19 ----> camber specs are -1.50 with trimmed bracket.
Dropped on Tein Flex Coilovers with SPC Front and Rear Camber and Toe kit.
bit sunken but here for reference - might need a 10mm or 15mm spacer especially for front since you can run 19x9.5+35 with 245 on a sedan.  I think coupe guards for v36 coupe are approx 15mm wider than skyline v36 sedan.
Avant Garde M310 in Dolphin Grey
19 x 9.5 +38 on BFG G-Force COMP2 - 245/40/19
19 x 11 +36 on BFG G-Force COMP2 - 275/35/19
Camber arms used although doesn't look to be any camber to it...
Wheel Brand & Model: Work T7R wheels
Wheel Size/Offset: Front: 19x9.5 +25, Rear: 19x10.5 +32
Tire Size: Front: 245/40/19, Rear: 275/35/19
Big Brake Clearance: Plenty of room
Suspension Modifications: Eibach Pro-Kit, SPC front camber arms, rear camber bolts. No rubbing, Camber in spec, no body modification needed.
Vossen wheels VFS1 - Matte Graphite
Wheels:
  • Front: 20x9.5" +25 (Mid Concave)
  • Rear:20x10.5" +40 including 5mm hubcentric spacer (Deep Concave)
Tyres:
  • Front: 245/35R20 Continental DWS06
  • Rear: 285/30R20 Continental DWS06
  • Lowered on Eibach ProKit, front and rear SPC camber kits, camber is within OEM spec but on the far negative side. No rubbing - my rear fender liner has been trimmed previously. My bumper bracket is not trimmed.
Rays Gram Light 57xtreme's wheels
19x10.5 +43 305/35 R19
19x9 +35 255/40 R19
Tires:  Rear - Nitto NT05R
Front - Nitto Invo
KWv3's coilovers.
No rubbing, no grinding. Just bolt and go. You'd probably have to cut down the rear bumper mounting bracket if you haven't already. Camber is within spec at all four corners.
Rear guards have not been rolled, just the factory roll. Plenty of clearance from the lower arm. The bolt however is closer. There is about 3MM of clearance. I drove it hard around some tight bends and the tyre didn't flex enough to rub.
If you want to run 305's, this is the setup you want. +43 on the offset and no wider than 10.5.
  • Like 1
Vossen VFS2 Gloss Graphite wheels 20x9.5+25 and 20x10.5 +45 rear Toyo 255/30/20 & 305/25/20
H&R Spacers F&R pushed out to 20x9.5+5 for front and 20x10.5+35 for a wider stance
air bag suspension
Edited by R377
    • I tried my best, well I see how it is though... It's time to be ruthless! I'll up my bid with a JVC sub and an amp to run it, 8 stainless steel drink coasters with a rubber backing, and a photo of Tom Cruise. Oh, I can increase the cash portion by 20 cents if that helps.
    • Or if it's grey, is it watery? Does it do it after you've been for like an hour long drive it will still do it, or just near the start of the trip? As GTS said, does it seem like oil (blue), water (white/grey) or fuel (black)? Sometimes the colour can be hard to see clearly too for what it is, as GTS says, what's it smell like?
    • I wonder if part of it has to do with when you've each bought the kits. I honestly have the feeling that the silicon joiners in the 2000s were actually better quality than most of what you can find these days. Even in the same brands. Everyone racing to the cheapest price while still trying to make profit means lower quality parts. For coolant, I personally would be going with rubber, OR, converting the radiator and engine to use the huge AN fittings hose for radiators.
    • If shift solenoid A is bad, that explains limp mode --- now you're in the same position as I mentioned previously, in that the next step is to confirm loom/wiring integrity from TCU to gearbox connector with a multimeter (the TCU cannot detect a broken wire, which can happen ..ie; rodent damage, loom rubbed through)...and then finally measure resistance (at the gearbox connector) for shift solenoid A ... ...once you confirm shift solenoid A is bad (open circuit, really low or greater than 40ohm resistance), then it's a job ; you have buy a complete solenoid set, get under the car and drop transmission oil pan, and remove valvebody assembly (the solenoids sit on top), replace solenoid set, and reassemble....it's not exactly a fun task, but readily doable.
    • Is it oil smoke or fuel smoke? They smell different.
