F.S-RB20 AfterMarket Performance Parts New
Hello All!
It has come time for me to clean up the millions of parts from around my house and shed as the landlord demands it :( I will list all the stuff that I can remember still having in as new OR actually new condition. Most came off my R32 which was a daily driver for 3 years then decided to turn into track car. All parts are neg.
R32 RB20DET USED 5 speed manual box - Works fine (apart from the fact I broke the speedo sensor top off whilst changing clutch) so runs fine except speedo does not work unless you replace the top mounted thread bit. Around 83-85K old. Had changed the oil with shock proof twice at great expense twice whilst owner. -- $500ono
TurboSmart Boost Tee - Brand New manaul boost controller in the box, brought 2 of them when they where on special and never got around to putting one on. Retail $180 at SuperCheap  Selling for $70 each
R32 Stock Airbox - Great to have when the cops are being jealous wankers cus they dont have a pimping skyline -- $50
Turbo Bits And Pieces - I have a shit load of different turbo housings for almost every turbo you can fit to a RB as well as a few exhaust turbines and different Oil and water cooling lines. Prices start from $10 each.
Stock R32 Factory alloys in good condition set of 4 with approx 45% rubber $400 set.
3 x Different RB injector combinations full sets Used but in good working order, one set stock with rail and regulator and the other two sets larger capacity from $100 set.
Stock and Custom made Dump pipes for almost any turbo - I custom made a few of these over the years from $50 each
After Market Exhausts - Fujistibo rear mufflers, some HKS 3 inch pipes and a cannon make an offer $ONO
MOMO Track style real leather steering wheel -- $80
Defi Advance CR Turbo Boost Gauge complete kit BRAND NEW cost $270, selling for $130
Timing Belt and assorted belts full sets all brand new -- make an offer
Rear Spoilers - I have a large Supra design $75 and a low mount standard type 200sx $50
I also have a SHITLOAD of other stuff that I have collected and thought at some stage may need for some reason in the future that suits not only skylines but also some Mazda RX-7 old school bits and also Subaru WRX bits like a brand new Greedy FV BOV full kit to suit EJ20DET with all mounting hardware,hoses and adapter plate to fit stock intercooler NEW $160
Please dont hesitate to email me at [email protected] OR call or txt me on 0415931283 for more info.
Note emails and txt preferred as I am mostly working of which not allowed to use my phone. And any interstate or country buyers welcome as long as they are willing to pay any freight costs for larger items. - small parts like $12 more.
Cheers and Happy Boosting!
    • If you are genuinely considering trying to get this engineered, I would strongly advise finding the engineer that is happy to sign that off first before you put the hole in your car.  I've seen cars get defected for this and not be able to be put back on the road as no engineer they spoke to was happy to sign if off.
    • Apologies, while id like to put the MAF as close to the TB and relocate the recirc, this may be too much work. Will most likely end up just putting it on the original AFM spot ( onto/next to the airbox ).  Was going through nistune, found a pretty nifty doc on this. Nistune MAF Notes. Also, i was looking through the bay, and there seems to be a tube/line connected from the A/C to the intercooler piping ( Between the smic and the recirc), what does this do as the crossover fmic piping doesnt have any connection? plumbing? not sure what you call it but the nipple thing ahah.  Also, been reading up more about crossover fmic in regards to the legality of having the hole drilled for the piping, this would most likely need to be engineered right?
    • My advice is if you need a big build done do it in Japan. The yen rate is so favorable and there are shops that can be genuinely trusted and not micromanaged/carefully monitored every step of the way. Garage Yoshida is obviously my preferred option but they're so busy these days and all interaction with new customers has to be mediated through BBL/Toprank now.
    • I haven't....but a poorly made one would terrify me. Surely a good second hand one is the go, as they don't work hard and no-one wants to keep one after they are finished with it A big consideration would be the weight of the shell you are putting on it....is it a fully dressed chassis or just the body
