Whiteline snapped rear upper arm
Whiteline quick clip suspension arms
These are the next thing to hit the scene. I currently have the first set in the country and let me tell you, these things are incredible!
But seriously, what do you think happened? has anyone seen this before?
Whiteline has come to the party and sent me a replacement rod today. No more stance life.
The smooth bit is completely smooth. It starts at the very first thread from the centre nut. Either a machining defect or stress over a long period of time. Whiteline hasn't given me an answer yet though.
That's fatigue failure. Started at the thread.
 Are they rolled or cut threads?  Looks like it's been loaded in bending.  If the bush in the pivot was binding it might be enough to cause the fatigue to start.  Bolts hate bending stress.
  • Like 1
38 minutes ago, Smally514 said:
It was a good two hours on the side of a closed off road quickest cotter run I've ever done :D
I didn't get till around 8 haha
Again, thanks for staying with me the whole time :cheers:
19 hours ago, Trex said:
I couldn't tell you. They look cut to me.
I was thibkjust by maybe at full droop and back to compression may be the cause. Is that what your saying?
They will have to be routinely checked now.
Is the smooth part (called beach marks,  or crack propagation zone) towards the top / bottom of the rod when in normal position, or towards the side  (i.e. is the line at the edge between the smooth and rough parts horizontal or vertical with the arm in position)?
If the beach mark area is towards the top / bottom then it sounds like the bush is binding. Poly bushes are notorious for being sticky  (hard to rotate around the pivot ). That's bad in a suspension system for a lot of reasons, one of which being the bending loads they can place on the arms.
As you suggest,  it could be bottoming out,  which could be overloading the arm too.
When you refit the arm, make sure that the arm is free to pivot through the full range of motion before you refit Springs and the rest of the suspension.
  • Like 1
Yep the smooth section is dead vertical on the bottom.
I did notice the bush was captive in the mount. You could pull the arm down and it would fling back into place horizontally how it was installed. In the back of my mind I thought the sleeve should protrude and be the main contact but thought whiteline would know more than myself.
I will have to grease these sections of the bush and get some lock nuts.
I will have to take a video and send it to them.
They suggested I need their traction rods to help aid in the stress lol. I can't see how this will help at all when the new traction rod will be the exact same length and stock.
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
