Whiteline quick clip suspension arms
These are the next thing to hit the scene. I currently have the first set in the country and let me tell you, these things are incredible!
But seriously, what do you think happened? has anyone seen this before?
https://www.sau.com.au/forums/topic/466758-whiteline-snapped-rear-upper-arm/
Whiteline has come to the party and sent me a replacement rod today. No more stance life.
The smooth bit is completely smooth. It starts at the very first thread from the centre nut. Either a machining defect or stress over a long period of time. Whiteline hasn't given me an answer yet though.
Who needs air bags when you've got link snaps!
Instant camber for the EOMM or car park meets lol.
Lucky no one was hurt or any injuries were had on the car.
Funny how a premium product can snap like that.
  • Like 1
That's fatigue failure. Started at the thread.
 Are they rolled or cut threads?  Looks like it's been loaded in bending.  If the bush in the pivot was binding it might be enough to cause the fatigue to start.  Bolts hate bending stress.
  • Like 1
19 hours ago, Trex said:
I couldn't tell you. They look cut to me.
I was thibkjust by maybe at full droop and back to compression may be the cause. Is that what your saying?
They will have to be routinely checked now.
Is the smooth part (called beach marks,  or crack propagation zone) towards the top / bottom of the rod when in normal position, or towards the side  (i.e. is the line at the edge between the smooth and rough parts horizontal or vertical with the arm in position)?
If the beach mark area is towards the top / bottom then it sounds like the bush is binding. Poly bushes are notorious for being sticky  (hard to rotate around the pivot ). That's bad in a suspension system for a lot of reasons, one of which being the bending loads they can place on the arms.
As you suggest,  it could be bottoming out,  which could be overloading the arm too.
When you refit the arm, make sure that the arm is free to pivot through the full range of motion before you refit Springs and the rest of the suspension.
  • Like 1
Yep the smooth section is dead vertical on the bottom.
I did notice the bush was captive in the mount. You could pull the arm down and it would fling back into place horizontally how it was installed. In the back of my mind I thought the sleeve should protrude and be the main contact but thought whiteline would know more than myself.
I will have to grease these sections of the bush and get some lock nuts.
I will have to take a video and send it to them.
They suggested I need their traction rods to help aid in the stress lol. I can't see how this will help at all when the new traction rod will be the exact same length and stock.
When installing poly bushings in the rear A arms, I did shorten the split bushings so that the arm would be able to pivot up and down without being able to move back and forth too much. Superpro ones were far too tight (ie too long).
Assuming they mean adjustable traction arms, they definitely can make a difference to both binding and bump steer...when you change the length of the main upper arm but not the front/traction arm you change the geometry.
    • I’d love to find some where that can recover the dashes to look brand new and original. Mine has a very slight bubble, nothing compared to some I’ve seen though
    • $170K. I asked one of the guys there as a joke if that price was just for the passenger seat as it was where the price sheet was... he tried really hard to crack a smile 😄 He also mentioned that every single part of the car was inspected and either restored or replaced with a new or as new part, or made from scratch. The interior was incredible, every inch like a new car.
    • Time for a modernisation, throw out the AFM, stock O2s, ECU into the e-waste bin. Rip out the cable throttle, IACV, pedal, etc. into the scrap metal bin. DBW, e-throttle, modern ECU, CANbus wideband, and the thing will drive better than when it left the factory.
    • I agree, don't go trusting those trims. As I said, first step is to put the logger away, and do the basics in diagnosis.   I spend plenty of time with data loggers. I also spend plenty of time teaching "technicians" why they need to stop using their data loggers, and learn real diagnostics.   The amount of data logs I play with would probably blow most people away. I don't just use it to diagnose. I log raw CAN data too, as a nice chunk of my job is reverse engineering what automotive manufacturers are doing.
    • I'm aware, but unless you're actually seeing the voltage the ECU is seeing and you're able to verify the sensors are actually working I find it hard to just trust STFT/LTFT. I will say, logging the ECU comes naturally to me because it's one of the lowest effort methods of diagnosis and I do similar things in my day job all the time. Staring at 20+ charts looking for something that isn't quite right isn't for everyone. NDS1 allows you to log almost everything so that's normally what I do and then sort out the data later.
