15 minutes ago, er34gtv said:
Try a new set of coilpacks and spark plugs and see how you go, they were the first things to die on me when i imported my 34 from japan at around 88,000kms. I bought yellow jacket coil packs and NGK iridium plugs to fix the issue.
I'll give it a crack mate
So did you have a similar issue to me?
18 minutes ago, Giaccovitch said:
Coilovers sorry mate
OK then but still coils are expensive so I would take them out, give them a good clean and try insulating them with tape or a spray and fit new plugs.
I just bought some splitfire coils, when they arrive I'll change plugs and see how I go
Had a problem with the coilpacks and/or plugs in mine. Was causing the car to missfire and jolt/hessitate while under acceleration, cruising and at idle. It felt like i was loosing power and over time it gradually got worse and worse until it got to the point i could barely drive up a hill. Replaced everything and havent had a problem since. Where are you located?
I'm in the northern suburbs in melbourne, I have no problems with the car accelerating or at idle, it's just trying to maintain a certain speed and sometimes when it neutral if I try to hold at a certain revs it jumps up and down a little. The coils/sparks have never been changed on the car so I'll give it a crack anyway, got coils coming in the next week or two
  • 1 year later...
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
