Jonic Posted September 11, 2016 Share Posted September 11, 2016 (edited) Listen to the Video, I thought it was the Belts and i tried spraying some Wd40 and it was better but then i figure there was another Strange Noise Sounds like the the Lifters but ive done the Lifter Tune up Lubricant, but still nothing, Got one of my mates and he said it could be your Rod Bearings worst Case Scenario Its a strange Chirping high pitch noise, similar to the belts. When engine warms up it quite's down but when i accelerate or Rev you can Hear it, Very Scary Noise ): What do you guys Reckons ?? PLEASE HELP ! Taking to mechanic this Weekday but just want to know if anyone has any knowledge. Don't want the mechanic to be Dodgy and rob my money !! Listen to the Video, HERE >>>>>>>>>>> Weird Noise From Engine.mp4 Edited September 11, 2016 by Jonic Fix Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/ Share on other sites More sharing options...
R_34 Posted September 11, 2016 Share Posted September 11, 2016 CAS bearing maybe. Unplug you CAS and rotate it by hand, if it doesn't rotate freely then it's the culprit. Definitely not rods bearing though. Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7774509 Share on other sites More sharing options...
hardsteppa Posted September 11, 2016 Share Posted September 11, 2016 Mine sounds like a quieter version of that, and is an exhaust manifold leak. It makes a chirping sound, mostly goes away once warmed up. Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7774517 Share on other sites More sharing options...
Jonic Posted September 12, 2016 Author Share Posted September 12, 2016 Yeah getting it check tomorrow at Edge Motorworks, Barry will know whats up Hopefully not something too major, Could be the Crankshaft hopefully not any Bearings though ! Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7774771 Share on other sites More sharing options...
Jonic Posted September 13, 2016 Author Share Posted September 13, 2016 So I just went to get it checked out and turns out it was the turbo gasket, apparently it's a common problem but thank god it's not the bearings !! thanks for the information guys ! Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7774871 Share on other sites More sharing options...
hardsteppa Posted September 13, 2016 Share Posted September 13, 2016 Yeah bwoyy. Exhaust leak ftw. Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7774877 Share on other sites More sharing options...
Jonic Posted September 29, 2016 Author Share Posted September 29, 2016 So in the end it was my timing belt, my harmonic balancer was off, changed the exhaust manifold gasket and turbo gasket and changed all my belt and bam fixed it all, and then changed my water pump and valve cover. Now it runs like a dream haha spent about $2k in total for parts and labour. Now I'm broke lol Link to comment https://www.sau.com.au/forums/topic/466762-whats-this-weird-noise-from-my-engine/#findComment-7779779 Share on other sites More sharing options...
