Not to be "that guy" but I've got an n/a neo thats looking at being replaced by a turbo neo in the next 12 months....regardless of the engine everyone seems to get great results from turbo'ing n/a motors but it seems to be the general concensus that they pretty much turn into hand grenades if you choose to go down this path...so my question is how many km's have you done since your de+t and how hard do you drive it? My skyline is my toy so I treat it mean but am fairly scrputenous on maintenence. I personally think im far better off dropping an already turbo'd neo motor into it...what is your oppinion? I want something thats going to last as opposed to a better low end torque curve.
For me doing this will be about the cost and the challenge. On the forum you'll find other threads including 666DAN's thread which (if you enjoy a lengthy read) shows that some guys ran conversions successfully long term. Parts have cost me a third of the price of the cheapest NEO DET engine. If you want bigger power then an original DET engine has way more potential. There's lots of info about taking the right precautions to stop them blowing up - hopefully it's right :-)
If you can afford it and potentially want to chase bigger power in future then you're probably doing the right thing dropping a motor (and ECU) in. You'll probably want a matching gearbox too if you want longevity.
Cant you piggy back the manual ecu's anyway? I only just read this the other day so perhaps its bullshit. I didnt think the gearboxes were any different between a turbo & non turbo 34 except perhaps the ratios, I was thinking gtr syncros though cuz I know the syncros in those boxes suck ass. I will be chasing a diff though, 4.11 is great but not for high speeds. If I can run 300kw eventually I will be happy, im only aiming for about 200 at the wheels at the moment though so I can get used to driving some proper power. Cheers for the info ill have a read
I did the conversion because I knew my de had genuine kms and being an auto it most likely hasn't seen a hard life and I wanted to get some hands on experience on our engines. After finishing the conversion, I made sure to check the garage floor for leaks before/after going for a drive and went under the car every few drives to check for anything unusual. Ive also never driven the car without having the nistune gauges displayed on my laptop just incase a fault is raised or something looks out.
There are a few things to consider before you make your decision.
I've done around 6000 kms after completing the conversion. I am an extremely spirited driver so the car is definitely not granny driven. I am fully prepared to have to drop a DET in Incase something fails which is why I try and push the car to see how it handles the conversion. The hardest few days it's seen is when I did 4 hours of constant driving over 2 days in 30° weather. The oil drain from the turbo half popped off because I didn't fully tighten the clamp. Fixed this in 30 mins at home so that would come down to user error.
To be honest, selling the car and buying a genuine manual turbo is always the best route. When it comes to resale, people don't want de+ts or manual converted skylines. Dropping in a DET is a good option as well and won't really effect resale as long as all of the Na parts on the car are replaced with gtt parts.
The thing about my 34 is that I'm too attached to let it go. Even in Na/Auto form, I was hooked the second I bought it. I'm the first person to hit boost/shred rubber in it which is an awesome feeling.
All that aside, reading the workshop manual and modifying the car myself has given me an unbelievable amount of knowledge. I cringe when I think about myself 3 months ago, barely being able to install a boost controller or wire a headunit. I still feel like I dont technically know much but I am now able to diagnose be plenty of issues and replace/upgrade parts on my own.
the n/a gearbox is the smaller rb20 type gearbox with a  push type clutch, turbo r34's come out with a much stronger and physically larger gearbox that has a pull type clutch.
  • Like 1
I'm pretty sure de boxes have the strength of an rb20 box. I was going to originally put a 20 box in after I turbod mine since people say it should be able to support around 200rwkw if not tracked but picked up a det box for cheap. Youll be able to achieve 200rwkw easily even with stock bits and if you've been driving it n/a, the power difference alone will keep you satisfied for ages.
Yeah, these are good points Aleks makes about changing over other DET bits too and there's a lot of those. NAs won't necessarily have extra bits like traction control, hicas, lsd. The suspension, brakes and fuel pump will be different (R34 NA suspension is same as R33). Have you upgraded your brakes and suspension first - or at least plan to do at the same time? These are all pretty important for the extra power and add to the cost which might make selling and buying a GTT a more economical option. Fortunately I did all that ages ago and got very good deals on the parts.
Edited by DatsunBanana
I can tell you I do have hicas & an lsd who wants traction control anyway f**k that haha. I was going to go to a walbro 255lph pump, nismo 550cc injectors, nismo s-tune suspension (coil-overs to stiff for roads out here) and r33 gtr brembos running on 245/35/18 possibly nankang rubber (cheaper and still perform well when hot), splitfire coilpacks (thats a given) run a 3 inch turbo back exhaust with a deleted cat and a 3076r steel wheel ball bearing turbo, front mount trust intercooler with twin thermofans (no clutch fan). I am fairly capable behind the wheel but by no means a racecar driver, this thing will be pushed well above 200km/h so it needs to handle and perform well.
Ah yes, another good point - exhaust. Forgot that as I already put a stock GTT cat back on a couple of years ago. Great that you have LSD - I want one. Mine had none of the nice options LOL. Hicas delete seems a popular mod anyway so probably not a make or break if you have it or not really.
Be interesting to see what cost estimates all this comes to for the various options. Mine's definitely been a budget build. Apexi suspension, GTT exhaust, R32 GTR brakes came in at 350 GBP. All the turbo bits are on target to come in at around 5. Just a turbo motor would have cost me £1500 GBP minimum. To sell mine and buy a GTT might have cost me 3-4K at GB prices but would probably have managed to get a manual for that.
Nice buy for $580AUD, I still need to install my 33 gts-t brakes. That's $2500 for a turbo engine in the UK wtf??? We have Facebook groups where people sell import parts, I've seen rb25det motors without Bolt ons for $900 - $1200 and full rb25det engines for $1100 - $1500 with compression tests. Maybe you could look at getting a manual setup shipped to you? I have no idea how much shipping would cost but it might turn out cheaper. You can buy full conversions for around $1300 - $1800 using an r33 gearbox. I can find you parts if you ever decided to, these are AUD prices btw.
  • Like 1
Yeah thanks. It's a bit mad what we have to pay for some stuff. You could get Skylines from Nissan dealers new in AU right? We only have imports (apart from a small number of GTRs) I've just waited patiently for the right deals to come along on secondhand parts. Some of the cheaper engines on eBay are without turbo and other ancillaries and then another time you'll see one with a gearbox for a couple of grand. It varies but you can see one of the reasons why I've gone the +t route on the NA engine.
Never saw the point in a catback personally, what is the point in 3 inch cat back exhaust if you have 2 inch restricting the exhaust gas flowing between the exhaust manifold & the cat? But perhaps im wrong. Hicas delete is great if you want to drift but I like high speed cornering so im sticking with the hicas. Im expecting at the end of it all to have pretty much been able to buy an rb26dett which im also well and truly considering
You guys are all lucky in terms of costs for this conversion haha. the cost of a good condition det motor in Canada is at the very least 1500+ and potentially double for the manual tranny attached.
The cost of me swapping to a gtt in better condition than my current setup is also gonna set me back 3-5k at least assuming I can get market price 10k and a decent gtt for 13-15k.
I honestly also feel the same way aleks feels about the car, in that I also pretty much wanted to learn and loved the car before the conversion talks. the exhaust part I also got done essentially subbed the original exhaust stuff a little in front of the cat to a 2.5 all the way through to a borla muffler at the end car sounds mean but quiet enough while crusing.
Heads up for anyone reading this thread and looking for a DET ECU there's a couple on yahoo auctions Japan at the mo ...
A manual currently at 2000 Yen and an auto at 6000
http://page17.auctions.yahoo.co.jp/jp/auction/v478256366
http://page4.auctions.yahoo.co.jp/jp/auction/d209093120
Aleks, just looking at the position of the nuts on the exhaust manifold. At least one seems impossible to get at with a socket. How did you manage?
Those prices are amazing.
It looks like the bolts are hard to undo but it's not too bad. I think I used a socket for all but one or two, used a spanner for those instead. The hard bit is cracking the bolts then most of them came off by hand, not sure if it's the same for yours but let me know how it goes [emoji106]
OK - that makes sense. For the last few weeks I've been regularly spraying WD40 on all the bolts/nuts I'll have to undo for this project. Hope that'll ease things a bit.
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
    • Hmm. I've gotten pretty good outcomes from talking to them about things that I've had go wrong or ideas for improvement. Have had a lot to say about the R32 FUCAs, and they have sent out some replacement parts for those, gratis, on a couple of occasions. Mind you, I have bought a couple hundreds of $ of replacement rod ends for them too!
