Short answer: Daily driving? No.
Longer answer: It could theoretically be done, but you'd have to get absolutely everything spot on perfect, and anyone who can pull that off has enough self doubt to want to verify the setup works correctly... by tuning it.
A Nistune is what you want. If you cannot afford a Nistune + Tuning time, or a plug in ECU for the Donor ECU you are using (Haltech, Link or similar) then this project is out of reach.
Yes, its a large expense for a DE+T that might make 200kw. This is also still the cheapest option.
On 16/08/2020 at 12:49 PM, Kinkstaah said:
Correct, this issue happens because
1) The NA Auto ECU cannot accept a Nistune
2) A GTT Auto ECU cannot natively run the Auto gearbox from the NA car, because the NA car has a seperate TCU.
You can wire the the inputs to the NA TCU into the GTT ECU on the correct pins and bypass the NA Auto TCU. Nissan have the wiring diagrams of both units available in the shop manual.
This has only been done successfully a couple of times. It isn't that hard, about ~20 wires. All clearly labelled in the shop manual. People just never tried it, or had need to.
So does this mean a better option for an R34 de+t is to run a stand-alone ecu (power fc, adaptronics, link etc..) or still better to run the gtt auto ecu with nistune?
A Nistune is kind of a stand alone ECU. You'd want some kind of tunable ECU, it doesnt have to be the bees knees, but you'd need to tune it to do it properly, because a NA+T is _not_ a stock car/tune, and even stock GTT cars get tuned anyway.
Just keep in mind the GTT auto ecu will NOT run a NA auto without wiring the standalone auto ecu that is in the NA cars, directly into the GTT ECU. Which may only work in theory, but the same pins exist in the GTT ECU that are seperated (for some reason? Maybe a good one!) to the GT standalone TCU.
Okay I feel like I’m getting more confused as this goes on haha, so from what you’ve said above: to use the gtt auto ecu you need to wire it into the tcu to control the auto. ORRR you can keep the NA TCU and run a completely different ECU seperate?
If you have an auto (which most people do when asking this question it seems) you cannot use the GTT ECU to control it plug and play.
You also cannot just leave it as is, and let the TCU control itself. The TCU by default wants to talk to the GT ECU.
If you want to use a GTT ECU *only* you have to wire the TCU into the GTT ECU.
If you want to use a standalone ECU for the engine, you either piggyback that off the GT ECU (gl with that) or have a complete aftermarket TCU to control the gearbox.
Go manual.
  • Thanks 1
Go manual.
Okay that makes way more sense. Obviously manual swap is the way to go, but for now with the basic power I’m looking for I’d like to retain the auto (grown to enjoy the tiptronic). I’ve already got the GTT auto ecu so will just sort out the wiring side of things.  Thanks for taking the time to reply.
Keep in mind noone has ever documented actually doing it. But if you have the NA ECU/TCU diagrams and the GTT ecu pinouts you can see that the GTT has extra pins that correspond to the exact pinouts of the NA TCU.
I am ASSUMING you can join/bridge these up. ASSUMING.
At the time I noticed this, I already had an aftermarket engine ECU, and an aftermarket Transmission ECU. I noticed this when I was re-wiring in the aftermarket transmission ECU as I swapped from a GT chassis to a GTT chassis.
I too, wish I knew this information before I bought a haltech, and a $2000 aftermarket auto transmission controller.
If it doesn't work, go manual, the NA box won't live long behind a turbo motor anyway. Even if built. I know that one too, from experience.
I was always of the same opinion as Kinkstaah that using a GTT auto ECU would be complicated. If you've got the R34 service manual, pages EC11/12 show that GT auto and manual have the same ECU wiring that uses a separate transmission control unit and the GTT auto has the transmission control built in to it. Page AT3 states that plainly. As per the diagrams, wiring for manual GTT ECU is same as GT auto/manual so that's what I used on my auto NA+t. It works fine and just uses the original GT transmission control unit to look after the auto box. As mentioned above, popular opinion is that there could be problems if the transmission circuit inside the GTT auto ECU creates conflict or doesn't talk with the GT transmission control unit still in the car. Pages EC13/14 will show you which pins are different and what they control. On page EC11, pin 79 of a GTT auto ECU (multiplex communication) is shown as only being for TCS/ABS but on page EC12 for non-turbo it also goes to the separate GT TCU. Pages AT8/9 have the transmission circuit diagrams (top right corner on page AT9 shows the connections from separate TCU to ECU). If you're gonna give it a go, those refs might help and if you get it working report back to feed the knowledge base. R34Nur posted a couple of weeks ago and said it worked fine with auto GTT ECU but that does go against popular opinion.
  • Like 1
  • Thanks 1
I think it can certainly be done, and upon reading the manuals you can see how it could very conceivably work as above. The workshop manuals are very direct and easy to interpret, surprisingly so!
I think it becomes hard because people do not read the manuals, do not have the gusto to compare the wiring diagrams and think "Well what if I...." and assume it will plug and play, which it won't.
It may however, be a wire-in job. It probably is, the only thing that throws me (personally) is wondering why Nissan went to the extra work of making two seperate systems in the GTT and GT. There could be some reason, but it may have absolutely no effect.
  • Thanks 1
  • 2 months later...
It's your idle air control. Both for idle speed control all the time and for fast cold idle via a wax pellet valve that also lives inside. It goes on the back end of the DET plenum. You cannot live without it if you are using a factory ECU. You can live without it if you're using an aftermarket ECU, but you will need to do soomething else for idle control. From a simple 2-wire idle air valve, all the way up to a proper e-throttle.
@Jack_Dubz if you're planning on running Drive by Wire sure launch it. However I suspect you're not so that needs to go into your plenum as that's the idle control valve.
Also I recommend installing OEM coil packs OR Splitfires OR R35 coils, whatever you have there will end up being another topic on SAU asking why your car is misfiring.
too fast, too furious
The Price of EVERY Car From 2 Fast 2 Furious! - Ideal
On 07/12/2021 at 6:52 PM, GTSBoy said:
Did. You. Not. Read. The. Replies?
Just found an adaptor thanks for your help.
For anyone looking for the adaptor here it is. https://otakugarage.com.au/product/otaku-garage-rb25det-neo-iacv-adaptor-for-series-12-iacv-flange/
    • Hey was wondering if you ended up installing the R33 GTR speed sensor - I found one too and wanted to confirm it's a direct swap into the R34 6 speed?
    • After 23 years of owning a Skyline, finally had the latch go.  Followed this guide,  works like a dream again. Great Guide 👍
    • Hi all,   I’ve got the biggest lot of problems with my R33 GTS-T   It was a freshly rebuilt 25th anniversary RB25DET (plastic cas, neo cams) probably 6 years ago now   The engine was running so well but I fkd up badly and trusted someone I’d known for 10 years that was well known around Plazmaman for his welding and fab work. I added a lovely photo of some of his previous work. Not sure why my car was worked on by whoever did this shit     I’m normally someone who would never open myself up to something like this, I still can’t believe I did it. Trusting him literally fkd it all up for me. Everything has been a struggle, like it’s almost been 6 years that’s how much I’ve just on and off been trying to work it all out.    All I wanted was a car that danced down low, like full boost from around 3~3500rpm to redline, don’t really care what power it puts down (if it ever does) but I just wanted it to be quick to get on it.    He recommended the turbo to get, I picked Hypergear but he told me to get the front 4” with a T4 and 0.68 rear housing.    I was expecting all these beautiful welds, tidy fab work and paid for it to be ready to go to a tuner when I got it back.    I got a car back that was an absolute mess, I actually couldn’t believe it was my car anymore. I don’t think you could even call what he did welds, they’re disgusting.    So I stripped everything he touched off it and with every bolt I loosened it just got worse and worse.    I covered it and literally built and finished another car in the meantime but now it’s getting to the point where I really want my Skyline back.   Its a struggle because I paid him to do all this shit because I didn’t know how to and now I’ve had to try and figure it all out omg    Please excuse the bird shit horrible welds, I’ve got my show pony car and am so beyond dealing with this car I don’t even really care at this point.    If someone told me about what he did to my car I wouldn’t have believed them but it happened to me. It was unbelievable. He went missing, my car went missing, it came back missing parts, the straight af chassis rails bore the scars of being dragged up a trailer backwards, even the sandwich plate was bent. Everything was leaking and open to whatever fell into it, rounded off/ missing bolts, power steering oil and coolant everywhere, no gaskets, parts stolen off it, even managed to damage the sump pan.   Promised me he’d finish the car, knew what it meant to me, I paid him thousands and thousands just for him to trash it. He told me he was fully licensed and insured, come to find out he’d cancelled his ABN, so obviously no insurance. I had laid up insurance on the car and would’ve been covered but I was scared they would’ve written it off or because the business was no longer trading I’d still be liable.    He was supposed to:  New fully custom mild steam pipe exhaust manifold with turbo location moved from factory position to high forward mount. (I don’t know if it is a mild steam pipe, I’ve got a funny feeling the waste gate isn’t in a very good position and I don’t think the outlets off each cylinder are equal) 4” custom stainless steel dump with external gate (he re-plumbed it) Cut and shut OEM intake manifold with throttle reposition (I ended up doing the throttle reposition) Box in pod filter (left out) New 100cel catalytic converter (pretty sure it’s there but unsure if it’s 100cel) Front mount intercooler piping fabricated to suit (all smashed up and rusty holes where he was supposed to make it look standard where fmic piping passes through. I don’t even think my front bar is going to fit 🙄) Custom 5” intake pipe from pod to turbo (didn’t come with it so had to do something to make it work with the Z32 afm)   Engine: Full cylinder head service & machining  Brand new valves Precision upgraded spring kit Engine block honed New bearings  New piston rings  New ARP conrod bolt kit New ARP head studs Cometic head gasket VRS kit   ATR43SS2 ball bearing turbo 0.68 rear housing  Turbosmart 45mm external wastegate (got delivered to the fab bloke, I’ve got no idea what spring is in it, I’m assuming the one that came pre installed) Walbro 260 fuel pump  Nismo 740cc injectors (tested to 880) Spitfire coil packs GCG FMIC RB25DET manual 5 speed 4:11 rear diff   I’ve got an Apexi Power FC in it atm, I was hoping to just get it to operating temp to make sure everything was okay before towing to a tuner but it’s over-fuelling too much. I don’t think that’s going to happen so i think I’m going to get either a Link G4 or Haltech for it. What do you guys recommend? I can’t work out the power FC so just gonna give up on that one     It’s got an exhaust leak coming from somewhere I can’t see 🙄    The fuel pressure was steady but now it like drops from 40 to 20psi randomly (noticed this yesterday)    I’ll attach pics of the shit he put on my car and the engine bay now as it sits    I really just need some help, I need a tuner in Sydney I can trust, I’d like to be with the car while it’s being tuned if possible, I know it looks terrible but unfortunately I’ve just got to put up with it for now and fix the cosmetic stuff later   Do you guys think the manifolds are going to be okay? Or do I throw the exhaust manifold and try again?   I don’t even think these combinations are going to work tbh   I know everything I fitted was rated to be able to take at least 400kW but most rated higher    If you’ve gotten this far I really really appreciate it 🙏 I don’t mind if you trash me or the car, I made a rookie error and f**k I’ve paid for it. As you’ll see 🙄
    • From everything I’ve heard you’ll be waiting a long time for  the parts to arrive
    • Have you looked at the workshop manual?
