Rectifying non-captive springs in Zeal coilovers
Hello all,
So, I've taken my new R33 GT-R through its rego inspection (in the ACT you have to go through the government pits. It's worth just going and seeing what they find as if you return with everything rectified within a month you only pay an additional $16 or so). Mostly all stuff I anticipated that's easy enough to fix, like the exhaust being too loud. The one surprise has been that the springs in the coilovers aren't captive under full droop, such as when the car is jacked up. For background the car is on Zeal coilovers (sub brand of Endless), unsure if they're function x or something else as I haven't had a chance to properly get under the car myself. I've taken it to my suspension guy (Ian at Revell in Fyshwick), who's said if I don't want to lower the car further the fix is helper/tender springs (people don't seem to be able to agree which name goes with which thing - here we mean the super low rate springs that coil bind as soon as the car sits on the suspension and only extend to pin the springs in place under droop) which will cost almost a grand after parts and labour.
Before I drop that kind of money I want to be sure it's the way to go, so I've been doing my research. So firstly I'd like to check I've understood the problem properly. As I understand it the issue goes like this. With coilovers unless they have independent height adjustment ride height changes are made by winding the seat of the spring up and down, adjusting the preload and how much it's squished by. Non-captive springs happen when the seat isn't wound up enough, allowing the spring to fully extend under droop and rattle around. Is that correct? What I don't understand is why a kit that I assume was designed for this model of car would have such a problem within its range of adjustment. Is it just operating at a ride height higher than the manufacturer intended?
Secondly, I obviously need to work out the best way to fix this. Again as I understand it the possible solutions worth exploring are:
  1. Lower the car more. It's not crazy low but clearance at the front is marginal already in a lot of environments including the ramp to my apartment complex parking. The current front splitter is already scraped underneath but I don't want to break anything, and ultimately I'm planning to put a carbon fibre item on and would like to avoid destroying it.
  2. Helper/tender springs. A decent chunk of money but will properly fix the problem, retain the current ride height and not mess with the properties of the suspension under driving conditions. Can also potentially be reused on other coilovers I might fit in the future.
  3. Replace springs with longer springs.
  4. Replace coilovers with different coilovers that don't have this issue at the desired height or with a separate spring and damper combo.
Whilst I'm thinking I might eventually replace the coilovers with Ohlins ones down the track, I had planned for that to be in several years after doing a bunch of other work on the car, as it seems the current Zeal coilovers are reasonably well regarded. Is that the case? I'm leaning towards just getting the helper/tender springs, but want to make sure I'm not just throwing good money after a bad setup. I'm planning to keep this car until they put me in a box, so want to do it right.
TLDR - Zeal coilover springs aren't captive under droop, should I fix with tender springs or are these coilovers junk and I should replace with a new system instead of spending money fixing them?
I could be wrong, and someone with more knowledge than I will surely come along and help, however, using the below pic of generic Zeal Coilovers as an example, the height adjustment is separate to the spring seat adjustment, so you should be able to adjust the Lower Spring Seat & Lock ring (2 rings below the spring) to fully captivate the spring at droop, (what effects this has on the ride comfort with pre-loading I don't know).
The ring at the very bottom is the one used to adjust the ride height, so if this is what your coilovers look like, you should be fine without having to adjust the height.
$1000 to install helper springs is ridiculous, pretty sure you can  buy them for about $50, but I guess there is a lot of labour in removing, pulling apart, reinstalling and aligning. but you shouldn't need to do this.
Hopefully.
  • Like 1
While I agree, they are kind of expensive if you take into account that you may need intermediate spring seats (between the main and helper spring) as well as the springs. and the labour assuming its not DIY
You could just lower the car so they are captive to get through the pits.....
I wouldn't swap out working zeals for new bilsteins, they are a reasonable shock and its not really an upgrade unless they needed a rebuild anyway.
My 32 had zeal coilovers on it when I first got it and mine were junk. They were the stiffest things I have ever felt and despite trying some much lighter springs to try and get some (if not ANY) travel they made little difference and were only fit for the bin. Bought a set of near new Australian made Shockworks coilovers which made an absolute world of difference!!
Okay, so I finally had a chance to get under the car over the weekend properly. GTofuS-T gets a cookie, they do indeed look like they're independently height adjustable, and besides that the springs spin but don't rattle so even if they're at full height already the lowering would be in the order of a couple of mm to fix it. They'd been slipping up more and more lately for me and a few friends, but I think I'll be going somewhere else for suspension stuff from now on!
Not that it matters, but for background the quote was something like $88 bucks a spring, $33 bucks a spacer and the rest was labour for fitting them and a full alignment. But that's money I don't have to spend now! Just need to work out what size range c spanners to get and I can do it myself.
  • Like 1
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
