Hi all,
Made some major changes to the car so the following parts are up for sale:
R34 GTt APEXi power FC with commander and boost controller- $700
PFC with hand controller, boost control kit harness, 3 bar pressure sensor and solenoid, great plug and play ecu and boost controller without having to cut and shut stock wiring, good condition had no issues, just selling since I decided to give e85 flex tune a go this time hence I'll need something different.
Hicas lock bar- $80
Comes with almost new tie rods, only used for less than 10000km, tightens the rear of the car and keep the back end planted. suits r33 and r34
Hardrace adjustable caster rod- $150
Adjustable caster rods, rubber version with the rubber replaced by Superpro urethane bushes, keeping it legal whilst getting a sharper steering
 suits r33 and r34 and maybe r32
Split dump- $50
Short split dump hks style to suit all rb20 and rb25 cars, heat wrapped, pulled 270rwkw with it on highflow turbo
Braided turbo lines (brand new)-$60
Mamba Braided water line x1 and braided oil line x1 to suit rb20 and rb25 standard turbo. Oil line suits standard ball bearing turbo, makes turbo installation and upgrades a walk in the park
Located in Sydney, Chatswood. PM if interested, happy to post at buyers expense.
Photos to come soon
https://www.sau.com.au/forums/topic/466810-lots-of-parts/
Got brand new Blitz SBC spec S for sale - $350
Brand new still in box, only opened up to take photo
It is the latest model and it is much easier to tune than previous SBCs
Was going to put it on my car but decided to just use the used AVCR I have pulled out of my old car anyway. So here's your opportunity to grab a bargain!
Located in Sydney will post at buyers expenseef89186aeeba921e6f1c9b903a231230.jpg1fe17051130895fd194ea950994dd848.jpgc3dc73bbf51cb7aef6e0d8ceb7f9c692.jpg2b5f28e86746e4ccecd434b9886f0350.jpgef10ebc4b72d393e2e161e1dbc07a6ff.jpg
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777659
Price drop, SAU Special!
R34 GTt APEXi power FC with commander and boost controller- $650
Hicas lock bar- $70
Hardrace adjustable caster rod- $120
Split dump- $40
Braided turbo lines (brand new)-$40
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777827
Also got a set of bronze/ gold buddyclub P1 racing 2 wheels for sale- $650
Size: 19x8.5 +38 offset and 19x9.5 +45 offset
Comes with 235 wide tyres on the 8.5 inch wide wheels and 265 wide tyres on the 9.5 inch wide wheels. All tyres have approx 60-70% thread.
The front wheels will not clear gtst and gtt 4 pot calipers due to spoke design, may just clear if you grind the Nissan logo away from the caliper, but since it's advertised on SAU, I will throw in a set of high quality GKtech hubcentric spacers, 15mm billet aluminum with high tensile extended studs and wheel nuts to suit.
Should fit the non turbo r34 with ease however.
Aluminum hub rings also included as part of SAU special.
They'll fit R34 and R33 non GTR cars without guard work, it was fine on my car lowered by 30mm.
Selling because I need to clear up some space in my garage, plus needed funding to finish off work on my car.
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778281
Still for sale:
Hicas lock bar- $70
Split dump pipe- $40
Surely there are some skylines out there still with leaky caster rod bushes and HICAS still attached. Good opportunity to upgrade the handling of your car without paying a premium!
The lock bar also comes with new tie rods and dust boot so you won't have to worry about getting new tie rods when you upgrade!
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778430
    • First up, I wouldn't use PID straight up for boost control. There's also other control techniques that can be implemented. And as I said, and you keep missing the point. It's not the ONE thing, it's the wrapping it up together with everything else in the one system that starts to unravel the problem. It's why there are people who can work in a certain field as a generalist, IE a IT person, and then there are specialists. IE, an SQL database specialist. Sure the IT person can build and run a database, and it'll work, however theyll likely never be as good as a specialist.   So, as said, it's not as simple as you're thinking. And yes, there's a limit to the number of everything's in MCUs, and they run out far to freaking fast when you're designing a complex system, which means you have to make compromises. Add to that, you'll have a limited team working on it, so fixing / tweaking some features means some features are a higher priority than others. Add to that, someone might fix a problem around a certain unrelated feature, and that change due to other complexities in the system design, can now cause a new, unforseen bug in something else.   The whole thing is, as said, sometimes split systems can work as good, and if not better. Plus when there's no need to spend $4k on an all in one solution, to meet the needs of a $200 system, maybe don't just spout off things others have said / you've read. There's a lot of misinformation on the internet, including in translated service manuals, and data sheets. Going and doing, so that you know, is better than stating something you read. Stating something that has been read, is about as useful as an engineering graduate, as all they know is what they've read. And trust me, nearly every engineering graduate is useless in the real world. And add to that, if you don't know this stuff, and just have an opinion, maybe accept what people with experience are telling you as information, and don't keep reciting the exact same thing over and over in response.
