Hi all,
Made some major changes to the car so the following parts are up for sale:
R34 GTt APEXi power FC with commander and boost controller- $700
PFC with hand controller, boost control kit harness, 3 bar pressure sensor and solenoid, great plug and play ecu and boost controller without having to cut and shut stock wiring, good condition had no issues, just selling since I decided to give e85 flex tune a go this time hence I'll need something different.
Hicas lock bar- $80
Comes with almost new tie rods, only used for less than 10000km, tightens the rear of the car and keep the back end planted. suits r33 and r34
Hardrace adjustable caster rod- $150
Adjustable caster rods, rubber version with the rubber replaced by Superpro urethane bushes, keeping it legal whilst getting a sharper steering
 suits r33 and r34 and maybe r32
Split dump- $50
Short split dump hks style to suit all rb20 and rb25 cars, heat wrapped, pulled 270rwkw with it on highflow turbo
Braided turbo lines (brand new)-$60
Mamba Braided water line x1 and braided oil line x1 to suit rb20 and rb25 standard turbo. Oil line suits standard ball bearing turbo, makes turbo installation and upgrades a walk in the park
Located in Sydney, Chatswood. PM if interested, happy to post at buyers expense.
Photos to come soon
https://www.sau.com.au/forums/topic/466810-lots-of-parts/
Got brand new Blitz SBC spec S for sale - $350
Brand new still in box, only opened up to take photo
It is the latest model and it is much easier to tune than previous SBCs
Was going to put it on my car but decided to just use the used AVCR I have pulled out of my old car anyway. So here's your opportunity to grab a bargain!
Located in Sydney will post at buyers expenseef89186aeeba921e6f1c9b903a231230.jpg1fe17051130895fd194ea950994dd848.jpgc3dc73bbf51cb7aef6e0d8ceb7f9c692.jpg2b5f28e86746e4ccecd434b9886f0350.jpgef10ebc4b72d393e2e161e1dbc07a6ff.jpg
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777659
Price drop, SAU Special!
R34 GTt APEXi power FC with commander and boost controller- $650
Hicas lock bar- $70
Hardrace adjustable caster rod- $120
Split dump- $40
Braided turbo lines (brand new)-$40
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7777827
Also got a set of bronze/ gold buddyclub P1 racing 2 wheels for sale- $650
Size: 19x8.5 +38 offset and 19x9.5 +45 offset
Comes with 235 wide tyres on the 8.5 inch wide wheels and 265 wide tyres on the 9.5 inch wide wheels. All tyres have approx 60-70% thread.
The front wheels will not clear gtst and gtt 4 pot calipers due to spoke design, may just clear if you grind the Nissan logo away from the caliper, but since it's advertised on SAU, I will throw in a set of high quality GKtech hubcentric spacers, 15mm billet aluminum with high tensile extended studs and wheel nuts to suit.
Should fit the non turbo r34 with ease however.
Aluminum hub rings also included as part of SAU special.
They'll fit R34 and R33 non GTR cars without guard work, it was fine on my car lowered by 30mm.
Selling because I need to clear up some space in my garage, plus needed funding to finish off work on my car.
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778281
Still for sale:
Hicas lock bar- $70
Split dump pipe- $40
Surely there are some skylines out there still with leaky caster rod bushes and HICAS still attached. Good opportunity to upgrade the handling of your car without paying a premium!
The lock bar also comes with new tie rods and dust boot so you won't have to worry about getting new tie rods when you upgrade!
https://www.sau.com.au/forums/topic/466810-lots-of-parts/#findComment-7778430
    • I had never actually looked into it, but aren't onboard compressors a thing in trucks?
    • Read the ECU for fault codes or have someone else do it. A faulty coolant temperature sender is usually listed in ECUs. If the sensor itself is not busted it can also be a bad ground connection. Or in a really unlucky case, damaged wiring.
    • Can't be a Futjitsubo as those are made with a flex piece and Reimax is smaller in pipe diameter. If anything it is closest to a Mines pipe, but evidently it is not an actual Mines pipe.   Classic word humor
    • Alright I will try to not forget.   As GTSboy replied to you already, problem is mainly the mismatch between the actual exhaust part and the denomination in the papers. That basically just looks like tampering to a cop, if they were to check your car and notice. If it had been done right they would have clarified it to be a custom pipe and just given it a certain part number that you have to engrave or weld onto the pipe. I will definitely inquire on what to do. Changing the pipe wouldn't be my favorite solution as it costs a bunch of money and the cat was fitted with the front pipe and exhaust under the car, and if the front pipe flange does not sit in the OEM location the cat will need to be refit for any other pipe to work. It also usually doesn't need a brand name or something like that, but more something like a part number. Usually for exhaust parts, on silencers and cat units specifically, there is a badge that reads the certificate number that belongs to these exhaust parts under EU regulation. You get these numbers after you put a part or group of parts through the tedious testing according to EU vehicle legislation and they pass. You can find these "part numbers" on various parts throughout a EU vehicle. On windows, headlights, engine parts, seat belts and so on. All these parts have gone through standardized testing and acquired a so called ECE or EG Certificate that makes them legal to use by themselves in all countries that adhere to these standards. You can also not alter these parts in any way, if you do they become illegal. An example for stampings on an exterior lighting part, the people who need to know can find the documentation for this unit in a database. I do not know what all the standards and so on mean.
    • If that was the case I suppose you could call it "Mein's" brand....  ... I'll see myself out... 😅
