2 hours ago, Dose Pipe Sutututu said:
^ yep!
then buy proper tyres, a proper LSD, proper suspension arms to fix up the crappy Nissan rear geometry.. If you can't even put 200kW down to the ground, don't bother with power upgrades.
But if you're single pegging everywhere, who cares brah! 300kW uleh.
  • Like 1
On 9/16/2016 at 10:50 AM, Dose Pipe Sutututu said:
^ yep!
The later model 34 GTTs have a Helical Diff yea? Is it worth the upgrade providing this is in a healthy condition?
I do plan to take her to the track, I'm assuming a true 1.5 way would be better...
Edited by macca911
For street, a helical is pretty much the nicest diff.
For track, a proper mechanical diff is better.  Especially if you have really high roll stiffness - where you may lift the inside rear wheel off the ground - or if you tend to hit kerbs hard enough to do the same.  Getting a wheel up instantly converts a helical into an open diff.
Also S2 R34 helical diffs are like hen's teeth and if you find one I would prefer you let me buy it.  Or at least the 5 bolt stub axles from it!
Edited by GTSBoy
On 9/16/2016 at 1:53 AM, hypergear said:
lets say. I can get you 3582's power with better then 3076's response. and much cheaper in price.
Hypergear, I'm listening... Would this be something like the Atr45sat?
Internal or external gate?
Cheers,
Thats the latest ATR45SAT RV2 model in ceramic ball bearing center. Is maxed at 330rwkws on 22psi p98 fuel internally gated Bolton, 20psi by 3650rpm, unopened neo motor.  Run that externally gated e85 it will be making around 400rwkws region. Check my fb or dyno sheet section for result.
  • Like 3
  • 1 year later...
Gents,
It's been some time since my last post.
The car has been finished and it made a super responsive 625rwhp and 680nm (e85)
I went with the following setup:
  • JHH Built RB25 Neo
  • EFR BW 7670 1.05 TS
  • 6boost Manifold with twin gates.
  • 2000cc Bosch Injectors
  • Haltech Platinum Pro
  • Hypertune Plenum + TB
  • PWR Intercooler and Oil Cooler
I can't recommend GT Auto Garage at Slacks Creek enough.
Their attention to detail in both fabrication and tuning is fantastic!
Still running the stock gearbox...
Cheers,
  • Like 3
It turns out every car I drove after mine felt like an absolute dog.
The EFR smashes the GTX3071 in every aspect.
I have unrealistic expectations for response it would appear relative to 100% of RB's ever built. I would assume that a 2.5 with a 7670 would be laggy, or at least laggier than mine. Still going to be better than anything else bolted to a 2.5.
The result does backup my thinking on the matter, that the 7670 is actually a pretty big turbo and is more a 450kw turbo than a 350kw turbo that people seem to consider it to be. Would be curious to see if there is speed sensor data as 466rwkw is really up there.
On 7/3/2018 at 12:04 PM, macca911 said:
Gents,
Cheers,
Very nice!  Can you please share the dyno plot?  The peak power is solid, but not the most interesting part of that setup :)
Kinkstaah Unfortunately I don't have a speed sensor installed. It's coming...
I have to agree, it must be pushing the limits!!
KiwiRS4TIt wasn't intentional... I've now got concerns for the gearbox etc... Matter of time haha.
E85 run attached. I believe the dip at 5400 would be VVT... Please correct me if I'm wrong.
Unfortunately, I'm in the US and only have the 625hp/640nm run photo on me. You'll get the idea though.
The final power run video is on the GT Auto FB page.
As always, bugs to iron out and more mods to do.
At this stage, I've planned as far as brakes and an accusump setup in the coming weeks...
  • Like 1
I would log your RPM vs. time, I wonder if the VCT turning off is causing some form of timing belt slap/vibration thus causing the CAS to spaz out.
That would explain the harsh dip
  • Like 1
The dyno run attached does look quite a bit like it could be VVT turning off too early, I'm assuming that's sorted now?
Saw a post on NZ Wiring's workshop page of a very similar setup/workshop which upgraded to an NZ Wiring CAS setup on an RB25 Neo recently, wasn't you by any chance?  Very solid delivery for an RB25 making that kind of power, though.  Should be a fun drive :)
  • Like 1
Nah, not me. I'll take a look though!
Not sorted yet... Mainly due to work commitments. I'll aim to spend some time on it starting next week.
Edited by macca911
(y) This is the post that got my attention btw: https://www.facebook.com/nzwiring/photos/a.263208990533912.1073741827.263205613867583/915378341983637/?type=3&theater
  • Like 1
big power, noisy valvetrain and Nissan's high resolution optical sensor (CAS) never works out well haha
VCT "shouldn't" be giving you a massive dip, I dare say (without any data) that there may be triggering issues
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
