I
On 9/21/2016 at 1:36 PM, r32-25t said:
Higher lift help a lot with power and maybe a little response but longer duration is a massive detriment to response, it's actually surprising how little duration it takes to have a big effect
Its also suprising how little duration you need to make big power..
there is so many overcammed rbs going around..people like to point out peak figures..it means shit..its all about the power under the curve and how wide it is with a h pattern!
cheers
darren
  • Like 2
On 9/22/2016 at 1:45 PM, khezz said:
So what would be your recommendation for cams. For the type of setup discussed in this thread. 2.6l, e85, 750-800hp turbo. Going for 500kw at all fours?
mine made 500kw on JEM's dyno with just a set of HKS drop in 256 cams 8.7mm lift
the problem with going bigger lift is the costs start to go up cause you need to mess around with the head even more
i was actually very surprised the cams didnt 'hold back' power as I was originally told go with 272 cams
JEM told me - lift makes power - duration moves the power up and down the rev range...
  • Like 1
Agree totally ^^
People are too quick to throw big lift/duration cams in these days to the point of even making up custom high lift/low duration and bashing the valve train unnecessarily when there is more important things to sort out.
Ive made 5540wkw on a portedhead with 256 9.5mm kelfords (basically poncams)  Smart money gets spent where the greatest gains per dollar are first [emoji16]
What's does your fuel system consist of, if it's not a secret?
Fire hose style lines and had to eliminate the injectors all together as they were providing a restriction just straight fuel line in the intake manifold does the trick for this bad boy
On 9/18/2016 at 8:37 PM, khezz said:
I should point out that this is not regarding any particular car. Just want to see experienced people's views. It seems that high mount twins are dead as dead can be. Low mounts are old tech.
My car will be getting a pair of low mount Gtx units. In search of 450awkw. The cost of engineering papers puts a high mount single out of reach.
so do you want feelings or factual numbers? because depending on a few factors their result will probably vary from yours.
I suppose numbers would be more useful. Different drivers will describe feelings differently. I have now been forced to go the single turbo rout. Going for the precision. So numbers would be great.
Holy, phone typo induces mass hysteria!
We were all very impressed and kinda worshipped you for a while. Thanks for ruining it.
So what sort of fuel system are you running. Fuel pump and injector size? Please
  • Like 1
    • Haha thanks everyone, I'll take everyone's suggestions into consideration. If I do eventually choose a car ill post it here update on the mods I do.
    • I found the ingredients at larger amounts from a Coffee Shop. 1kg Citric Acid for €8.50 500g Baking Soda for €2.50 I tried it out tonight distilled water (I got from my ACs) and dish soap. It does get bubbly with dish soap. In just two hours the hanger has improved significantly and rubbing against any remaining rust seems to flake it off. I'm going to leave it a little bit longer and see how it goes. I have read that someone even used this solution in an ultrasonic cleaner to clean a seized water pump which brought it back to life.
    • If you like more modern stuff than the R series, you should check out a V37 400R, they are pretty mod friendly
    • Haha luckily we don't have emissions, inspections, or any laws against power adders here. They only thing they somewhat keep an eye out for are ridiculously loud exhausts.
    • Just wanted to pop in an update on my setup. The CD swap has been great, I love the mazworks housing for the overall simplicity. I ended up sealing my trans tunnel with a thin sheet of aluminum reused some of the holes on the trans tunnel, and laid some window sealing EPS foam around the edges. Works great, really quieted things down and sealed up the car.  As for the power comment. Right now I am also running about 650whp. with the way the bell housing is attached to the face of the transmission I have zero doubts it would be fine, mainly because the input shaft and main shaft bearings are seated into the bell housing adapter. This means the load is NOT on the bolts to maintain the power, rather into he casing of the bell housing; Yes the bolts are doing some work there, but with both shafts locked in zero worries.  End of the day, the Mazworks solution is the easiest and safest. no need to take your trans to a shop to get milled perfectly, it fits with minimal clearancing, and you can use all your existing clutch and flywheel.  Driving wise the CD has been great compared to the big box, I'll probably swap my final drive at some point. The serial 9 shifter is gooooood, my only qualm is how tight it is, it takes a fair bit to get use to, 5th and 6th are a bit eh/hard to find at times, but maybe I need re-adjusting, and I think my clutch master is very tired and needs a rebuild.
