Spherical Bearings in Stock arms
I see a lot of ppl buying aftermarket arms, of course many want the adjustability however if you dont lower the car stupidly and dont need a fix roll centres etc I was wondering why dont more people take their strong and F*&K stock control arms, toe arms etc to a bearing place and get the rubber replaced with a solid bushing.
Thinking of giving this a crack. Any thoughts or issues with this or has anyone got experience with doing it?
https://www.sau.com.au/forums/topic/466836-spherical-bearings-in-stock-arms/
Having bent standard lower control arms and brackets in the front end if a R33, "strong as f**k" is probably not the word I would describe standard control arms. Not that I would recommend super strong control arms... I'd rather the arm bend or break in an accident rather than the mounting points on the body of the car.
The main issue I see with the idea of spherical bearings in standard arms is that the kind of person that wants to eliminate all potential slop in the suspension at the cost of NVH is also the kind of person that wants camber adjustment, which standard control arms simply provide hardly any in the rear end and absolutely none in the front. Not everyone uses adjustable for camber correction after "slamming" their car, some of us want -3 degrees for track days ;)
Here's the thing.  Of all the parts of an aftermarket suspension arm, the ONLY part that is not road legal is the spherical bearing.
My interpretation of the rules makes me think that you just need to get an engineer to sign off on it
https://www.google.com.au/url?sa=t&source=web&rct=j&url=https://infrastructure.gov.au/roads/vehicle_regulation/bulletin/pdf/NCOP11_Section_LS_Tyres_Suspension_Steering_Nov_2015_v4.pdf&ved=0ahUKEwiwwNSJ6ZXPAhWEmZQKHQn5C_EQFgggMAI&usg=AFQjCNFZ6jheyXhqRGWl3zaZ7qbZSGK2hg&sig2=vBG4FoqZkRegERGwLHFkqQ
Page 25
Spherical bearings deal with arm-mount gross misalignment issues when altering ride height and alignment.
Otherwise stick with rubber.  Far more durable than uniballs on the road, and won't flog out like urethane.
Too many people zero-in on the idea of "removing slop", when their changes have fundamentally shifted the alignment away from "right".  Adjustable length arms are far more important to making the car handle and feel right once moving away from stock.
  • Like 1
Talk to an engineer Matt, and see how they interpret that.  Perhaps they will.
Quick count I think there's at least 16 pivots/mounts that could go to uniball in an R chassis.  At ~ $100 per joint for quality replacement (no sane person would install low quality sphericals - would they??) there's a hefty bill for the suspension maintenance schedule - quite aside from the cost of the initial conversion.
I was going to approach an engineer until October 2014 when my R33 was written off in a flood. I had adjustable arms with spherical bearings on it and was a little concerned about defects.
I'll admit that if I were to do it again, I'd probably choose bushes over bearings... In hindsight the increase in NVH, the cost of replacement bearings and the stress of law enforcement attention (if engineered or not) just wasn't worth the "increased performance" (not that I could tell, I was replacing 15 year old OEM bushes with bearings, of course there was going to be a performance increase). Unless it were a dedicated track car, which I don't see my finances being good enough to handle at the moment [emoji23]
    • No......not yet Minister for War and Finances has stated that the Commodore has to go first Not that I am going to modify the NC any more than what it is already modified now.....
    • Thanks again, really helpful chap from alpha omega wanted to speak to me, little concerned if this is meant to he aero alloy/ airospace quality and car sitting on drive has caused this.  Airplane are subject to much more changing temp and conditions than road salts! My caliper, many other components much older have surface rust but never eating part of the metal   Had I not seen it , could have been a disaster! specifically on rear part of bracket coming off like biscuit will update on what they say, helpful people so far
    • January or Feb is it booked in for turbo fitment?
    • The MX5 has had some annoying rattles in both front doors over bumps So I installed fancy pants door bushings, which stopped all of the rattles with the windows up, but........with the windows down there was still rattles, so after some googling,  and a chat with MX5 Mania, I got some new door to glass weather seals, all the rattles, windows up, or down, are gone now Shout out to MX5 Mania, the weather seals were on sale, and when I head to Dural to pick the up they even fitted them for me for free I did see a "really" nice Blue NA sitting out front   and this Black NC PRHT that looked like it has sat in the sun for its whole life and never had a wash, the clear coat was non-existent, an it looked horrible, really horrible, but, it had a nice turbo kit with over 200kw, the thing went like a cut snake, bagging the rears through the gears and dosing like a champ 😍 But, as I've always stated, I am keeping my NC na, I'm happy with the current power the car makes In other news: MX5 Mania do a drive in drive out turbo kit, the only minor additional part recommended for boosting my car, as it sits now, is a oil cooler, and that bonnet vents are definitely required for track use Aftermarket version look a bit to "racecar" spec I wonder how Focus RS bonnet vents would look?????
    • Paint is only structural when applied to the outside of Chinese and Indian cars. Otherwise it should never be present between mechanical joints that were intended to be metal to metal. Pain slips, slides, cracks, compresses, and add thickness that wasn't intended to be there. It comes firmly under the category of "just no".
