I know I've been talking about buying a front bar for a couple of months now, but I have the cash in my hand and I want to pick one up ASAP.
I'm after a Trust style front bar for a S1 R33, as seen on the yellow R33 DEDSXE.
I have been told to go to either autObarn or Viva Garage, however I wasn't very impressed with autObarn Mile End when I was last there and I spoke to someone from Viva Garage at Autosalon who didn't seem to have any idea what I was talking about and really couldn't help me.
I know a few of you sell bodykits, so please PM or e-mail me your prices.
If anybody from autObarn or Viva Garage read this and believe you can sell me the above front bar at a competitive price, please reply or contact me directly.
And if any of you can recommend other places in SA to go, I'm all ears.
https://www.sau.com.au/forums/topic/46686-who-wants-to-sell-me-a-front-bar/
Went to autObarn today. They had the bar listed as $600.00 in their book, but said they couldn't do it for $600.00 and didn't know how much it'd be. :shrug:
But, they also said there was only one supplier in Australia for this particular bar, so jager's source who can do it for $430.00 is selling the same bar as autObarn is for $600.00+.
And Jager, the S1 Trust bar looks pretty much like a stock S1 front bar, which is why you ended up with a S2. Looks good though...
  • 3 weeks later...
Please check your PM, I'm the guy who sold jager the front bar, ring me on 040 45 455 or email me to [email protected], thanks.
*If you can order it within this this or next week, I can do that a bit cheaper than $430, because I had orders coming next week. So, ring me is the best way to find me, 0402 452 455.
    • That's the thing....the basics of fuel and ignition are deceptively simple.....getting it to behave like factory in all conditions after airflow mods is way more complex. Newer cars like the V37 are all about modifying the standard ECU which is about a billion times more complex than they were 20 years ago, with a bunch of parameters affecting others
    • The larger TB I had on the SS was a pain to get to idle right, but, that was cable In the end they just raised the idle up a couple of hundred RPM so it was happy idling away either in gear or in park (slush box life) I'm curious on how my NC will idle with the new intake, larger TB, and cams that are currently going in/on, but I have faith that MX5 Mania will sort this "electronical" "black magic" out the best they can in the tune with a electronic TB Sometimes I wish I knew more about the intricacies of tuning, but most of the time I don't because I know it would hurt my brain 🤣
    • That's the thing. Cam is smaller than before.. though the old cam was +6 degrees advanced. We're talking huge changes here, the narrowbands want to trim out 20% of fuel and pull the (wideband) idle to like 16.0 AFR or such. One side is a little more trimmy than the other. Think along the lines of ~20% to ~15-18%. Unfortunately my scouring of the internet hasn't really found anyone with this issue. People either just disable NB's or have them wildly different, where one is -20% and the other is +20 or 0 (i.e a sensor is just dead/wiring is just busted). Turning them off and relying on the base map only results in the wideband reporting at about 14.0 with the Varex closed. It'd be a little leaner (closer to 14.7ish) with the Varex open. I know I can just change the switch points so that the narrowbands agree with the wideband, but it's still odd. Both of them are reading voltage, it's just that they're reading quite high mv, in the ~800 region. It's just odd. This was with the IAT fudged to report it was about ~22 degrees which is my guesstimation of the temperature in the room. I have an OEM sensor ready to try tonight, which is slow and crap - but .. worked last time I used it. Sadly I am aware that idle tuning with the big TB is going to be a PITA and I look 'forward' to many hours spent stalling or stumbling idle or delving into drivability things.
    • The GTR strut brace clears the new manifold.. by about 0.5mm. So this means I need to buy an OEM GTT Strut brace (again), which will clear the new manifold, but not the bonnet vents. I guess I can sell the GTR Strut brace with the bonnet with the vents as a package deal as someone will need this one day. So my choices are vented bonnet but no strut brace, or GTR Bonnet with OEM brace (which I have to buy) but is bright red instead of the same colour as the rest of the car, which means the entire front end of the car will just be red until it goes back to paint jail. In other news the engine starts and doesn't leak. Why both O2 narrowband sensors think the tune is rich AF I do not know. The idle is also pretty shitty and my expensive IAT sensor from the USA is dead. The car sounds awful. But I assume or at least hope this is due to the many exhaust leaks, and the concrete garage it is in, sitting there with 0 intake bolted to it, and no bonnet or panels or anything to stop the induction/intake sound which is about 200db.
