The Attessa systems on R32 R33 and R34 are all different. It could be that the pump is the same but look very carefully at how they are mounted as e.g. R32GTR  and Stagea are quite different. Maybe between GTRs they are the same but have a look before you buy one. What sort do you want ? Is it for an R34 GTR?
If its just the accumulator you need they are about $400 from Nissan (here is a part number from an old thread 41630 20U00)
  • Like 1
I have a non vspec R34 GTR, and was thinking about trying a R33 GTR non vspec unit if they are compatible. Reason being is that R33 parts are much easier and cheaper to find.
I have already changed the nitrogen accumulator.
I have had problems with slow and inconsistent transfer of torque to the front. No attesa fault codes and it has been bled properly. The transfer case was inspected by simply levering on the plates on from the rear without pulling it apart, and the specialist said he doesn't believe it needs a rebuild. It has stumped everyone.
Last things left to try are replace the pump (cheaper) and rebuild the transfer case (more expensive).
 Share
    • Much less twat-tastic. CF wheels are too garish for civilised use.
    • From there, as the manual says....assembly is the reverse of disassembly, no tricks worth mentioning Much better (for me)
    • In my case, the standard wheel I had was in good condition but the buttons had more wear, so I swapped them across from the original wheel from the car. The plastic rear cover is held on by 4 tabs, and once the wiring is removed you can get access to 2 screws on each side the hold the buttons in From there I just swapped the wiring over. What was interesting is the standard style wheel is 2.0kg but the carbon fibre one is 50% heavier at 2.9kg. It even has a weight inside the wheel at the top to make up for some sort of imbalance in the design. weird
    • Once the airbag is off, to remove the steering wheel.... Undo the 2 plugs into the clock spring, and the horn connector from it's clip. Hit the 19mm nut with a rattle gun (preferably) or if you don't' have one, you probably want an assistant to hold the wheel in place while you use a breaker bar to undo the nut Then, screw the nut back on 3 turns, and pull the wheel sharply towards you. If that doesn't work hit it medium force with a rubber mallet on either side, or possible behind if you can get there. If that all fails (it shouldn't!) you might need a steering wheel puller
    • So, to next task....the carbon fibre steering wheel was either an expensive factory option or a chinesium special. Either way, I don't like either the flat bottom or thick ring style, so it had to go So...to remove the steering wheel.... First, disconnect battery negative and stomp on the brake pedal for a few seconds. Then, remove the small circular covers on each side of the wheel's rear surround to uncover the airbag clips. You need to push something like a flat bladed screw driver through, to push the steel clip inwards and pull the side of the airbag forward. Once you've done the easy side, same on the centre console side. You can see the tab you are shooting for circled in red Then, disconnect the horn spade connector and for the yellow airbag plug you need to get something small under the black locking tab to pop it out, then the connector releases......airbag is off
