R33 cold start
Hey guys does anyone here that runs a PFC get a delayed cold start?
By this I mean you have started your car from cold operating temp and usually cold start kicks in almost immediately but for some reason mine can take a few minutes sometimes...
This isn't a issue for me more so it's just annoying I can only assume either it's something to do with the Power FC or perhaps a dodgy cold start valve?
thoughts?
https://www.sau.com.au/forums/topic/466917-r33-cold-start/
do you mean it idles low initially, and then the idle rises as the car starts to warm up? that's not a problem with PFCs, its a problem with your tune, or air or fuel mechanical system.
it may be running too rich until the water temp rises and pulls fuel out, is it also missing at first?
https://www.sau.com.au/forums/topic/466917-r33-cold-start/#findComment-7777920
Engine idles at normal idle speed upon starting then sometimes can take a while to kick up to around 1200rpm
i may be able to check AFR through the hand controller but try to avoid messing around with it in case something goes wrong but I'll be sure to look into it
not gonna lie I'm pretty pissed about the tuning job that was done had to take the car back to the tuning shop because they failing to tune the AC on and AC off values in the pfc causing the car to stall upon turning the AC on ?
Cheers for the replies
https://www.sau.com.au/forums/topic/466917-r33-cold-start/#findComment-7778019
You can't see AFR through the hand controller you need a separate wide band to do that.
If your AC is causing the car to stall at idle it's too lean. So most likely your cold start is probably alright and it has a shit tune for idle.
AC puts a fair bit of load on the engine so takes a bit of fiddling to get it to run properly.
Easy to fix if you have the equipment to do so.
https://www.sau.com.au/forums/topic/466917-r33-cold-start/#findComment-7778084
I'm pretty sure the power fc has a self tune mode for idle and ac idle. It's been a while since I've had one but from memory you leave the car idling for around 10m and then turn lights on and ley idle again, then ac on and idle again. If you google, you shall be able to find the exact instructions on how to do that. May or may not fix your issue but definitely worth a shot. You can do it yourself and it's free.
https://www.sau.com.au/forums/topic/466917-r33-cold-start/#findComment-7778090
well the sad fact is that cold start tuning is a little fiddly compared to the easy stuff (full throttle power runs). Lots of tuners don't give it enough attention and I'd guess that's what happened here.  The good news is it is easily fixed by a competent tuner with a little time, and there's nothing wrong with PFC capabilities...
https://www.sau.com.au/forums/topic/466917-r33-cold-start/#findComment-7778111
    • Been a long time since r31 got some love, my brother dropped a shitbox ls1 crapadore in my lap to fix up.  Put a wiper motor in as the flooded one was no longer alive.  got windscreen wipers now. Time to clean respray and install back in the titanic  IMG_0505.mov
    • Nah its a server spammer thing  Although, now that I manually approve all the accounts I can probably loosen up some of the restrictions.
    • Thread bump, again! Although, no bad news this time. Posting for the sake of possible root cause. Basically, I rebuilt it (mostly stock), installed Haltech + sensors, had it running fine on new ECU.  Still not really understanding why it cracked pistons last time. Got to tuners, and while checking timing, noticed +-10deg of timing scatter while revving. Changed CAS, and it was rock solid. While not definitive, can't imagine seeing 20+ psi with that amount of scatter would be a good thing. Also glad I found something.   Bit more of a run down; Carried out a stock rebuild, a set of stock pistons, out of a spare bottom end. Everything stock apart from head studs and oil restrictors. (so I can pretend I didn't let the Nissan out, ha.) Armed with the measuring gear and FSM, set about doing overhaul. Oil restrictors as per oil control thread for a RB25, stock oil pump, drifting. Head drain/vent from rear of head, to passenger side of sump above oil level. Two dash 10 vent lines from drivers side of sump (unused atm) Hi octane style cam cover breather kit Splash covers over last 2 cam caps. Both breather lines from cam covers to vented to atmosphere catch can, not plumbed back into sump (wanted to see what it was actually breathing). Got it run in (did about a 1000km) no to low boost scenario, As I had questions over old ECU setup. Installed haltech +sensors for flex Retune on E85 (finding CAS Issue along the way), made 300rwkw at 20psi, out of wastegate. Did a drift day the next day (yes, it was a big weekend!) and was checking catch can throughout the day, ZERO blowby. I mean nothing. Lines from cam covers are not even wet. Done a bunch of street driving, spirited and catch can is still dry. Early days I guess, but pretty happy so far. Also now run 10w60, up from the 10w40 that I used to run. Oil pressure is significantly better, especially when hot (as you would expect)
    • Thanks buddy. I thought it was a server storage thing. 🤣
