That is true but will not sell skyline
will keep it and tune it later .
what is standard injectors good up to?
the issue is when I am calculating the cost it can easily exceed 8-9k in pounds which I could be putting toward an m5
i have split fire coil and think i can upgrade exu to link and turbo to straight fit ones which should give me 330 to 340 bhp at flywheel
i own an intercooler so can upgrade that as well for no cost
Or thinking more
I initially wanted to go all crazy with 500 bhp but soon realised it is too much work to do at this stage due to personal circumstances
I work 6 days a week and want to do it all myself
But i don't want to wait for a while to get time and also lots of expenses for this
So for short and maybe mid term i want to tune it so have much better performance than stock
Planning to buy m5 in few month
So far i have
Boost controller
K&n air filter
Splitfire coil
Okish intercooler . It is rated at 500bhp but looks like one of those chinese ones which is sold by a uk firm . It came installed
Coilover
Braided lines ..
Uprated brake (350mm) with brembo
What I want to do is
Walbro 255 - £80
Link ecu - £1400
Maybe injectors depending on current injector capacity £400
Existing turbo or direct bolt on ??
I have seen posts people saying you can change the ceramic shaft and others saying some firm make a modified t3 housing
I don't ideally want to change manifold and clutch
With above setup how much hp is realistic ?
I am thinking with around 2-3 k i should be able to get 400 bhp at flywheel
Is that too ambitious?
There are Nistune dealers in the UK.  Buy locally.
Buy the HG turbo from HG in Australia and just pay the $3.50 or whatever it adds up to for import costs.  Stop thinking about it and just do it.  Also get whatever he says you need to fit it (hoses, connectors, etc) from him.
You will need injectors.  Just buy 1000cc Bosch EV14 based ones.
You will need a Z32 AFM if you use Nistune.  That's the price you pay for not swapping to a completely different ECU.
Thanks GTSboy considering most of times you are sarcastic but thank you really:)
The import cost is 20% which is fine but what isn't is that I understood it as I need to send my turbo, they will change shaft and then send it back which means AU may charge import and uk do the same on return
If they sell one without sending mine then that will be great
Will get injectors. What brand would you get
As for AFM i am getting link which comes with a map sensor . I believe this is replacing the current afm installed right before air filter
( i read the difference between afm and map but can't recall it)
52 minutes ago, stranger12 said:
Yes but extra pressure can heat fuel up if not used
2 words.  Voltage control.
Also, don't buy a high flow from HG.  Buy an ATR to suit your power goal.  But even if you did get a highflow from him, you can just pay him to source a core for you.
Could you decipher this please :D
Who is HG and what do you mean by him sourcing a core for me
Apologies not sure what you mean by atr
Ok so when i install link ecu which comes with internal 4 bar sensor then that will replace the maf? Do i just unplug it
Would i need external maf if I am not going above 20-30 psi? In another word is therea difference between external and internal maf if i don't go above 20psi?
Should i get a new iat?
I am also researching voltage control so can install a bigger pump . Is there anything specific people use? I am wiring a new positive and negative direct from battery to pump to replace existing cables which cannot provide a higher voltage
ok I am about to buy the link plug and play
question I have is, my car is not running well due to boost pressure control ( Hitachi Bosch PS66-01) not working (un plugged).
I don't want to waste £120 buying that sensor so would you keep driving car as is with standard ecu or buy link and drive it with base map for a while ?
It will be good few month before I can take it for remap .
my real question is how reliable is link base map
There is no such thing as a base map.  ECU goes in while the car is strapped on the dyno.  Do not half arse this stuff.  Buy all the shit you need and do it all at once.  This half half stuff will cause you nothing but pain.
Why is the boost sensor disconnected?
the nipple which you connect the hose to is broken and brand new is between £120-150
an ecu is £1300 . the sensor won't be used when putting link it so wasting money really but don't want my car to run bad as a result
might just bite the bullet and get the sensor
Which nipple? If you mean the boost source I drilled and tapped a hole in the compressor housing - pretty sure the nipple was less than $10
Sitting down and thinking through this i am still going to get injectors, ecu and pump( bought walbro255)
Then really i am not saving anytime as rather than using hyper gear i could get twin scroll with internal wastegate
The only extra i need is exhuast manifold
The only hassle is custom downpipe. I am not paying fortune to tuners and do it myself so how do you go about getting the right downpipe sorted?
I guess the manifold will be a split design but you still get one twin port to mount turbo on
From turbo to exhaust would you have two pipes or one?
If I go top mount, does it fit in engine bay with my carbon bonnet?
    • Essentially, yes. Although I wouldn't put the AFM on the crossover pipe. I'd want to put it into what amounts to the correct size tube, which is more easily done in the intercooler pipework. I bought a mount tube for card stile AFM that replaces the stock AFM - although being a cheap AliExpress knockoff, it had not flange and I had to make and weld my own. But it is the same length and diameter as the stock RB AFM, goes on my airbox, etc etc. I don't have a sick enough rig to warrant anything different, and the swap will take 5 minutes (when I finally get around to it and the injectors & the dyno tune).
    • So to summarise, the best thing to do is to move recirc to between turbo and IC, and maf on the crossover pipe. Meaning I'd need a recirc flange, drill a hole in the piping on turbo outlet area. And drill hole on crossover to fit/weld maf sensor? Either that or put the MAF on the turbo inlet right?  Is an aftermarket recirc/blowoff valve recommended? Do currently have family in Japan so could probably bring something back with maybe a cheeky lil SuperAutobacs run?
    • Yep, so far most have said that it looks like corrosion on the wall from piston not moving. Which then has probably damaged the oil rings and caused those vertical marks. The longest the engine was still after the rebuild, was the winter of 2018 - 2019, plus the boat trip to Japan. When I shipped the car, it had normal gas in the tank but before that winter pause, it had E85 in tank.  In any case, even if either one of those was the cause, it happened close to 6 years ago and the car has been driven something like 30 000kms after the fact. Again, apart from the plugs and the dip stick, there is nothing in the way the car runs that would indicate what has been going on in the engine. I am going to consult a shop and ask their opinion, what would be the best approach. I do have some access to a garage I could use to diagnose further myself, but time is very restrictive. Might end up buying another engine that could be used while this one is being remedied. Without pulling the head, it will be impossible to find out if it needs another bore, but here's to hoping a hone would suffice.  Goddamnit, I would really have preferred this not happening.
    • Hi guys, has anyone either purchased or built themselves a rotisserie for their car before? I can only just justify the need for one hence why I should just make one but at the same time, if I make one I can kiss another 4 weeks of potentially productive car working time goodbye because I'm building a bloody rotisserie....  I mainly want it for the application of the body deadener.  Cleaning the old stuff off, priming and then colour over the deadener doesn't worry me, it's just the application using the Schutz Gun that I feel would achieve a significantly better finish painting it side on and keeping the Schutz Gun upright.  I don't think they would work well on the side let alone almost upside down for some areas.  If the product I use (Terosun, etc) could work through a HVLP ok then it might be ok to apply without the rotisserie.   I can get one of these style ones for about $1200 which is pretty good value-     I reckon if I made one it would cost around $500 but it's more the time that it would take is more of a killer than the cost.  They look to hold their value pretty well second hand so I could always sell it after using it and realistically only lose $200-$300 at worst.  Or keep it and buy another project when this one finally sees the light of day... Anyone selling one...? Cheers!
