Hey guys,
I'm reshelling my R33 after it got written off
Anyway I dropped the rear subframe yesterday, I knew the subframe bushings were gonna be cactus and they sure are.
Anyways I'm thinking I want to go with a hard bushing kit, I like it riding stiff, it's got BC gold coilovers in the rear, I want to do the diff bushings too
Been told GKtech are ok but what do u guys think? I don't want to do this again, because it's taken ages working all this shit out
I think the front end is all Nolathane, don't know how bad they are yet because I haven't dropped the front yet
Any input would be awesome, also is there anything else I should be doin while its out? I'm deleting hicas and just subframe and diff bushings
Didn't realise what I was getting myself in to with this rebuild lol
https://www.sau.com.au/forums/topic/466923-rear-subframe-bushings-please-help/
for a road car, I'd use anything you get. nolathene, whiteline, gtech, whoever
in my race car I did have to replace nolathene bushes again after about 10 years because they crumbled away but I think they'd be OK indefinitely for road use.
I would reconsider solid bushes for a street car. Being that it is subframe, I'm sure some decent polyurethene bushes would do the job perfectly and not create as much noise or vibration
If you decide on this, my plan is whiteline subframe bushes. Whiteline have always worked well for me
I was planning to go with nismo ones but haven't really compared prices. .. whenever I balance first gear I get a sound god knows from where but it sounded like the sound came from the rear. .. basically up shift i get that noise. .. down shift not so much ... have yet to really check what is busted ...
Lots of these cars have subframe bush issues by now, they take all the load every time you put power down....which can be often and a lot in a skyline.
If you haven't removed your subframe like OP a better option is to install some alloy locking collars, they slip in between the subframe and chassis and stop the car moving ont he bushes,  They are noiser than standard but if you can put up with that it saves a big job
    • Thanks for the info. The only "Issue" I've had with the shifter is I always found the throw between 4th and 6th gear too close. I'm always worried to shift into 4th accidently and sending my motor to the moon. Adam LZ recently came out with a video and stated Serialnine revised their shifters to correct this and will change all the revised parts for 150$. Strangely enough, I contacted Serialnine right after and they denied it and said it's bullshit. I found that strange as he's a distributer. I'll keep this forum post updated on that saga.
    • Yep that is correct. It allows you to adjust the short throw range from what I can tell
    • Car has been running great, I've put about 300km's of break in time on it. First thing that stands out with properly sealing rings is no more noticeable crankcase smell coming out of my catch can. This may seem insignificant, but the constant smell while driving around was infuriating. It's also nice to see my oil level remain stable. Two new issues have developed that I only noticed this weekend though. There's a very noticeable driveline vibration past 100kmh. I only noticed it now as I've been babying it under 100kmh in the backroads. This comes as no surprise as I'm running a one-piece shaft, and I paid zero attention to my driveshaft angle when I put everything back in. I also have a fair bit of voltage drop on hot starts. The starter audibly is forcing. No issues on cold start though. I must not have removed all the paint under my main block ground during assembly. I'll try and take care of both those issues this week once the kids are asleep.  I also received all the parts I was missing for my direct port setup. I will hopefully have pictures of that up soon. I'm hoping to get back on the dyno the week of June 30th as I'll be on vacation. I'm confident I should be able to make north of 500rwkw on pump gas and WMI. I'll go back again later this summer with E98, but I want to confirm my ethanol content sensor is working properly first. I've never seen it read anything but 11%. This makes sense for our 10% ethanol content pump gas here, but I would expect the occasional movement between fill ups.
    • 75% complete. Will now need to get a new axle with 5x114.3 hubs and then figure out how to customize some mudguards for it once the wheels are on.
    • Trailer prep is underway... Lined up the wheel to get a rough indication of how it would sit Then removed all the bits (as far as possible) and gave the frame a light sand and quick lick of paint   Then added some carpet
