I have this really annoying problem with my auto R32 Gts-t. It only happens when switching from light throttle to no throttle at low speeds. For example, driving in traffic or in a shopping center car park (just tapping the accelerator). As soon as I release throttle, it starts hunting and hesitating, gets all jerky, then snaps back into normal idling.
It only happens at light throttle, any ideas?
I've check the TPS. I'm getting proper voltage readings, approx. 0.5v closed and 4.0v WOT, and switches between throttle open and closed properly... Is it possible the TPS is at fault even if it's giving proper readings?
What else could cause this issue?
Thanks heaps.
Edited by rayj
I would have pointed the TPS but you checked it already.
Isn't the tps for auto different than the manual one ? I think it should have an idle and WOT contact on the TPS as well.
Otherwise dirty maf sensor maybe.
The variable voltage output on the RB20 TPS is only used by the transmission's CU.  The ECU knows nothing about it.  The ECU looks only at the closed throttle position switch.  The very best way to make sure that an RB20 has the TPS adjusted correctly is to use your hand on the bellcrank* to just crack the throttle open the tiniest amount.  What you want to happen is the switch to change state at almost no movement in the throttle at all.  You will hear the injectors double fire (which is what the RB20 ECU does when it sees the throttle switch change at idle).  Basically the sound of the injectors clicking just speeds up to double rate for something like 2 rotations of the engine (ie <1/2 a second).
The single most likely thing that is wrong with your engine is that the throttle body and/or the idle control valve are full of grunge and need a clean. The idle control valve being the most likely.  What is happening is that when the IACV is dirty the stepper motor on it struggles to make it move fast enough to change position.  When you are running with the throttle open, the IACV is too closed to run the engine at the right speed.  When you then close  the throttle the revs drop low while the IACV tries to open up.
You need to dismantle it and soak it in carby cleaner, give everything a good scrub and put it back together/on.
Thanks for your help. The Throttle body was taken off the car, cleaned thoroughly, then mounted back on with new gasket and torqued to spec. Much the same the entire AAC unit, completely soaked and cleaned thoroughly.
The problem still exists
I've checked for vacuum leaks, cleaned the AFM and tried resetting the TPS again. Same problem continues...
What I've noticed with the TPS, if I test it with Consult without the engine running, everything looks good. Closed throttle is approx. 0.5v and throttle switch is closed. As soon as throttle is opened, throttle switch changes to open, and throttle position will gradually rise to approx. 4.0v WOT.
However, as soon as I start the car, the throttle switch will immediately move from closed to open even though the throttle hasn't been touched (it's closed).
So then I adjust the TPS accordingly while the car is running, so that throttle switch open/closed occurs at the right time, all looks good, but the problem still persists.
This doesn't seem right, the output should be the same no matter if in the ON position or engine running. Why is the closed throttle value changing between ON and engine running?
The throttle will either be rotating a little because of air flowing across it, or possibly there is bearing slop and it is just moving in some other direction under the force of the flowing air which turns up as a change in the TPS.  Ultimately it doesn't matter what the TPS says when the engine is off.
to get the correct contact position for the throttle...
warm up engine, disconnect AAC valve connector, rev engine to 2000 then slowly ease off the peddle until the idle switch light illuminates to indicate throttle closed position, taking note of the revs the exact moment the closed position light comes on, this should be 950RPM +- 150RPM if it is not then adjust to suite. This why the tps voltage specifies 0.4 to 0.5 Volts.
    • Knowing how slow their other compressors are that connect to the cars battery, you'd want to hope it's one hell of a slow leak!
    • So why can’t the front pipe just be listed as custom make? why does everything have to have a brand name to it? or if you have bought the car like this and have no idea about anything at all or no knowledge what so ever of parts how are you supposed to inform them of what it is you have exactly?
    • Yep, I'd be interested to hear how it works out in the end.
    • Because all parts that are put into your papers usually are assigned a badging if they did not come with one. So other people can just check that badging to tell if it is the parts your papes outline. But my pipe has NOTHING on it whatsoever. No idea why this even passed as a Mines pipe to begin with. I see this going two ways: -nobody cares and it's a non-issue, but that is unlikely -the pipe will just have to be assigned a bagding, for sake of argument, a Mines logo, and the papers corrected accordingly If it interests you I will post what the actual solution ended up being. All I care about is that it has to sound equal length and nobody can screw me later on because of a pipe being illegal.
    • The fasteners to the pipe are not subject to TÜV I guess, if we really start putting nuts and bolts through technical tests I'm going to hang the people responsible and then myself. Usually on a modern-ish EU normed car, you would just replace the pipe. Because if you start hacking away at it and welding new pieces on the cops will definitely find a reason to tow your car. That is just how it is sadly. On old cars and imports with no clear "standard" stuff like that won't matter too much. Most cops or inspectors probably won't even really know what they are looking at. But there is experts for this stuff even among cops, and some of them know the rules to a T and even have extensive knowledge about many vehicles. For "just a pipe" to be legal it usually is included in a set of parts, like a complete intake kit or a full exhaust. For example my exhaust needs to pass a noise test, meaning they have a standardized test track with a set of instructions and they run the car through there 3x for an average noise value that is 75dB(a) at point x of the test track. If it's above that, fail. For a turbo setup to be put in your papers you have to do dyno runs, emissions testing etc. So quite costly
