r34 GTT brake upgrade
Hi Guys,
I have set of EBC 310 grooved and dimpled on my r34GTT
I installed it with ebc red stuff and I have to say brake performance is fu***ing sh*t
I think my kia picanto 1 liter is better than the skyline. I also changed the fluid to dot4 racing from castrol.
My hope is that I need to bleed the system and brake is ok. I have been lazy to do it as have hardly drived the car but I am using it frequently now.
I almost crashed it another day by failing to stop. it gets very soft and goes further down when braking hard .
Anyways, whilst I am going to do the bleeding , I thought I also change the caliper and rear discs to groved/dimpled.
It is the standard size of 310 at front and 295mm at back. would you invest £600 on pair of GTR brembo or change the disc to 350mm and get evo10 caliper and disc?
I spent in excess of £400 on the disc and the pads last time.
  • Like 1
https://www.sau.com.au/forums/topic/466946-r34-gtt-brake-upgrade/
1 hour ago, stranger12 said:
That is the typical answer!
i have and been searching, i have seen evo10 355 may fit
has anyone done it?
If you have been searching why are posting in the forced induction section instead of "suspension, braking and tyres" where there is a whole sticky on brake pads and the first post is on R34 GTT brakes? And a free tip - use Google for searching this site... and do the research before you spend the big bucks rather than after.
User error.
No way you're even going past the GT-t braking capabilities on the street. Many people use the same setup on their track cars and they seem to stop so there's no way you can possibly exceed their capabilities on the street.
Hey if you're keen on frying cash and funding any reason to do so, then that great but if you can't get a set of 310mm brakes to work then even a set of 350mm Evo brakes won't save you from installation error.
  • Like 2
I understand but I want to fix the brakes and ensure it is capable of stopping a 300rwkw car so hence the reason for my post
I was thinking to get gtr brembo caliper which are quite expensive
evo calipers are cheaper so I think it is a wise investment to change caliper and discs to evo 10
would i gain 25-30 braking power compared to original skyline?
Work out the current problem before going and wasting more money. Good pads, rotors, fluid and braided lines will stop a 300kw car no worries at all as long as they have been installed correctly
I upgraded the puny brakes on my heavy 320AWKW  Stagea  with GTT brakes and it was perfectly adequate on the street and even on the track for the first few laps. I only replaced them later for the track - would have been fine for street use.
Buy proper pads and discs, I owned EBC stuff too but for an S13 and OEM pads are way better than EBC shit. Rotors doesn't seem to be any better, they are way too hard so they just heat up and warp instead of slowing down the car.
cool, how do you guys bleed it using abs module ?
I don't have a software that can activate it , I normally bleed, drive for few hundred miles and bleed again in hope of all air from abs is bleed that way
I went ahead and bought set of evo 9 brembo calipers, it was £450 for two calipers rebuild plus red stuff pads
it looks cheap to me, how can I ensure it is actually evo 9 calipers and it is brembo ?
The brembo logo seems to be a paint only so anyone can fake. The guys claims he has also changed all of the pistons
http://www.ebay.co.uk/itm/262612438947?_trksid=p2060353.m2748.l2649&ssPageName=STRK%3AMEBIDX%3AIT
I can cancel it if it seems fake to you guys
Edited by stranger12
No idea whether or not they are genuine but as about 4 or 5 people have told you there is nothing wrong with GTT brakes if you bleed them properly and use some decent pads. if you go to the brake forum you will see info on how to bleed your brakes properly (needs two people for best results).
Are u getting a larger master cylinder to go with the larger calipers? Are u also getting larger discs ? They won't b any good if they r not installed correctly again.
Have u even taken it to a proper mechanic to even have a look at your problem?
yes I am getting bigger master cylinder later.
I just want to improve it now and know my brakes can break my neck if needed :)
I do everything on the car myself and know it needs bleeding but hardly use the car and now want to change it anyway for above reason
I will then change the backs to 350 as well in the future
    • Yeah, the latter. No diff should have a centre replaced without checking clearances because its unlikely to be the same as whatever came out. Not that that stops most people just checking a new centre in
    • Major thread necro but how bad of a job is it to DIY? Looking at it online it looks like if you reuse your ring and pinion as long as those are in good condition it should be fine to just pull the axles/front cover and replace the diff that way? Or should I be replacing everything and doing preload measurements/gear mesh testing like the factory service manual mentions for the rear diff?
    • in my list I had the R33 GTR as the best Skyline. Infact I had all GTR's (33>34=32), the NSX, the GTO, the 300ZX, the 180SX, the S15 better than the FD RX7. I had the MR2 and the A80 as 'just' better. I also think the DC5R Integra looks better but this is an 01 onwards car. I also think the FC>FD. It's almost like aesthetics are individual! The elements @GTSBoy likes about the FD and dislikes about the 180 are inverse in my eyes. I hate the rear end of the FD and it's weird tail lights that are bulbous and remind me of early hyundai excels. They are not striking, nor iconic, nor retro cool. The GTO has supercar proportions. I maintain these look much better in person (like the NSX) especially with nice wheels and suspension which is mandatory for all cars pretty much. Some (or all) of these you have to see in person to appreciate. You can't write a car off until you see one in the flesh IMO. Like most people we probably just like/dislike cars which represent certain eras of design or design styles in general. I also think the 60's Jag E type looks HORRIBLE, literally disgusting, and the 2000GT is nothing to write home about. FWIW I don't think the Dodge Viper Gen1's have aged very well either. You can probably see where I rate bubbly coupes like the FD. I know we're straying now but the C4 and C5 absolutely murder the Viper in the looks department as time goes on, for my eyes. Wouldn't surprise me if people who love the FD, also love the MX5, Dodge Viper, Jag E Type, etc etc.
    • I used to hate R31s, and any of the other Nissans that led up to it, and any of the Toyotas with similar styling, because of the boxiness. They were, and remain, childish, simplistic, and generally awful. I appreciate R31s a lot more now, but only the JDM 2 door. The ADM 4 door (and any other 4 door, even if they are unique compared to our local one) can eat a bowl of dicks. The Aussie R31 is also forever tarnished by their association with stereotypical bong clutching Aussie R31 owners of the 90s and early 2000s. I think the Nissans of the 70s (other than 120Y/180B/200B) are far superior looking to the 80s cars. The 240K era Skylines are boss. The same is broadly true of Toyotas. Hondas don't ever register in my thinking, from any era. Mitsus are all horrid shitboxen in any era, and so also don't register. Subarus are always awful, ditto. Daihatsus and Suzukis also don't generally register. They are all invisible. I think the SW20 MR2 looks fiddly. The 3000GT/GTO is like that but way worse. Too many silly plastic barnacles and fiddly gimmicks ruined what could have been a really nice base shape. Kinda-sorta looks like a big heavy ST165 Celica coupe (and I'm not sure if that's a good thing or a bad thing). I think the 180SX is dreadfully bland. It's not bad looking. But it has no excitement to it at all. It's just a liftback coupe thing with no interest in its lines, and bad graphical elements (ie wide expanses of taillight plastic on the rear garnish). The S13 Silvia is a little better - getting closer to R32 shapes. But still....bland. S14? Nope. Don't love it. S15...a little better. Probably a lot better, actually. Benefits from not being like a shrunk in the wash R34 (where the S13 was a shrunk in the wash R32 and the S14 looked like a Pulsar or something else from the stable on Nissan mid 90s horrors). The Z32 was hot as f**k when it came out but hasn't aged as well as the A80. Keep in mind that I think the R33 is the most disgusting looking thing - and out of all the previous cars mentioned is objectively closest to my precious R32. It's just....real bad, almost everywhere you look. And that is down to the majority of what was designed in the 90s being shit. All Nissans from that era look like shit. Most other brands ditto. In that context, the FD absolutely stands out as being by far the best looking car, for reasons already discussed. Going behind the aesthetics, the suspension alone makes it better than almost any other car.
    • If they just called it the "Mazda Tiffany", it would have been spot on.
