Hello everyone.
Its been awhile since i was here. Last time was when i was changing out rb26 guides to a bc units that needed to be cut to the right length. Simple truth the supertech stuff are the exact same as oem nissan rb26 guides no cutting just install. After i bought a tool that pulls the guid in the head. KEEPING in mind the head was very hot and guides frozen in nitrogen. I got the in with no problems, no galling nothing. It was all an experiment really. So i started to lap the valves, and yes now i have to have the seats cut to the new center line of the new brass guides. Wow. What a damn workout after all those tools i bought.
So i spent the last month and a half refecting on what i want to do. I could send the heads out, as i have 2 heads that are new and will need the works basically done to them. From guids to seats valves, relief cut for cams. Small bit of porting and so on.
This got me thinking. So i started looking into way i can cut the seats myself. And correct me is im wrong here but at minimum ill need a accuracy of 001 of an inch for racing, and the old school guys that used stones and blades to cut the seats were around 003 of an inch, as well as takes lots of skill at minimum a machine that can be bought today for about 15k usd.
I started to look at methods used to cut seats. I came across lots, one machine floats heads and machining bit on a cushion to find true center line. Next was one of my favorites Newen fixed tuning contour BB.
In short guys im looking to have my shop move into this field of machining, i enjoy the stuff. I want to redirect my funds to provide a service rather than waste it racing.
I know this topic might me in the wrong section, but there is reliance to it. First we know you need to cut seats when we change guides, next the method to changing rb26 guides i can show anyone if there willi g to pm me. Next we know the heads needs to be heated and guides frozen, so its not all a waste, last bc guides needs to be cut to size. I dont like that so go with supertech one i would say.
If anyone here can help point me into the right direction, like a head machining forum, or a place i can gather lots of info on methods to service heads cutting tools anything. I can see an initial investment of over 500k. A contour bb is about 80k new. But this is the path to my future. This is what i want. Ill be the first in my region if i can accomplish this goal. Thanks for taking the time to read over my thread, and i thank you in advance.
Marcus.
https://www.sau.com.au/forums/topic/466948-insight-on-valve-seatmachining/
If you are going to invest that amount of money maybe you could spend a few bucks visiting some top machine shops (in the guise of scoping out someone to do your heads) and see what modern day best practice looks like...and what machines they are using.
Thats in the books. As im taking a trip next month. Im also looking to visit some trade shows regarding the subject. But its all new so im searching where ever i can. I was hoping for a good machining form.
PM TK (Tony Knight) on Performance Forums. Adelaide guy, does engines and heads and is a guru and is usually fairly willing to help people out.  He is usually flat out busy, so don't be too taxing in what you ask him.  I would suggest asking what he would recommend for someone who wanted to set up to do the sort of machining you're talking about with low cost but good results.  Special emphasis on being in a fairly remote place (from Australia) and being not quite 1st world, if you know what I mean.
  • Like 1
    • When's the rear mounted turbo kit coming? Needs dose and V8 chop idle lol.
    • I was very unimpressed with how the car came up from the A pillar forward, before I hit things (twice). It all has to go. It had to go, but now it has to go... more. So we finally found the very first Shennanigans with the entirely perfectly setup engine that had no problems being pulled apart to improve on 'was perfectly fine'. Cam bearings looked a bit... stock. Which isn't entirely bad given they were stock and this is a ~20 year old engine. So new cam bearings are on the way because it's somewhat difficult to get to this stage to do it later, and it will trash the block. It was quite unusual that it wasn't done when the perfectly new-looking VCM cam was originally installed by [unknown] What IS unusual is the cam that was installed there was advanced SIX degrees. As to why there is no way to know.. however it could have been @Dose Pipe Sutututu's mate who wanted a larger cam sound but also wanted it to come on earlier to be more usable. This is my dyno sheet with the previous setup - This cam is not supposed to peak until 7000+ RPM, according to VCM. This is what lead me down the whole 'my heads/intake setup is running out of puff and can't support the cam' line of thinking to begin with. Anyway too late now - New cam is in! It could be rather funny if this smaller cam acts like a larger cam because it isn't advanced six degrees. In the spirit of everything is working amazingly - the COMP cam required no dialling in whatsoever. It was about 0.5 degrees advanced, which seems pretty bang on. Any adjustment either way would be further out. I'm told as a chain breaks in it ends up regarding back about 0.5 a degree as the chain breaks in, making it bang on. In the spirit of everything was previously working amazingly - The timing gear that was taken out turned out to be was an N-Motion double timing chain kit, with adjustable cam gear (which is how it was 6 degrees advanced) and all looks entirely perfectly new. It also had a Torrington bearing, which was one of the reasons I ended up getting the Cloyes kit which they used in the C5R 24 hour racecar - Because I couldn't confirm what was in the engine when talking to Tony Mamo. I did believe however it was a Double chain kit of some kind... but found no supporting documentation or evidence for it.
    • I recently did this to my R33 with the full set from Car Mats Direct, they can't do the vinyl anymore that's advertised on the website due to a supplier issue so I ended up with the Black Loop Pile which looks great. I went all out with rubber sound deadening sheets from Repco and also added the sound deadening foam layer option with the carpet. Makes a world of difference and got rid of all the weird smells in the 29 year old interior. It was a bit of work but I'd 100% recommend it, Car Mats Direct had awesome customer service and quick postage. Replaced my seats with some sporty ones from Autotechnia while I was at it, feels like a new car.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
