RB26 engine restore
Deza3000
 Share
RB26 engine restore
Hi Guys,
Thought id share my first time attempt at restoring my tired rb26 rocker covers and intake snorkel. Came out fairly decent and was pretty happy with the results.
Before (rocker): Not sure if you can see the paint flaking towards the middle of the motor
After:
Before (snorkel): Notice the worn out sponge, tired worn plastic
After: - Not the best pic, sponge was replaced
The rest of the bay still needs some attention but the hardest part was taken care of.
Also need to polish up the black piece on the spark plug cover, its a bit hazy. Not sure what product to use to restore it :/
12 hours ago, GTR_JOEY said:
Nice, where did you get the sponge?
Cheers mate.
It was something like this:
https://www.bunnings.com.au/raven-9-x-6mm-5m-grey-adhesive-foam-door-and-window-seal_p3970353
Make sure its the weather proof ones as they are more durable. Adhesive is strong so it does the job well.
2 hours ago, colourclassic said:
Haha I used the exact same sponge strip from Bunnings years ago for the exact same thing. Looks a lot better than that old brittle stuff.
Haha how good is it! How is yours holding up after 2 years? Not too shabby for 5 dollars.
 Share
    • They should do. I have S14 (or something S chassis, anyway) driveshafts in my R32 (because my diff flanges have 3x2). They're the right length. When you go looking for R32/3/4 driveshafts (for turbos), they're all the same thing, so are the same length. So there really shouldn't be any reason why those cheapies from JJ won't also fit an R34. R32/3 NA should also be the same thing. The (3x the price) D-Max ones are uni-fit. They have 5x1 and 3x2 bolt holes and say they cover all the cars. So that would also suggest that they are all the same except for the flanges. And in that case, the flange goes both ways. I'd be buying the D-Max ones if I ever have to replace a shaft. Because that will open up diff options without needing to juggle shafts also. Juggling shafts is gay.
    • Yeah with the adaptors they do look like the photo above - just the fitment within the plenum itself and then further with the rail to the intake is questionable - we shall see tomorrow hopefully once I get some replies from Aeroflow, maybe those bosses are the missing piece....
    • Should be fine, if you have it sitting too far in, you end up just spraying the walls and have shit idle. You "can" run them like that, however I don't think it's a great idea (also depends on your plenum, might be good to just get the injector bosses first, mock it up and see if you need to get the bottom extension) Ideally your injectors, with the extension should look like this  (Not my photos, just Google)
    • Thanks for the replies guys, it's really appreciated.  It seems the kit was supposed to come with those injector bosses but hasn't. Unsure if they'll help as even with the adaptors to make them a 3/4 height injector they still sit too far out so mount the fuel rail?
    • Hello, I am looking to replace my two rear drive shafts in my R34 N/A Skyline but I'm finding conflicting information. Do S13/S14/S15 or R32 NA/ R33 NA fit? https://justjap.com/products/gsp-premium-rear-drive-shaft-l-h-nissan-silvia-s13-s14-s15-3x2-type?currency=AUD&srsltid=AfmBOoqY7EwDaYCUoUU3mxxZ_qrUXkVVHiV4MIN7ozoar6scjnEiekv- would this fit?
