RB26 engine restore
Hi Guys,
Thought id share my first time attempt at restoring my tired rb26 rocker covers and intake snorkel. Came out fairly decent and was pretty happy with the results.
Before (rocker): Not sure if you can see the paint flaking towards the middle of the motor
After:
Before (snorkel): Notice the worn out sponge, tired worn plastic
After: - Not the best pic, sponge was replaced
https://www.sau.com.au/forums/topic/466979-rb26-engine-restore/
The rest of the bay still needs some attention but the hardest part was taken care of.
Also need to polish up the black piece on the spark plug cover, its a bit hazy. Not sure what product to use to restore it :/
12 hours ago, GTR_JOEY said:
Nice, where did you get the sponge?
Cheers mate.
It was something like this:
https://www.bunnings.com.au/raven-9-x-6mm-5m-grey-adhesive-foam-door-and-window-seal_p3970353
Make sure its the weather proof ones as they are more durable. Adhesive is strong so it does the job well.
2 hours ago, colourclassic said:
Haha I used the exact same sponge strip from Bunnings years ago for the exact same thing. Looks a lot better than that old brittle stuff.
Haha how good is it! How is yours holding up after 2 years? Not too shabby for 5 dollars.
    • Good morning all, Bit of a random question but figured I’d finally throw it out after wondering for a long while. Before I start, I'm hoping to do this purely out of personal preference. I think it would look better at night, and don't mind at all spending a few hours and dollars to get it done. I've copied this from a non-Skyline specific forum, so I apologize for the explanation of our headlight switch setup that we all know. Here we go: Zero lights (switch off) Parking lights (switch position 1) being a rectangular marker on the outside of the housing, my low beam being the projector in the centre (position 2), and a high beam triggered by my turn signal stalk. Most North American cars I’ve owned of this era have power to the amber corner (turning indicator) light as part of the first switch (parking lights). I’d love to have these amber corners receive power when the headlights and parking lights are on (headlight switch), yet still blink when using the turn signal which is of course a separate switch. Hopefully I’ve explained my question correctly. Is anyone aware of a way in which I might be able to achieve this? Thanks in advance
    • My heads are cathedral port! It's likely possible, but I don't want to add any extra moving parts (I know they don't move) between the heads, manifolds, etc. It will also affect how injectors/fuel rails etc sit and I don't really know if it would change how the FAST manifold goes/sits/fits. I have the LS6 steam pipes already as I have a very late LS1 block so it should be fine. I couldn't find anyone who had ever actually used one for this purpose, it seems 100% of people grind the water pump. The thermal spacers are 12mm and are half way to the cost of the newer water pump anyhow... so if it comes to that I suppose I'd rather buy a new pump. The bearing in the pump I do have is a little.. clunky, but it hasn't done that much time and I never noticed it when the car was together in the past few years, so..
    • The bushing has failed, not all that uncommon for a car of this age.  Any mechanic should be able to push in a new bushing for you, or you can probably buy the entire lower control arm, complete with bushes.
    • Could you not use "thermal" spacers to give the clearance, like the ones I used between the blower and head? That raised the manifold height by around 10-15mm Albeit the ones I used were for cathedral ports, but I assume they have similar for rectangular ports????
    • Thanks Paul I reached out to Autotainment but they no longer work on JDM cars as the guy who used to do the work moved on and is no longer doing that kind of work. I am talking with Level Up Audio though.
