Need New Brake Pads and Possibly Discs
Hi Guys,
So looks like my brake pads are cooked, left side has hit the indicator and is squeeling like crazy.  They were Bendix Ultimates.... Was recommended years ago but Im not getting them again...
Anyway I have been looking into the brake pad thread and it looks like the Intima SR's are the go for me.
My main issue is with the discs, I think they need to be replaced as well, will measure soon.
What I have narrowed it down to are DBA rotors.
Now Ive seen DBA 4963s for fronts and DBA 4908s for rears.
But as I was reading more, esp a more recent thread which said slotted rotors arent necessary.
So question to go Slotted or not, through brakes direct it looks like the difference in total would be 118.40
and would these pads and rotors be a good choice, if not open to recommendations
.... just realised mainly daily, with maybe odd track day, but not hardcore lap times
The pads you suggest will be fine. I'm running them myself. Very good on the street. I will be track testing them on Saturday. Since your mainly daily driving with occasional track use, you can even go with the cheaper rda plain rotors or if your current rotors aren't under size you can reuse those and have them skimmed If needed. My 2c. Cheers.
To answer the question on slots, they don't really do too much but do look pretty cool. So really its more a question if you're willing to spend some extra $ for the look factor. I personally run plain on the front and slotted on the rear only because I got them dirt cheap.
wallah!
however man, no idea how Brakes Direct are selling rotors at those prices!?!?!??!! it's like they're making $5~10 .. I just sent Matt a price list and then look at Brakes Direct thinking "yeah I'm cheaper for schizzle" then was shocked... they might have some kind of volume agreement
I've been running DBA T3 Club Specs for a while, happy with them. You can probably get by without the slots and save some coin, but have a compare of the internal cooling structure of your options, I'd say it's more important than the surface.
I too have just put in fresh Intima SR's, they bite nicely on the street. Only issue is pretty good squeal at a particular brake pressure, hopefully beating them a bit at Sandown will fix it :) soon
I find the Intima SR squealed a little with the 296mm R33 disc - but no where as much as Project MU HC+ or those god awful QFM pads, however on the 324mm Brembo discs/calipers they don't squeal.. It might be the size/dimension that provides the right mix to create the squeal and amplify it.
However going to the Type-D it's virtually silent for street use (as they don't bite when cold LOLOLOL) but on the track once they hit the right temperature they squeal a bit.
18 minutes ago, GTSBoy said:
SRs on my R32 on 33 rotors are quiet as.  Seem like a very decent street pad - not that I ever give my brakes enough load to really find out.
What's the dust like? loved my remsa's except for the mess they made of the rims, put my 3/4 used stock Nissan pads on while I reconditioned some 33 calipers, holy shit when I first tried to stop with them.
I have black wheels, so dust is not something that catches my attention.  Having said that, they are certainly more dusty than both the stock pads and Bendix Ultimates.  I wouldn't say they were as anywhere near as obscenely dusty as the pads that people complain about though.
If memory serves me right, they're a little less dustier than the QFM A1RM however will cop more abuse and not fade as quickly... and also much quieter!
I haven't used Remsa so can't compare... if this helps, they're less dustier than Project MU HC800 / HC+
SR's are heaps less dusty than the Remsas, they were ridiculous! In normal street driving the SRs are completely fine and I have white wheels..
Cheers for that, I'll put the SRs on my short list, I almost bought some Project MU NSs from RHD last night, as they have them for a decent price t the moment.
Well I did have a chat to Dose Pipe and he helped me where he could which was awesome, so will wait till the pads arrive. I'm still waiting for a quote on RDA's before I decide RDA or DBA...
Then I'll prob get a mechanic to do the install and touch up the tune at the same time, and report back on how it all goes
Ok. So just did the sandown track day yesterday and gave the sr's a good pounding. Sandown is very taxing on the brakes so perfect for reviewing the performance of these pads.
The car is a R33 gtst, stock sumitomo calipers, plain rda 324mm rotors with adaptors up front and rda slotted/drilled standard sized rears with sr pads all round, penrite 10 tenths fluid and stock brake lines. Small 35mm agi pipe ducts run from front bar to back of discs on front.
Completed 43 laps during the day. 30 of those in anger as it was wet in the morning. Every session was run flat out, no cool down laps.
The intima Sr get a big thumbs up from me. No fade at all, after they get hot, you do have to apply a little more pressure to the pedal but they still stop fantastic. As the day progressed I got more and more confident with the braking and the sr just kept doing the job. They squeeled a few times when real hot and that's about the only bad thing I can say. They didn't wear much either and the amount of brake dust that came off them wasn't much at all considering what they had just been through. They did get a real good workout and the car was going quick, managed to break into the 1. 25's which is pretty damn good for a stock brake system.
On the road for daily driving they are also fantastic. Quiet, low dust, almost squeel free. Only heard a slight squeel once or twice. Overall, great Street pad that can definitely handle track abuse as well.
Would definitely recommend to anyone looking for a pad that is good for the street, reasonably priced and can handle track duties.
  • Like 2
Thats good to hear!, looks like the bigger disc/cooling ducts are making a big diff,
Yeah I had my Brakes go dead after 3 laps at Symmons. Im not chasing lap times, but just want something reliable.
Do you guys think its worth swapping to braided lines as im redoing pads and discs?
    • Back again. I returned to Japan in Jul/Aug to spend time with the car on my birthday and remind myself what all the sacrifice and compromise is for. It happened to line up with the monthly morning meet in Okutama, which I have been wanting to go to for a long time. It's a unique event at a unique spot with really rare, interesting, and quirky cars. It's where all the oldheads and OGs gather. The nighttime scene at DKF certainly has its place and should be experienced if you're into cars, but there's too much bad attention and negativity around it now. IMO the better time is Sunday morning at DKF or Okutama; it's more chill and relaxed. I'm glad I was finally able to go, but not sure it's worth the drive from all the way from Nagoya immediately the day before, unless I was already staying in Tokyo for the days right before the meet, because you have to wake up quite early to make it in time. Funnily enough though I didn't drive the car all that much this trip because it was just too damn hot. While there were zero issues and running temps were nominal and the A/C was strong, RBs already run crazy hot as it is. Sure, it took it all like a champ but something about driving these cars in the ridiculous heat/humidity bothers me and makes me feel like I'm asking too much of it. I'm just me being weird and treating the car like a living thing with feelings; I'm mechanically sympathetic to a fault. Instead I was mainly driving something else around - a KX4(silver) 2001 X-Trail GT, that I acquired in May. There's a few different flavors to choose from with Xs, but visually it's the Nissan version of the Honda CR-V. Mechanically it's a whole different story as this, being the top-trim GT, has an SR20VET mated to a four-speed auto and full-time AWD! It was a very affordable buy in exceptional condition inside and out, with very low mileage...only 48k kms. Most likely it was owned by an older person who kept it garaged and well-maintained, so I'm really happy with how it all worked out. It literally needs zero attention at the moment, albeit except for some minor visual touch-ups. I wanted something quirky, interesting, and practical and for sure it handily delivers on all three of those aspects. I was immediately able to utilize the cargo and passenger capacity to its full extent. It's a lot of fun to drive and is quite punchy through 1st and 2nd. It's very unassuming -in the twisty bits it's a lot more composed than one would think at a glance- and it'll be even better once I get better tires on it(yes, it's an SUV but still a little boat-y for my liking). So...now I have two golden-era Nissans in silver. One sports car and one that does everything else; the perfect two-car solution I think👍 The rest of the trip...I was able to turn my stressed brain off and enjoy it, although I didn't quite get to do as much as I thought. I did some interesting things, met some interesting people, and happened into some interesting situations however, that's all for another post though only if people really want to know. Project-wise, I went back to Mine's again to discuss more plans and am hoping to wrap that up real soon; keep watching this space if that interests you. Additionally, while working in the tormenting sweatbox that is the warehouse, I was able to organize most of the myriad of parts that my friend is storing for me along with the cars, and the 34 has a nice little spot carved out for it: And since it can get so stupid hot in there, that made it all the more easy -after I was standing there looking at the car and said 'f**k it'- to finally remove all the damn gauges that have mostly been an eyesore all this time. Huzzah. The heat basically makes the adhesive backing on the gauge mounts more pliable to work with, so it was far less stressful getting this done. I didn't fully clean it up or chase the wiring though; that will happen once I have the car in closer possession. Another major reason to remove all that stuff is to give people less reasons to get in my car and steal s**t while it's being exported/imported when/if the time comes, which leads us to my next point... ...and that is even though it's time in Japan is technically almost up since it's a November car and the X would be coming in March, I'm still not entirely sure where my life and career is headed; I don't really know what the future looks like and where I'm going to end up. I feel there's a great deal of uncertainty with me and as a result of that, it feels like I'm at a crossroads moreso now than any point in my life thus far and there are some choices I need to make. Yes, I've had some years to consider things and prepare myself, however too much has happened in that time to maintain confidence and everything feels so up in the air; tenuous one might say. Simply put, there's just too much nonsense going on right now from multiple vectors. Admittedly, I'm struggling to stay in the game and keep my eyes on the prize. So much so in fact, that very recently I came the closest I ever have before to calling it quits outright; selling everything and moving on and not looking back. The astute among you will pick up on key subtext within this paragraph. In the meantime I've still managed to slowly acquire some final bits for the car, but it feels nice knowing there's not much left to get and I'm almost across that finish line; I have almost everything I'll ever want for my interpretation and expression on what it is I think an R34 should be. 'til later.
    • Thanks for that, hadn’t used my brain enough to think about that.
    • Also playing with fire if they start to flow more air down low than what the stock twins can. It's not even up top you need to worry, it can be at 3000rpm and part throttle and it's getting way more flow than it should.
    • Any G40/1000 or G40/1250 results out there?
    • You still want a proper tune on the stock ECU though. Stock tune + stock ECU with GT-SS/-9s is probably playing with fire if you're running more than stock airflow/power.
