I think the biggest difference was made by the pads, of course the rotors and ducts would've helped a bit. If you're not regularly tracking I wouldn't bother with braided lines if your stock lines are in good nick. If you have to replace because they look suspect then definitely worth it. My 2c[emoji4]
Glad I could help :)
Check out adms15' video on how his SR pads performed at Sandown.. pretty damn good!
They're no Project Mu HC800 pads but they're close enough and at half the price, it's perfect for a weekend track warrior
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sr[emoji106]
  • Like 2
  • 3 weeks later...
So I've decided to install the pads and discs myself after looking at guides.
Is the caliper bolts torque spec the same for gtr as gtst? Guide says 92-118nm
On 10/10/2016 at 8:23 PM, admS15 said:
Furthermore, happy to report after a week of normal Street duties that the track day didn't effect the pads at all. Unlike other Street track pads I've used that have become noisy squeely junk after a good thrash. Sremoji106.png
I got sent Intima SR instead of SS, they're great, Needs a couple of hits for it to warm up but perfectly driveable on the street (slow, daily driving). Once they're warm, holy shit they stop. Overkill for daily duties but works. Not that dusty either (especially compared to A1RM).
  • Like 2
So managed fronts yesterday. Drivers side was stuck but improvised with a clamp to get the disc off.
Tried the rears this arvo. Rear left easy.
Rear right is stuck and giving me no love. So I'll prob need to get some bolts to screw into the two holes do you guys know the specs on what I'll have to buy?
Yes use the bolts but also bash the drums all round with a big hammer to loosen things up (assuming handbrake is not binding). You may need to clean up a bit of a lip inside the drums before you put them back (unless you have new ones).
thanks guys ended up finding a couple of spare bolts from my top feed rail that fit the holes.  Managed all four discs and pads over the last couple of days, rain, darkness and the one stuck disc made it more than a day, as well as taking my time on the first one. but overall pretty easy job.
Thanks for your advice and esp thanks to Johnny and STT
  • Like 1
  • 4 weeks later...
On 03/10/2016 at 0:44 AM, admS15 said:
The car is a R33 gtst, stock sumitomo calipers, plain rda 324mm rotors with adaptors up front and rda slotted/drilled standard sized rears with sr pads all round, penrite 10 tenths fluid and stock brake lines. Small 35mm agi pipe ducts run from front bar to back of discs on front.
How are you finding the RDA's on the track Bill, any issues with the heat? Have you run DBA's before, for comparison?
I'm getting an annoying squeal (yes have added copper grease) and some shudder on the front right and trying to diagnose the cause, someone suggested the classic 'warped rotor' but will need to investigate further. My current DBA T3's have been skimmed once, there's maybe one more skim left in them, but in case I need to replacement I'm wondering if RDA's would do the job for ~60% of the price...?
Hi Jussi, so far so good but they've only really copped 1 hard track day. I need to put them through some more torture before I can give a decent assessment of how they cope under extreme duress. Haven't had dba before, just Nissan oem which held up well over multiple track days. I'll keep you posted in the future.@V28VX37
  • Like 1
On 10/3/2016 at 10:23 AM, MatthewT85 said:
Thats good to hear!, looks like the bigger disc/cooling ducts are making a big diff,
Yeah I had my Brakes go dead after 3 laps at Symmons. Im not chasing lap times, but just want something reliable.
Do you guys think its worth swapping to braided lines as im redoing pads and discs?
I think the theory with braided lines is the same as M/C stoppers: more instant reaction when you hit the brake pedal i.e. no initial flex of the bulkhead or expansion of the rubber brake lines.
    • Got the motor out and torn down. I'll be dropping off the block Monday. Luckily the scoring on Cyl6 is much less pronounced then the pictures made it out to seem. It can barely be felt. If you pass your finger over it 10x you'll barely notice it. Hopefully by some chance it will only require a honing. I'm not in the mood to buy one size larger pistons or another block. Oddly enough my 6th cylinder with the scoring has extremely clean intake valves compared to my other 5 cylinders. I'm worried the scoring was caused by too much fuel or Water/Methanol washing the cylinder. I'll review some old logs to confirm.  This was also the first time I pull an engine with the transmission still attached. It went much better then expected. I was worried my CD009 wouldn't make it easy due to its sheer size but it was much easier this way.
    • From the pictures I have when doing the job the flywheel is the same diameter, I don't think they're playing weird tricks like putting weights at the outer diameter to increase flywheel inertia or anything like that. The OEM flywheel is definitely heavier, but it's not a huge difference. Quoted weight savings of the clutch is 2 kg so I can't imagine the flywheel being lighter than ~7 kg. Kind of regret not weighing it before the clutch went into the car but as far as driveability goes I have no complaints.
    • HKS trigger kit should be very easy to integrate with a Link. It's a 36-2 crank trigger. Hard part is finding the motivation to take off the timing belt and everything on the front of the engine to install it. You also need to cut out a hole in the oil pump housing so the sensor can read the trigger wheel. Changing out the cam sensor for a 24 tooth setup is probably good enough but as others have mentioned depending on what underlying assumptions are changed it becomes more of a problem. Reading the crank state off of the cam is an abstraction that works in the general case, but if you have an edge case it makes less and less sense. There is a GTX2860 gen 2 that can take a compact 5 bolt housing so it's direct bolt on but I'm not 100% sure of what's involved. Peak compressor efficiency drops off a bit on these turbos vs -5s, 77% vs 73% but you get way, way wider region of operation. The -5s have a really strange surge line in their compressor map that is all over the place. If you think the hot side on the -5s aren't open enough you can try the Tomei T550B turbos which a local tuner seems to be happy with:
    • i need a complete tail light for my R33 GTR if you have please let me know.
    • I need a great maintenance workshop around Idaho, if you know one please let me know..
